Please I need help flashing chinees RX580 2048SP 8GB
drfaisal
3 (0.01/day)
when I use amdvbflash.exe -fa -p "0" "XFX.RX570.8192.171129.rom"
I get this
Detecting AMD GPU/APU. Please wait...
VBIOS related functionality not supported for Device: 0x6fdf
what Can I do now
Thank you
1,568 (0.26/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
Which version of amdvbflash did you use? 2.93?
What did you do to confirm the new bios is compatible with your card?
40,736 (6.54/day)
He is using 3.31 or newer, he needs to use 2.93
Also he is trying to install a 1002 67DF bios when he needs a 1002 6FDF 1002 0B31 Bios
Using 67DF on 6FDF will brick it
I get this
what Can I do now
Thank you
drfaisal
3 (0.01/day)
Thank you all I did use 2.93 to flash vbios and it worked and in deed I broke the card but I reflashed it with the backup , Now still all games crash any advice for the correct vbios
40,736 (6.54/day)
1002 6FDF 1002 0B31 is the device id subsystem id you need, give a gpu-z screenshot, then go to advanced tab and change word general to memory timings and get screenshot from there please
drfaisal
3 (0.01/day)
I'm very grateful for your help thank all so much
after spending 5 hours last night flashing different bioses the same problem persisted so I thought it was bad graphic card so I removed it and I'm going to buy new one
Thank you all again
40,736 (6.54/day)
Thank you all again
Yes do yourself a favor and buy a brand new in box video card, not crap from ali express.
So a RX 6500XT or better
