Possible psu failure after 9 years?
2,165 (0.33/day)
Metro Manila, Philippines
System Name Zangief (Reborn) 2.0 AM4 not dead yet!
Processor AMD Ryzen R7 5700X3D (tweaked PBO)
Motherboard Gigabyte GA-AX370 Gaming K7 Rev 1.0 BIOS F53d
Cooling Noctua NH-D15 Push / Push Config | 2x ML120 | 2x Phanteks 120 mm
Memory 2x16GB G.Skill Trident Z Neo RGB @ 3600mhz CL 18 -> running 3800mhz @ 1.37v
Video Card(s) Asus RTX 3080 Rog Strix Gaming OC
Storage 250 GB Samsung Evo 850 / 1tb WD Black / 4tb WD Blue / 512GB Adata XPG Pro SX8200
Display(s) Acer Predator XB271HU |Asus VX239H 23" AH-IPS Led
Case Phanteks Enthoo Pro M TG
Audio Device(s) On Board Realtek HD | Steelseries Arctis Nova Pro Wireless
Power Supply Corsair HX750i
Mouse Logitech G903
Keyboard Corsair K70 RGB MK.2 Cherry Browns | Akko 3908N Purple v3 Tactile
Software Windows 11 Pro 24H2
So I recently upgraded to a 5700x3d and a 3080 10gb.
I was playing MH wilds for hours without issues yesterday.
Today hopped on for a quick hunt and after I loaded in PC BSoD with a DPC Watch Dog violation.
After I shut off pc it turns on and clicks off instantly.
I then turned off psu switch and unplugged it. Rest for a few mins.
Tried again and was able to get into windows. But when I stressed it with a game or occt. It shuts off leaving leds on and even power switch led on the case.
After cycling the psu power switch it just goes 1 tick and turns off leaving leds on.
I thought it was my processor but I put back the 1700x and same behavior.
If the psu is the culprit.
Which one would be good between the two (considering if I upgrade gpu and platform in the future?)
Or
Thanks
Toothless
Tech, Games, and TPU!
9,774 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Nine years is a good life for a unit. Also don't know those links so they're staying blue. You can upload directly into your post or just say what they are.
FreedomEclipse
~Technological Technocrat~
24,538 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
HX is old. time to let it go. The links dont work. site wants me to log in to see stuff.
Otherwise an RMe or RMx would be a fine replacement.
1,206 (0.79/day)
My SF450 showed the same. I suspect some pads need to be replaced. makes the 5V line unstable (memory channel when populated) also overheats faster than the fanless function can kick in.
2,165 (0.33/day)
Mouse Logitech G903
Whoops sorry about that. It is the seasonic focus gx 850 watt but 2 different variants.
Altho the listing was confusing I found the 2024 model which has atx 3.1 compatibility.
Apologies for the link I was panicking.
Is this a good pick?
2,963 (6.40/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
The GX is a solid lineup, yeah. Should be fine for you to grab. Or, as @FreedomEclipse noted, Corsair RMe and RMx are also good options in the same class that are usually widely available.
FreedomEclipse
24,538 (3.76/day)
I would look for the V3 (ATX 3.0) version instead instead of the V4.
The V3 has a better write up
::EDIT::
Also. If you want to know if you can trust hwbusters. The guy who did the review is the former PSU reviewer for TPU - Cmaris.
2,165 (0.33/day)
Mouse Logitech G903
Thank you for your replies all of you. Will try to find the v3 version as suggested or another Corsair if I can't find the V3.
6,488 (1.11/day)
Midlands,UK
System Name Ultraman|Living room
Processor Intel core i9 13900HK|AMD Ryzen 7 5700x
Motherboard Alienware/Dell inverted motherboard|Asus B550m Prime Wifi
Cooling Alienware/Dell cooling + IETS GT500 cooling pad | Thermalright Silversoul 135 + Corsair 140mm white
Memory Alienware/Dell 32GB 6000mhz DDR5|Corsair DDR4 16GB 3200mhz
Video Card(s) Nvidia RTX4080 12GB| Zotac Nvidia RTX 4080 Super Trinity black edition 10GB
Storage 1TB Dell NVME + Samsung Evo 1TB NVME|WD Blue 500GB NVME,Kingston 240GB SSD,2TB Corsair NVME
Display(s) AOC Gaming CU34G3S/BK | LG C1 65" TV
Case Alienware X16| Corsair Carbide Air 240 White
Audio Device(s) onboard/Speakers: Logitech G560 | LG Eclair QP5 soundbar
Power Supply Alienware/Dell battery + 330W charger | Corsair RMx White 750w Gold Modular
Mouse Microsoft Pro Intellimouse - White | Logitech wireless
Keyboard EPOS mechanical keyboard| Logitech wireless
Pretty much what EVGA power supply I had in my GF PC did after 5 years, replaced the power supply and all the random hard "crashes" gone.
