Processor | Intel Core i7 10850K@5.2GHz |
Motherboard | AsRock Z470 Taichi |
Cooling | Corsair H115i Pro w/ Noctua NF-A14 Fans |
Memory | 32GB DDR4-3600 |
Video Card(s) | RTX 2070 Super |
Storage | 500GB SX8200 Pro + 8TB with 1TB SSD Cache |
Display(s) | Acer Nitro VG280K 4K 28" |
Case | Fractal Design Define S |
Audio Device(s) | Onboard is good enough for me |
Power Supply | eVGA SuperNOVA 1000w G3 |
Software | Windows 10 Pro x64 |
I have seem some AMD GPUs which show the lowest clocks possible, how would NVIDIA GPU look like in GPU-Z when it is completely off? Because if it has frequency it must be drawing power.It depends on the laptop and dGPU used. But most nVidia based solutions turn the dGPU almost completely off when it isn't in use, so the power draw would be effectively nothing.
System Name | Skunkworks 3.0 |
Processor | 5800x3d |
Motherboard | x570 unify |
Cooling | Noctua NH-U12A |
Memory | 32GB 3600 mhz |
Video Card(s) | asrock 6800xt challenger D |
Storage | Sabarent rocket 4.0 2TB, MX 500 2TB |
Display(s) | Asus 1440p144 27" |
Case | Old arse cooler master 932 |
Power Supply | Corsair 1200w platinum |
Mouse | *squeak* |
Keyboard | Some old office thing |
Software | Manjaro |
On mine, if the dGPU is not being used, GPU-z shows what it's max clock would be, but shows a big fat 0 for current clock speed. All the graphs are basically 0 when it isnt being used.I have seem some AMD GPUs which show the lowest clocks possible, how would NVIDIA GPU look like in GPU-Z when it is completely off? Because if it has frequency it must be drawing power.
HD 7650M shows the lowest possible clock when not in use and is not completely disabled:On mine, if the dGPU is not being used, GPU-z shows what it's max clock would be, but shows a big fat 0 for current clock speed. All the graphs are basically 0 when it isnt being used.
AMD does the same thing with enduro.
