Portwell Builds Intel Xeon Motherboard with 20 USB Ports
AleksandarK
2,790 (1.02/day)
Have you ever felt the need that your motherboard needs more ports? Different peripherals can occupy quite a lot of USB ports and almost fill up all of them quickly. That is where the Portwell PEB-9783G2AR motherboard comes into play. Being built on Intel's latest W480E/Q470E chipset designed to accommodate any 10th generation 10 core CPU with a TDP of up to 80 W, the board can run either a Xeon W CPU or regular Comet Lake-S Core CPU. However, what makes this board unique is not its chipset or anything, it is the number of USB ports present.
Portwell has put an astonishing 20 (you read that right) USB 3.1 Gen1 ports on the board, which you can run at a full 5 Gbit/s data signaling rate at the same time. The board doesn't use any splitting technology so you are getting the full bandwidth. To get that many ports to run at full capacity, Portwell has presumably re-routed chipset lanes for SATA 3 connectors and used them for USB ports, leaving only two SATA 3 ports. The board is built for the FlexATX form factor and features a sideways PCIe 3.0 port. Being built for Xeon, the board also features support for ECC memory and up to 128 GB of it. While the pricing is not yet available, you can get a quote on Portwell's website.
290 (0.11/day)
awesome. 20 Hot pluggable drives simply by using external USB3 enclosures for internal 2.5" HDDs/SSDs
427 (0.20/day)
Australia
System Name Ryzen
Processor AMD Ryzen 7 5700X
Motherboard Asus TUF Gaming B550-Plus (Wi-Fi)
Cooling Cryorig H7
Memory Kingston Fury Beast DDR4 3200MHz 2x8GB + 2x16GB
Video Card(s) Sapphire NITRO+ Radeon RX 6700 XT GAMING OC
Storage WD_Black SN850 500GB NVMe SSD + Adata XPG SX8200 Pro 512GB NVMe SSD
Display(s) Gigabyte G27QC
Case NZXT H510 Flow
Audio Device(s) SteelSeries Arctis Prime
Power Supply Corsair RM650x Gold 650W
Mouse Logitech G502 X
Keyboard HyperX Alloy FPS Cherry MX Blue
"Portwell" by name, "Port-very-well" by reputation.
14,323 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
I heard you like USB ports on your USB ports.
7,607 (1.46/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Mobile flashing, mass production mode or testing debugging HW and SW.
I can see this also in multi instrument automatization. When you have many independant DSP blocks in a rig. You connect it once and forget.
Disabling port reenumeration helps binding each port for specific HW, thus leaving the same COM number, so their native aplications does need setup config. Port count helps with that, as there are many HW platforms.
The world does not turn around only about need to plug in few flash drives. It is a specific board aimed at a specific market.
2,585 (0.79/day)
Figure it must have some practical use scenario to exist in the first place.
1,086 (0.18/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 990PRO 2TB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/9qw7iq https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
20 USB3 +2 LAN ports on the back is like the ideal look for my motherboard.
Wish we had more of these :D
200 (0.12/day)
System Name BUBSTER
Processor I7 13700K (6.1 GHZ XTU OC)
Motherboard Z690 Gigabyte Aorus Elite Pro
Cooling Arctic Freezer II 360 RGB
Memory 32GB G.Skill Trident Z RGB DDR4 4800MHz 2x16GB
Video Card(s) Asus GeForce RTX 3070 Super Dual OC
Storage Kingston KC 3000 PCIE4 1Tb + 2 Kingston KC 3000 1TB PCIE4 RAID 0 + 4 TB Crucial gen 4 +12 TB HDD
Display(s) Sony Bravia A85 j OLED
Case Corsair Carbide Air 540
Audio Device(s) Asus Xonar Essence STX II
Power Supply Corsair AX 850 Titanium
Mouse Corsair Gaming M65 Pro RGB + Razr Taipan
Keyboard Asus ROG Strix Flare Cherry MX Red + Corsair Gaming K65 lux RGB
Software Windows 11 Pro x64
Does the word USB Hub means anything to these guys...
2,834 (1.61/day)
That's a good point.
I remember seeing old CD-ROM builds where you'd have 20+ CD-RWs connected up to a single computer. Yeah, its slower than printing disks, but it was lower-cost for small-runs (ie: small local bands selling CDs).
The idea of handling dozens of flash-disks simultaneously for some... specialized purpose... just makes sense to me. Although it wouldn't be for musicians, it'd have to be for some other industry need where a ton of flash drives or portable storage was needed.
USB Hubs only allow one device to physically talk at a time.
Someone needs GBps per USB port, and 20x of them all reading/writing simultaneously.
226 (0.05/day)
I see 2 usage, but it must be cheap MB or it's not very useful, just cheaper :
  • Create a hub for PoE cameras : they don't need a lot of bandwith, but they need power and PoE switch are expensive
  • Create a station to load computers images for IT : like you have 20 new laptop to load with the company custom OS installation, you can use that as an hub (with USB => Ethernet adapters) to make it easy to use without another system.
You can also do both, and not pay a shitload of money for a NAS that will not fill your need.
But the testing thing might be a good option too. Very specific needs, because you don't unplug a drive like that.
2,834 (1.61/day)
For #1, USB doesn't seem to have the length or power-requirements needed for a ton of cameras.
For #2, PXEBoot is just easier, and all you need is a standard 20-port ethernet switch + one spare computer on the network to use PXEBoot. (And said computer can be a VM)
551 (0.17/day)
Texas
System Name O-Clock
Processor Intel Core i9-9900K @ 52x/49x 8c8t
Motherboard ASUS Maximus XI Gene
Cooling EK Quantum Velocity C+A, EK Quantum Vector C+A, CE 280, Monsta 280, GTS 280 all w/ A14 IP67
Memory 2x16GB G.Skill TridentZ @3900 MHz CL16
Video Card(s) EVGA RTX 2080 Ti XC Black
Storage Samsung 983 ZET 960GB, 2x WD SN850X 4TB
Display(s) Asus VG259QM
Case Corsair 900D
Audio Device(s) beyerdynamic DT 990 600Ω, Asus SupremeFX Hi-Fi 5.25", Elgato Wave 3
Power Supply EVGA 1600 T2 w/ A14 IP67
Mouse Logitech G403 Wireless (PMW3366)
Keyboard Monsgeek M5W w/ Cherry MX Silent Black RGBs
Benchmark Scores https://hwbot.org/search/submissions/permalink?userId=92615&cpuId=5773
20 usb ports... i approve of this immediately
110 (0.03/day)
Charleston, SC
System Name EchelonV
Processor AMD Ryzen 5 2600X
Motherboard Asus Prime X470-Pro
Cooling Corsair H115i
Memory G.Skill Flare X 2x8GB (F4-3200C16-8GFX)
Video Card(s) Sapphire Radeon 5700XT
Storage Intel 660P 2TB NVMe; 6xWD5000HHTZ RAID-0
Display(s) Dell U3415W
Case Corsair Carbide 678c
Audio Device(s) SteelSeries Siberia 800
Power Supply Corsair RM650X; CyberPower CP1500PFCLCD
Mouse SteelSeries Rival 100
Keyboard Cooler Master CK550
Software Windows 10 Professional 1903
Benchmark Scores Cinebench R15 3.9GHz = 1404
I was shopping for something with 22 USB ports. Close, but no cigar.
200 (0.12/day)
System Name BUBSTER
I meant for peripherals (mouse...) not transfers like an external hard drive.
1,002 (0.18/day)
Who asked for this though? What industry has an application for this. I genuinely want to know.
Thats very easy, there are miners which are effectively size of flash drive.. and plugged into USB. All you need is them and this mobo. :D
226 (0.05/day)
Meehhh.
So what it could be used for...the best I see is piracy actually ... not very useful. And plugging a Xeon on that seems overkill.
61 (0.03/day)
Germany
System Name New Horyzen
Processor Ryzen 7 1700X
Motherboard ASRock Fatal1ty X370 Gaming K4
Cooling Noctua U-12S
Memory 2x 8GB Corsair Vengance LPX 3200MHz
Video Card(s) Sapphire 5700XT
Storage A lot
Case Modded Corsair Carbide 300R
Audio Device(s) ESI Maya44 eX, Focusrite Scarlett 2i4 2nd, Samson Meteor, Mixer and Headphone Amp
Power Supply SeaSonic M12II 750W
Keyboard HyperX Alloy & Logitech G13
Software All of it
This could be nice for having a bench full of Lab-Equipment.
Just plug in your scopes, PSUs, testers, etc. and off you go.
2,585 (0.79/day)
Could make a 400TB proxy cache server from 20 combined 2TB drives in windows raid 10 with 128GB of ECC and primo cache buffering it all.
184 (0.07/day)
System Name Linotosh
Processor Dual 800mhz G4
Cooling Air
Memory 1.5 GB
That's what we use! I'll be dealing with PXE for the next 2 months based on my current schedule.
