Please I need help with the poor performance that my PC is giving me
NJX19
9 (3.00/day)
Well first of all, thank you for reading the post as it is going to be a long text to put it in context
First of all, this problem comes from an update that I did exactly last summer.
I had changed my ryzen 3 2200g for a ryzen 5 5600g and added a 1tb nvme
at that time my pc was this
ryzen 5 5600g
2x8 gb ram 2666
asus a320mk
1tb nvme kingston m.2
1tb western digital blue hdd
psu redragon 850 plus gold
rx 5700xt
when I changed the ryzen and added the disk I noticed that my games had super annoying micro cuts, but the game was only able to drop 2fps but that small jerk was noticeable, I tried everything, installing drivers from 0, formatting, windows settings but nothing worked, I simply resigned myself and came to think that it was the cpu simply because it was a ryzen with integrated, but before the update I was very sure that the pc worked perfectly in games.
After a while I upgraded the motherboard ram and gpu, thinking it could also be a matter of the low speed of the ram memories or that the motherboard was simply old, since it was about 4 years old
I changed to 2x16 gb of ram at 3600, a msi b550 pro vdh wifi motherboard and an rtx 3070, the problem continued...
I currently changed to a ryzen 7 5700x3d and I can't believe I still have these problems, now I was playing a lot of throne and liberty and I still have the same problems, I reformatted, updated, tested bios settings and I'm out of ideas, I'm posting on all the hardware forums I find to see if I'm lucky and find a solution
Currently my pc is this
ryzen 7 5700x3d
rtx 3070
2x16 gb ram 3600
msi b 550 pro vdh wifi
same disks
same source
I leave a video with an example of my problem, again thank you very much for reading!
stutter example
43,976 (6.81/day)
Remove the drive that you suddenly noticed stutters with
NJX19
9 (3.00/day)
Sorry but I don't understand what you mean, removing the CPU?
2,334 (1.15/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
is the game installed on the hdd or ssd? i presume its ssd...
43,976 (6.81/day)
No, you added a drive to your system and then suddenly started having problems, remove the drive you just put in right before you had stutters.
Do you understand?
A PC is only as fast as its slowest component.
NJX19
9 (3.00/day)
Do you understand?
I already tried it and there was no luck.
Yes, the game is installed on the ssd
2,190 (0.66/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
Test your RAM
Test your hard drives
See if there is a firmware update for your hard drives
Experiment with OS settings impacting drive behavior
1,770 (1.09/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
Please test for stuttter in an offline single player game with an fps cap, or use a standalone benchmark. Uneven frame rate in an MMO is not unusual.
In this particular game with your current settings VRAM is maxed out, which will result in fps drops and hitching. Also, judging by your RAM usage you may be running other stuff in the background.
sram
16 (0.27/day)
Do you understand?
This. From your talk, it seems like you changed almost all relevant hardware except the disk so it must be the disk. Use the old disk or another disk and see what happens. How does this ssd show in ssd software? Check its health.
NJX19
9 (3.00/day)
The disk is only a year old since I bought it, here are some images of the software:This. From your talk, it seems like you changed almost all relevant hardware except the disk so it must be the disk. Use the old disk or another disk and see what happens. How does this ssd show in ssd software? Check its health.
NJX19
9 (3.00/day)
In games like Cyberpunk I have a similar problem but it's not as extreme as in the video, I would even say that it doesn't bother me, but in Throne and Liberty it's super annoying.
NJX19
9 (3.00/day)
Above is the result of crystaldiskmark, I also tried another program that was recommended to me on reddit hd tach, here I leave it in case it helps.
2,190 (0.66/day)
Storage 1TB 980 Pro
Software W11 Pro
105 (0.02/day)
ryzen 5 5600g
2x8 gb ram 2666
asus a320mk
rx 5700xt
ryzen 7 5700x3d
rtx 3070
2x16 gb ram 3600
same disks
same source
stutter example
CAP your FPS to 100 in Nvidia Control Panel. Is enough for the game. Capping will give more stability.
Check your system for corruptions
Type CMD in search box. Right click and run CMD(command prompt) as admin - SFC /scannow with a space after SFC press Enter - if errors found - restart computer and run again the command till comes clear with the message : "Windows Resource Protection did not find any integrity violations."
If run twice the command with a computer restart in between and still can't fix /repair the corrupted files you have to use DISM command:
DISM /Online /Cleanup-Image /RestoreHealth
Run windows updates after this command.
For the drive where you store your game
Now type
chkdsk /f /r /x C: instead of C type the letter of the drive where you store your game.
After pressing enter will take some time. Restart the PC after that.
305 (0.16/day)
Elsewhere, USA
Processor AMD R7 9800X3D
Motherboard Gigabyte B850M Gamering X Wifi
Cooling Thermalright Phantom Spirit (7 pipe)
Memory Flare X 16GB x2 6000 MT/s 28-36-36-96
Video Card(s) Sapphire RX 9070 XT Pulse
Storage WD SN850X 2 TB
Display(s) Acer XV340CK x2
Case Lian Li A3 black, mesh, woodgrain
Power Supply Corsair RM750e (2025)
Software ZorinOS Pro
Turn of power monitoring on for your gpu.
305 (0.16/day)
Elsewhere, USA
You think 3000 series cards have an issue with power monitoring?
It can happen infrequently. Those massive power dips during stutters make me suspicious. If you turn it off on osd, and unchecked it as well, see if the stutters go away.
105 (0.02/day)
I don't think OSD does that but the overlays in this context.
I can even go as far as the game is hashing his card in a certain % if he plays online.
Stutters can appear from various reasons from bad DX 12 implementations in the game code, bad driver optimization, corrupted driver in the repository, junk software loaded at each start up, unreliable PSU voltages, already dying parts of voltage regulators circuit.
NJX19
9 (3.00/day)
Hi, luckily I have good news, yesterday I continued touching some things like installing ISCL, removing some background applications and the truth is that I don’t remember what it was another thing because I already tried a lot lol, the thing is that the performance stability improved a lot but I still have some high peaks in the frametime, it goes up and down at the same time generating a micro cut, I already limited the fps with rivaturner but it doesn’t fix it, could it be some configuration that I’m missing in the bios? (the only thing I touched in the bios was to activate xmp) or configure some kind of vsync since my monitor has freesync but since I have an nvidia gpu I can’t use it (in theory yes, but only with dvi and my monitor doesn’t have a dvi input)
I found this error with latencymon, does anyone know how I can solve it?
105 (0.02/day)
Did you manage to do those commands?
I mean all this:
Now type
Regarding Latency Monitor
Is not an error, is just saying that your system have problems in handling request fast enough to have a let's say a smooth experience.
the highest interrupt is shown by Nvidia driver, so try reinstall that. But before you do run the Latency Monitor while playing the game for at least 30 min and than post the image here.
NJX19
9 (3.00/day)
I tried the commands and no luck, it didn't detect any corrupt files either and I already did a clean installation, I was able to improve performance a little but I still have some strange spikes in frametime, here I'll leave you a recording of two games so you can see what I mean!
