PNY GTX 770 XLR8 OC - Aftermarket cooler?
7,113 (0.99/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
What heatsinks will fit a PNY GTX 770 OC XLR8 2GB?
This is a picture of the model from bit-tech's review:
Here is what I am considering:
Prolimatech MK26 (stacked power ports interfere)
Prolimatech MK13 (really big with the 120mmx25mm fans, OTOH you can run any fan you want)
Gelid Icy Vision (no pwm option so would need to run on a fan controller)
Arctic Accelero Twin Turbo II (really hard to find the II)
1. power connectors are stacked, any ideas if this is a problem?
2. stock vga wiggles and thermal paste doesn't stay so it is driving me crazy, I don't want to repaste card every time I change sata cables, this is because the posts for the heat sink don't fit through the holes in the pcb
3. I'd like to reuse the ram and vrm heatsinks
4. any others to consider, the arctic don't look like they work due to the double stacked power connector besides the twin turbo
edited to condense my thoughts.
mk13 is short enough it will probably fit with the stacked pci-e...
