Hello
I currently have a Full size Cooler Master HAF X case with the following build components
ASUS P9X79 Pro motherboard
Intel i7 3820 3.6 GHz. CPU - Socket 2011 LGA
NVIDIA GeForce GTX 760 gpu - 2 GB
2 X 4 GB sticks of Kingston DDR3 RAM - 799 MHz
1 TB Western Digital Hard Drive - old and tired
Running windows 10 64 bit OS
The system is slow and cranky
Applications take too long to start and respond
I am not at all hardware savvy or software savvy
I do NOT have any security software protection at all
I run Registry Mechanic and Glary Utilities often
I am NOT a gamer - do NOT play at all
But I use my computer a lot for business and surfing
I need it to be very very RELIABLE and FAST
I DO use graphics software like Corel Draw and sometime Adobe graphics products to fix graphics files
I use a lot of office productivity tools and Customer Relations Management software
I use Acrobat Pro to create and edit pdfs and a lot of graphics file edits
I surf a lot with literally 30 windows open all at once
BUT my computer seems very tired and I think I need an upgrade
I am very confused about whether I should change my entire system or just upgrade
PLEASE advise with detail suggestions on specific hardware
I do NOT mind USED components
I am on a BUDGET
Thank you
Yacob
I am on a BUDGET
Thank you
Yacob
