Post code 4d..
freeagent
10,215 (4.27/day)
Winnipeg, Canada
System Name Step_sis Rodeo
Processor AMD R9 9900X
Cooling Thermalright Aqua Elite 360 V3, 6x TL-B12 V2
Memory 2x16GB Lexar Ares @ 6000 30-36-36-68 1.35v
Storage WD SN850 1TB, SN850X 2TB, 3x SN770 1TB
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Lucky me.. got this code today with red light on CPU. Pulled out X3D and inserted 5900X, plugged everything in and 4d again.
I removed ram, swapped GPUs, CPUs. Worked great up until an hour ago.
Some google says a bunch of things, has anyone had this happen?
Some consensus says I have to RMA the board..
2,737 (1.26/day)
PNW, USA
System Name Metalia
Processor AMD Ryzen 7 5800X3D
Memory 2x32GB DDR4-3600
Seems RMAing the mobo is both generally recommended based on your troubleshooting, and specifically recommended for the symptoms.
At least 1 other reported a similar issue caused by a leaking cooling loop.
I assume in both the aforementioned case and your case, that some board-level component is damaged or 'cooked' and unreliably functioning.
IIRC, Asus' boards AM4 and AM5 both, are known to under-report and over-supply voltages. Not impossible the board cooked itself. I'd definitely give your X3D a good testing on another board (if possible).
I had a R5 5600 recently go in for RMA: I wasn't OC'd, (only on PBO) and my R5 5600 slowly lost a core out of the blue one day; I'd be concerned that there could be some inter-linked problem/CPU damage.
ir_cow
4,901 (0.81/day)
USA
If you already swapped everything but the motherboard, it's probably the motherboard.
freeagent
10,215 (4.27/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Yup she’s done.
Sad face.
Edit:
I ordered a Dark Hero. Should be here on the first I think.. Dammit.
If this one dies, then I guess no more Asus :laugh:
I will RMA my board shortly after I finish poking it with a stick :cry:
