Power Supply EPS 2.91 vs EPS 2.92 What's The Difference?
869 (0.16/day)
Nairobi, Kenya
Processor Intel Core i7-14700K
Motherboard ASUS ROG STRIX Z790-H
Cooling DeepCool AK500 WH
Memory Crucial Pro 32GB Kit (16GB x 2) DDR5-5600 (CP2K16G56C46U5)
Video Card(s) Intel ARC A770 Limited Edition
Storage Solidigm P44 Pro (2TB x 2) / PNY CS3140 2TB
Display(s) Philips 32M1N5800A
Case Lian Li O11 Air Mini (White)
Power Supply Seasonic Prime Fanless Titanium 600W
Keyboard Dell KM714 Wireless
Software Windows 11 Pro x64
Anyone who knows the difference between this two standards EPS 2.91 vs EPS 2.92, and is there a higher standard, what does it help with?
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
This -
as this is an ongoing specification it seems logical that a new version will come into play, I have seen v_2.93 mooted on the www however have not been able to locate a white paper on this standard.
Maybe another member of the TPU community can confirm EPS v_2.93
atb (all the best)
Law-II
869 (0.16/day)
Nairobi, Kenya
Still floating, please explain, I have read the info but its not sinking in.... what i understand according to the document 2.92 is more beneficial to 850W and above is it?
Bo$$
Lab Extraordinaire
5,656 (0.98/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
yes only for 850w or more, it's a minor difference, just tell us which PSU you are looking at. brand is far more important than what standard it uses just because how much the quality can vary
869 (0.16/day)
Nairobi, Kenya
I'm looking at Seasonic X-660 660W and Super Flower SF-700P14XE 700W
I like the Seasonic X-660W more coz i would love a fully modular, and i currently have a FSP Everest 600W which still works and its partly modular, so i just wanted to replace it with another PSU then i keep it as a spare PSU.
There are others but i like the Seasonic X-660 and it is EPS 2.91
The Super Flower SF-700P14XE is EPS 2.92
That's why i started the thread.
Aquinus
Resident Wat-man
13,178 (2.76/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
I've built two machines recently using Seasonic PSUs, including my own, and power has never been an issue. I have the 1kw 80 plus gold for my SB-E rig which hasn't skipped a beat, makes no noise, and the runs really cool even under load. I've also used the 550-watt (it could have been the 660, but I don't think it is,) on a 2600k machine and it too runs cool, makes no noise, and hasn't skipped a beat. I can't speak for its longevity since I've only had mine for a few months and the other rig has only been around for a little over half a year, but I've heard mostly good things about them and so far they've delivered.
869 (0.16/day)
Nairobi, Kenya
So according to what you've said, the Seasonic appears to be a solid brand. Plus i selected it coz i want a silent PSU, My FSP Everest 600W is silent but i got used to it so its not that silent i want something more silent and i think the Seasonic X-660 will do.
869 (0.16/day)
Nairobi, Kenya
Thanks all for the info, I got my new PSU today from Germany already installed it, it's a Seasonic X-660 SS 80Plus Gold Fully Modular. i wont be changing it for a very long time, Seasonic Products are pretty top notch
4,114 (0.67/day)
Iowa, USA
System Name THE CUBE 2.0
Processor Intel i5 13600k
Motherboard MSI MPG Z690 EDGE DDR4
Cooling Phanteks PH-TC14PE BK 2x T30-120 Fan mod mount
Memory G.Skill TridentZ 3200 MT/s C15 32GB 2x16GB
Video Card(s) Gigabyte Aorus 1080 Ti 11GB OC: Core 2GHz, Mem 5.7GHz
Storage WD SN770 250GB / 3x WD SN850X 2TB / Toshiba X300 4TB / 2x RAID1 Toshiba P300 3TB
Display(s) Samsung 49" Odyssey OLED G95SC 240Hz 5120 x 1440
Audio Device(s) Beyerdynamic DT 880
Power Supply Corsair RM1000X
Mouse Logitech G700
Keyboard Logitech G910
Seasonic is a very good brand and they have great full modular psu's, I think they are Corsairs OEM.
Bo$$
Lab Extraordinaire
5,656 (0.98/day)
London, UK
they are awesome! glad you went for a 80+ gold PSU, will save you a little bit of cash and some heat in the long run :)
Aquinus
Resident Wat-man
13,178 (2.76/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
That is the conclusion that I came to. My 1000-watt 80-plus platinum barely makes any heat and the fan barely has to come on, even under full load. Can't ask for anything better than that. :toast:
