yea this mb have not default connectors for front panel . see pics . i think this cable is the adapter but i can't find anywhere for buy. when i search i find only reviews. i texted support of gigabyte but they don't answer 2 week :/Are you talking about the MB headers?
shortening of cables does not work while standard turning.....if you can give the correct pinout ill do it I will just be very grateful to youWell I was going to say contact Gigabyte on this matter. Most likely they don't have spares just laying around.
That's one downside of buying used stuff. If you have means to make your own cables, I can provide you the pinout.
The manual might have it as well.
Processor | Ryzen 5 5700x |
Motherboard | B550 Elite |
Cooling | Thermalright Perless Assassin 120 SE |
Memory | 32GB Fury Beast DDR4 3200Mhz |
Video Card(s) | Gigabyte 3060 ti gaming oc pro |
Storage | Samsung 970 Evo 1TB, WD SN850x 1TB, plus some random HDDs |
Display(s) | LG 27gp850 1440p 165Hz 27'' |
Case | Lian Li Lancool II performance |
Power Supply | MSI 750w |
Mouse | G502 |
why not just ask the seller for it? if he doesn't have or doesn't reply sent it back, ebay will give you your money back. Gigabyte support is bad, so your stuck.
That is not normal. Are you holding the power button or letting it shutdown normally?thanks, it turns on, but if you turn it off again from the button, it doesn’t start anymore, if not, unplug the power cable from psu for the 20 seconds .. and if you turn it on with the button from the motherboard and turn it off back from there, everything is fine
As soon as I clamp it, it immediately turns off as if chopped off from the outlet. that pinout from manual are default pinout like all other mbs. they did not write there that the most important meaning of the small connector is what and where from mb it says about the top of the connectorThat is not normal. Are you holding the power button or letting it shutdown normally?
please do it if u can and tell me where i have to connect that cables.I have that MB, but it will take some time to pull it out and see what the pins are. From the picture / video it looks like the PW cable is connected to the rest pins.
thank you so much for taking the time to do this! after work at night I'll try to connect everything like that and write the result thank you very much friend!here you go. funky layout. I think you were confusing the MB with rest and power instead of the correct pins.
works 100%, correctly, thanks you so much for help you are a great man! wish you all the best!!!!!!here you go. funky layout. I think you were confusing the MB with rest and power instead of the correct pins.
Processor | Ryzen 5 5500 |
Motherboard | ASRock X570 Steel Legend WiFi |
Cooling | Stock |
Memory | DDR4-3000 CL16 |
Video Card(s) | GTX 970 |
Storage | TEAMGROUP MP33 |
Display(s) | Acer R240HY, Pixio PX248 |
Case | Thermaltak P3 TG Pro Snow |
Power Supply | Super Flower Leadex III ARGB |
Mouse | Razer Deathadder V2 Pro Wireless |
Keyboard | K38 |
this is so wholesomeworks 100%, correctly, thanks you so much for help you are a great man! wish you all the best!!!!!!
System Name | Dark Obelisk |
Processor | Ryzen 9 5950x |
Motherboard | Asus Dark Hero X570 |
Cooling | Arctic Cooling 420 AIO 6x Gentle Typhoons |
Memory | 128gb Corsair Dominator 3600mhz 4x32gb |
Video Card(s) | Nvidia 3090FE (Copper Modded) |
Storage | 2TB Sabrent Rocket 4 Plus 4TB Sabrent Rocket 4 Plus |
Display(s) | AW3423DW-QDOLED |
Case | Corsair 1000D |
Audio Device(s) | DOUK External Amp/Dac |
Power Supply | Evga P2 1600watt |
Mouse | Asus Gladiator |
Keyboard | Corsair Rapid Fire MK2 Cherrys |
VR HMD | N/A |
Software | Win10 Custom Pheonix |
System Name | Always changing |
Processor | Always changing |
Motherboard | Always changing |
Cooling | Always changing |
Memory | Always changing |
Video Card(s) | Always changing |
Storage | Always changing |
Display(s) | Always changing |
Case | Always changing |
Audio Device(s) | Always changing |
Power Supply | Always changing |
Mouse | Always changing |
Keyboard | Always changing |
There's always that one guy whos never had a problem with their support I sent them a dead motherboard (no box and no accessories) I bought on eBay and they sent me a brand new one in the retail box within 2 weeks no questions asked LOL. I thought to myself, why didn't the owner just do this?! It did help that no pins were bent.why not just ask the seller for it? if he doesn't have or doesn't reply sent it back, ebay will give you your money back. Gigabyte support is bad, so your stuck.
System Name | BigRed |
Processor | I7 12700k |
Motherboard | Asus Rog Strix z690-A WiFi D4 |
Cooling | Noctua D15S chromax black/MX6 |
Memory | TEAM GROUP 32GB DDR4 4000C16 B die |
Video Card(s) | MSI RTX 3080 Gaming Trio X 10GB |
Storage | M.2 drives WD SN850X 1TB 4x4 BOOT/WD SN850X 4TB 4x4 STEAM/USB3 4TB OTHER |
Display(s) | Dell s3422dwg 34" 3440x1440p 144hz ultrawide |
Case | Corsair 7000D |
Audio Device(s) | Logitech Z5450/KEF uniQ speakers/Bowers and Wilkins P7 Headphones |
Power Supply | Corsair RM850x 80% gold |
Mouse | Logitech G604 lightspeed wireless |
Keyboard | Logitech G915 TKL lightspeed wireless |
Software | Windows 10 Pro X64 |
Benchmark Scores | Who cares |
Glad it worked out for you. This is always why I like to keep review products long term
