- Oct 17, 2014
- 16,761 (4.61/day)
- Kepler-186f
this is stock CPU, latest version of HWINFO, ryzen 5600x and msi x570 tomahawk with latest bios
is this normal for Ryzen at stock settings?
System Name | ab┃ob |
Processor | 7800X3D┃5800X3D |
Motherboard | B650E PG-ITX┃X570 Impact |
Cooling | NH-U12A + T30┃AXP120-x67 |
Memory | 64GB 6400CL32┃32GB 3600CL14 |
Video Card(s) | RTX 4070 Ti Eagle┃RTX A2000 |
Storage | 8TB of SSDs┃1TB SN550 |
Case | Caselabs S3┃Lazer3D HT5 |
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
Power reporting deviation in HWInfo is only accurate under full, all-core load. This has been the case since the feature was introduced on Ryzen 3000 and continues to be true. That's the only number you need to keep an eye on. And even the degree to which the load is demanding can impact accuracy; I'd feel it's more accurate while running P95 Small than CPU-Z bench, for example.
Look for 90%+ under those circumstances. Most of the time, the value will remain high (100-200%+) while in idle or light load and only dip below 100% in heavy all-core. By default, the field will highlight a minimum value <90% in red if it falls that low, so if you're running the required workloads and it doesn't ever give you a red number in Minimum, you should be okay.
I just ran cinebench 20 multi and it read 120% furing that load. will try prime 95 small to confirm the 90ish range
No? That has nothing to do with the software reading in this two year old thread.If you are using X570 Tomahawk Then you should connect your motherboard with cpu 8pin+4pin connectors
Then you realize that the issue had been resolved, try it .
My answer is five posts above yours, posted back in 2021.So what Is your explanation
It is not for anything except all core load
