Poll: Do you think the 5090 will be thermally or power limited?
Which limitation will apply first?
  • It will be thermal limited
    Votes: 7 21.9%
  • It will be power limited
    Votes: 25 78.1%
  • Total voters
    32
l1CappYl1
27 (0.40/day)
China
It's all speculative at this point, but looking at how much size discrepancy there is between 5090s compared to previous gen cards got me thinking. If SFF cards can do the job, why are there so many ginormous coolers? And with the card TBP so close to the max rating of the cable, why are none of the top models offering 2 connector options?
What do you all think?
43,111 (6.73/day)
1,651 (3.88/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
575w is 1960 BTU/hr.
According to the calculator, that is almost exactly what you'd need to heat a 10x12 room to 75f with 10f outside temp.
So they have ginormous coolers :)
Edit: I voted thermally limited.
101 (0.02/day)
southern ontario
System Name AboutTime
Processor AMD 9800X3d
Motherboard AS Rock Taiichi Lite X870E
Cooling Be Quiet 360mm Light Loop.
Memory TeamGroup T-FORCE DELTA RGB 32GB (2x16GB) DDR5 6400MHz
Storage Crucial T700 NvMe 4 TB
Display(s) 24" Benq FP241W
Case Be Quiet Shadow Base 800 FX
Audio Device(s) On board audio. Speakers Edifier R200DB
Power Supply FSP Hydro Ti pro 1000 watt
Mouse Corsair M65 pro
Keyboard SteelSeries Apex 3
Software W11 64 bit Pro
Both I would think. If the 575 watt power use is to be believed and the power connection is 600 watts that leaves very little room for any overclocking if any at all and heat wise that's one huge die and heatsink plus all those power regulation stages and Vram chips. That suckers going to pump out a good deal of heat . We will know soon enough with legitimate reviews coming up in not to long.
1,032 (0.70/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
unleashed 5090 is double the 5080 or 720W and OC models should be up to 800W and we don't get that anymore, not that I would use it that way. some 2080 Ti with a 360W limit at 44% over stock.
l1CappYl1
27 (0.40/day)
China
Where are you getting those numbers from? The 12vhp+pcie would max at 675 and I can't imagine any board pushing power to the limit like that.
Not all of them.
Right now, they are all listed with the same power draw and clocks. I guess that's just a place holder and some cards will do more/less depending on their cooling performance, otherwise, what's the point of going 4 slot if a 2.5 can do the job?
1,032 (0.70/day)
Memory 32 GB
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
To run at its maximum clock speed all the time, the 5090 probably needs 720W, effectively a double 5080, so it will be severely limited. But even a 4090 doesn't always exceed 350W in games despite a 450W bios. So it depends on the use case. Especially if you are doing DLSS because that will lead to a very unbalanced load on the shaders and lower power if I remember correctly 450 W with RT-only but drops to 350 W if you enable DLSS.
johnspack
Here For Good!
6,043 (0.96/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
Must contain myself.....
539 (0.13/day)
System Name Can I run it
Processor AMD Ryzen 7 9800X3D (still pre-order)
Motherboard Gigabyte B650E Aorus Master
Cooling 2x EK-XRES 140, 3x Bykski 360mm/1x 240mm all white, DP100-D5 Plus distro, 12x T30, AC High Flow Next
Memory KLEVV CRAS V RGB DDR5 48GB (2x24GB) 7200 MT/s 34-44-44-84 ->7400 MT/s 36-46-46-86 (ROG Cert) 1.4V
Video Card(s) Waiting for something decent...
Storage Transcend PCIE 220S 1TB (main), WD Blue 3D NAND 250GB for OC testing, Seagate Barracuda 4TB
Display(s) Samsung Odyssey OLED G9 49" 5120x1440 240Hz calibrated by X-Rite i1 Display Pro Plus
Case Coolermaster HAF 700 White
Audio Device(s) Q Acoustics M20 HD speakers with Q Acoustics QB12 subwoofer
Power Supply Thermaltake PF3 1200W 80+ Platinum
Mouse Logitech G Pro Wireless
Keyboard Logitech G913 (GL Linear)
Thermal limited can be solved by watercooling or bigger case.
Power limited can only be solved by an additional 16 pin which I haven't seen yet.
117 (0.03/day)
Some Ppls are so shocked..
But amd fans told its okay to have so huge power usage.. but its allowed only if Amd Gpu
10,910 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
Well considering the 4090 is melting cables already - and mine melted my connector at the PSU side making me finally replace my PSU... It will be exciting to see how this ends up with that crap connector pulling max wattage.
7,267 (4.90/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Undoubtedly thermally limited on air cooled cards. Liquid will be power limited.
484 (0.34/day)
Processor AMD 7600x
Motherboard Asrock x670e Steel Legend
Cooling Silver Arrow Extreme IBe Rev B with 2x 120 Gentle Typhoons
Memory 4x16Gb Patriot Viper Non RGB @ 6000 30-36-36-36-40
Video Card(s) XFX 6950XT MERC 319
Storage 2x Crucial P5 Plus 1Tb NVME
Display(s) 3x Dell Ultrasharp U2414h
Case Coolermaster Stacker 832
Power Supply Thermaltake Toughpower PF3 850 watt
Mouse Logitech G502 (OG)
Keyboard Logitech G512
Yes only AMD have done this before.... Fact of the matter is that 500 watt GPUs are excessive to most people
3,850 (2.30/day)
System Name Mean machine
Processor 12900k
Motherboard MSI Unify X
Cooling Noctua U12A
Memory 7600c34
Video Card(s) 4090 Gamerock oc
Storage 980 pro 2tb
Display(s) Samsung crg90
Case Fractal Torent
Audio Device(s) Hifiman Arya / a30 - d30 pro stack
Power Supply Be quiet dark power pro 1200
Mouse Viper ultimate
Keyboard Blackwidow 65%
No way it's going to thermal throttle. Why would it?
But is your connector on the PSU side a 12vh? Doubt it, most psus are using proprietary stuff. That was totally a PSU issue not a gpu issue.
82 (0.26/day)
The 675 watt power limit kinda pisses me off. I was planning to do a nice overclock since I got a big watercooling system. I will have to find other ways
226 (0.84/day)
System Name Main Workstation
Processor AMD Ryzen Threadripper 2970WX PBO 3,6-4,2Ghz
Motherboard Gigabyte x399 Aorus Pro (ReBAR patched)
Cooling Alphacool Eisbaer Aurora Pro 420
Memory 8x16GB (128) Kingston Fury RGB @3266Mts 16-18-18-36-74 2T
Video Card(s) RTX 3090 ROG Gaming OC @1500Mhz (1965Boost)
Storage Lexar NM790 2TB, Corsair Force MP510 960Gb, Samsung 860 SATA 2TB, 2TB WD Green 7200rpm
Case Phanteks Ethoo Pro 2 TG
Power Supply EVGA Super Nova 1000GT
A ROG Mars is basically a modded card. My Shunt modded Titan XP can also draw 600W+ I should test what a 690 or 760x2 pulls after a voltmod.
592 (0.12/day)
mississauga, on, Canada
System Name YACS amd
Processor 5800x,
Motherboard gigabyte x570 aorus gaming elite.
Cooling bykski GPU, and CPU, syscooling p93x pump
Memory corsair vengeance pro rgb, 3600 ddr4 stock timings.
Video Card(s) xfx merc 310 7900xtx
Storage kingston kc3000 2TB, amongst others. Fanxiang s770 2TB
Display(s) benq ew3270u, or acer XB270hu, acer XB280hk, asus VG 278H,
Case lian li LANCOOL III
Audio Device(s) obs,
Power Supply FSP Hydro Ti pro 1000w
Mouse logitech g703
Keyboard durogod keyboard. (cherry brown switches)
Software win 11, win10pro.
every Nvidia card or any graphics card is power limited. thermally limited can be solved with water cooling or a better cooling solution, such as putting the radiator outside of the case, using “ refrigerator freezer technology” to cool the water…
