Pls help- First Time Using Second-Hand Parts – Is This preowned AMD CPU Worth Buying
Eternalblue
1 (0.25/day)
Hello everyone
This is my first time building a PC with second-hand components, and I have no experience with used parts. Could you guys help me check if this second-hand AMD CPU is worth buying? The green coating on the edges is missing, but the pins look fine.
My current CPU is too old i5-6600k does not support win11 , so I want to buy a second-hand CPU with adequate performance that isn’t too expensive.It is local pickup around 180 Canadian dollar(125usd).
https://ibb.co/0pc5SNK9
https://ibb.co/tp7vncmg
https://ibb.co/4nzvm6hx
https://ibb.co/bjVLv98G
43,999 (6.81/day)
Hello everyone
I wont buy used products without buyer protection when it comes to electronics.
Hello everyone
There are ways to bypass W11 system requirements for your existing system they are all over youtube.
2,617 (1.58/day)
Bulgaria
This processor appears to have had its cap removed sometime in the past, if I can trust my eyesight. It's unclear for what purpose and whether it would work as expected, if at all.
43,999 (6.81/day)
This processor appears to have had its cap removed, if I can trust my eyesight. It's unclear for what purpose and whether it would work as expected, if at all.
IHS removed:
1. LN2 OC
2. Deceptive practice
I would only buy a used part if there is buyer protection
OneMoar
There is Always Moar
8,831 (1.62/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
a few of the pins look dark as well can't tell if its just the light or if they are burnt possible substrate damage
No to many questions for a old outdated cpu, unless its very cheap (sub 75 usd) I would not bother you can get better examples on ebay for 150 usd or better yet go with something like a 5600x which is easily had for under 100 usd you are still looking at replacing the motherboard and ram anyway so no sense buying that 3900x
426 (0.09/day)
I couldn't tell you what the chip at the top is from, but other than that, the pins look straight and fine to me.
That being said, I wouldn't be looking at a 3900X unless you do very highly threaded production work, and I'm going to guess you don't since you have a 6600K. Otherwise, you have better choices. The thing with the 3900X is, like all Ryzen 9s, it's multiple CCDs, but on top of that, each CCD was sort of "virtually" further split into CCXs before Zen 3 (Ryzen 5000 series), so the 3900X is a bit like a 3+3 and 3+3 CPU. This can cause latency penalties in anything that crosses those core counts. For highly threaded productivity where latency doesn't matter, it's a performant CPU, but for general use/gaming? I'd pass. I know of people who used it for general use/gaming and regretted it. The Ryzen 9 x900 tier has always been a niche option and the 3900X in particular was the worst of them due to the CCX split.
If you need an AM4 budget option in a pinch, I would consider the 3700X a better choice (it's a 4+4 single CCD, so it has the best chance of avoiding the CCX penalty and no CCD penalty), but ultimately I'd look for a used 5600, 5600X or 5700X instead as they also have no CCX penalty concerns and are more performant while still being cheap on the used market.
43,999 (6.81/day)
Local Pickup huh, he should have the seller meet him at a pc repair shop to verify the cpu posts and doesn't crash under idle or load, if the seller turns that down don't buy it and report them on Social media/advertising website and authorities.
On ebay I was purchasing what I thought was a 5800X for 362 in 2021, after I received it, it stated 5800, I took it to Microcenter to verify if it was an X or not and that it would Post and not crash.
I paid 40 for that test.
I requested money back after I gave undeniable proof it was a 5800 and not an X. He spilled the beans that it came out of a dell and offered $85 back, I turned it down for $100, he agreed and sent me 100 back and I warned him to not be deceptive, so I got the 5800 for $262 at the time. I also knocked his reputation down a few points for that bs.
Hello everyone
You have to catch people off guard
553 (2.41/day)
why ? new 5600x/5700 cost under 130 US dollars, why would you pay the same for a used zen2 ?
7,890 (5.13/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Frick
Fishfaced Nincompoop
19,935 (2.87/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
That depends on how much you pay for it and what your expectations are. For me that usually means pay a lower price for something I'm fairly certain I can fix (no guarantee though!).
I've gotten Windows 11 update avaliable notifications on systems that weren't originally supporting Windows 11 (Ryzen 5600 with TPM disabled), the requirements has changed.
Basically this. A 3600, 5600 or even a 2600 would be more sensible for general use and gaming.
Note that rather deceptively, the 5700 non X is not Vermeer, but Cezanne with iGPU disabled... and as a result much worse than the 5700X - just avoid this model altogether
Ohh, didn't know that.
3,499 (1.70/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Hello everyone
I don't see anything wrong but you never know sometimes when buying used.
If ebay is your thing there is a north american listing for a complete combo for only $250 - Ryzen 9 3900x CPU, MSI Tomahawk Max Motherboard, 16GB Corsair Vengeance DDR4. Seems like a pretty good deal if your comfortable with the risk. Not sure if import fees might apply.
On the other side of the coin for $1 more you could get a new Zen3 5700 8-core on NewEgg.
Less cores but newer Zen3 CPU, and no guessing if it's damaged, and no CCX/CCD issues for gaming.
Based on your current CPU AMD 5500 might also be a valid less expensive choice. Presumably you will still need other parts too.
5600x/5700x would be better choices if you can find them in your price range.
Ouch. I forgot about that. (edit) ...but it's still Zen3
43,999 (6.81/day)
View attachment 388571View attachment 388574
Ebay has buyer protection, its why I went that route over facebook
813 (1.87/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
The ryzen 3900x is not worth it anymore. Too old and too outdated.
Literally this. I run a 3600 all day at 4GHz and it is far more than enough for my needs, which is next to nothing really.
If there is something I'm doing that MUST BE ON, I hand it off to my Athlon 2650e and let it go brrrrr.
If I'm doing something medium to highly threaded, I hand it off to my FX-8370 and it usually does a fair job.
When I have anything else highly threaded that needs to qualify or needs done RIGHT NOW, R5 3600 for the win.
The 3900X is effectively double what I have here. It's a 12c/24t part and it's fast af boi.
The 5900X is a newer generation part with optimizations and performance over the 3900X, often with a +$130 premium.
They're GREAT chips. Just make sure they're the right ones for you.
58 (0.10/day)
Frankfurt am Main, Germany
with halved cache
But much less power Consumption. The Cezanne-CPUs are in the Desktop-Load and in Idle the CPUs with the lowest Power/Watt-Ratio at this Time. Thats why i like them. But there is one another Disadvantage: PCIe 3.0 not 4.0 if you need this. This would effect a NVMe Drive more than a Graphics Card with 16 Lanes but thats one another Thing. The Cezanne CPUs got some Benefits and some big Cons.
3,499 (1.70/day)
Mouse Logitech M575
180 CAD is a lot of money for a used Zen 2 processor. That's about the current market price for a brand new i5 13400 and Ryzen 5600.
It's a good point to bring up if OP has to change socket anyway to look at offerings from both camps to find the price/performance match that fit's in the OP's budget.
