Power Supply for 160$
5 (0.13/day)
System Name MyPC
Processor Ryzen5 7600
Motherboard MSI B650 Gaming Plus Wifi
Cooling Endorfy Fera 5
Memory 2x16GB Lexar Ares 6000MHz CL30
Video Card(s) RX 7800XT Sapphire Nitro+
Storage 1.Kingston KC3000 2TB 2.Lexar NM790 1TB
Case Silver Monkey X Chest TGM
Mouse Razer DeathAdder Elite
Keyboard Krux Atax Pro RGB Gateron Red
Hello. I’m in need to upgrade the PSU of my PC and I looked a lot at this site and others, but there is so much good looking options that I cannot choose one. I’m looking for 850W PSU under 160 bucks. About requirements, all I want it to be is modularity. So can be RGB, no RGB, like whatever. There are my options for now with prices below from lowest to highest, if someone would help me I would be glad:
-Cooler Master MWE GOLD V2(123$)
-FSP/Fortron VITA GM 850W(131$)
-NZXT C850 V2(144$)
-Thermaltake Toughpower GF 850W(144$)
-MSI MPG A850G(154$)
-XPG Core Reactor II 850W(157$)
I do not require high level of silence, just not something completely over the top. It will power Ryzen5 7600 and 7800XT for now with later on propably getting 8900XT or whatever it will be called. Also RMx Shift and Super Flowers which I saw highly rated here(Poland) are much more expensive, like 200 bucks. I am also opened to any other options you guys suggest and I would be happy with any help I can get.
18,585 (2.71/day)
System Name AlderLake
How about a Be Quiet! Straight Power 12 850W Platinum.
5 (0.13/day)
System Name MyPC
6,232 (4.53/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
Between these I would probably go with the MWE Gold, it's a budget-minded power supply but it should do the trick and is cheaper than the other models.
436 (0.11/day)
Midlands, UK
System Name Electra III
Processor AMD Ryzen 5 3600 @ 4.40 GHz (1.3 V)
Motherboard ASUS PRIME X570-PRO with BIOS 5003
Cooling Cooler Master Hyper 212 EVO V1 + 4× ARCTIC P12 PWM
Memory 32 GiB Kingston FURY Renegade RGB (DDR4-3600 16-20-20-39)
Video Card(s) PowerColor Fighter RX 6700 XT with Adrenalin 24.7.1
Storage 1 TiB Samsung 970 EVO Plus + 4 TB WD Red Pro
Display(s) Dell G3223Q + Samsung U28R550Q + HP 22w
Case Fractal Design Focus G (Black)
Audio Device(s) Realtek HD Audio S1220A
Power Supply EVGA SuperNOVA G3 750 W
Mouse Logitech G502 X Lightspeed + Logitech MX Master 2S
Keyboard MSI VIGOR GK71 SONIC Blue
Software Windows 10 22H2 Pro x64
Benchmark Scores CPU-Z = 542/4,479 — R15 = 212/1,741 — R20 = 510/3,980 — PM 10 = 2,784/19,911 — GB 5 = 1,316/7,564
-NZXT C850 V2(144$)
The SeaSonic FOCUS PLUS is $160 on Amazon. That is the one you want.
31 (0.10/day)
System Name Home workhorse-gaming
Processor Intel 13600KF @ 5400/4200
Motherboard Asus ROG Strix Z790A Gaming WiFi
Cooling Arctic Freezer 2 rev.7 360mm
Memory 2x16 Kingston Fury Renegade Silver RGB DDR6400@XMP settings - 32-39-39-80
Video Card(s) Palit GamePro 3080Ti with Alphacool Eiswolf 2 360 mm
Storage NVME, WD 550 Blue 1 TB (gen.3), Samsung 980 1 TB (gen.3), Kingston KC3000 2 TB (gen.4)
Display(s) Samsung Odyssey G5 LS27AG500NUXEN (IPS, flat), @120Hz, 10 bit color (165Hz@8 bit)
Case Corsair 5000D Airflow, 4xArctic Bionix P120
Audio Device(s) Creative Sound BlasterX AE5 Plus, Creative T580 boxes, Soundheiser HD569
Power Supply Seasonic Focus GX 850W Gold
Mouse Razer Basilisk V3 Chroma
Keyboard Asus TUF Gaming K3
VR HMD none
Software W11 pro
Benchmark Scores https://hwbot.org/xtu2/analyze/5404795?recalculate=true
Don't be cheap on the power supply! From my experience I'd go with Seasonic, Floston or Super Flower directly.
5 (0.13/day)
System Name MyPC
Is Focus GX 850 an option? Focus Plus is not really available in Poland.
I mean isn't brand generalization bad in PSU's? I heard that early Gigabyte PSUs were absolutely awful and now they have some solid models, while Seasonic while being overall really good, had some stinkers or at least mid options.
I did check this site out, but the amount of things here to check is just crazy, that's why I narrowed it to these 6. Also I saw this list is based on HWBusters tests and all of those are rather high on their list, while VITA GM review by him say he will add it to the best 850W ATX 3.x PSU list.
FreedomEclipse
~Technological Technocrat~
23,898 (3.75/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
12,891 (1.94/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Cannot find anything on an 8900 XT. Looks like it will be 8900 XTX.
Well, I note 850W may well be over the top.
Do you really need a new PSU right now? If not, and if you are sure you will be upgrading to the 8900 XTX, then I recommend you wait until more information about the 8900 XTX comes out and we learn more about its power requirements.
^^^THIS^^^
If you can wait until we learn more about the system requirements of the 8900 XTX, you might learn that, for YOUR system (your CPU, you RAM, your drives, your cooling plus the 8900 XTX) you my discover you can easily do with a 750W (or even less) PSU. And odds are and careful homework, you can buy a top quality 750W supply for the same money (or less) than a not quite at the top 850W supply.
To make sure you size the supply correctly and so we know what hardware we are talking about , please fill out your TPU System Specs.
The right way to determine the proper power supply size you need is to research all the components individually (motherboard, CPU, graphics, type and number of RAM sticks, type and number of drives, cooling devices and each connected USB device), determine their maximum power demand. Add those values up to get the minimum size supply you should get. But that takes a lot of time and work. So I recommend using a good PSU calculator and the best and only one I use and recommend is the eXtreme OuterVision PSU Calculator. This will calculate your minimum needs and recommend a suitable size for those needs. It will also recommend a suitable size UPS! :)
Plug in all your components. Be sure to plan ahead and include all the hardware you think you might add in 2 or 3 years (extra drives, bigger or second video card, more RAM, etc.).
While not necessary, I generally recommend setting CPU utilization to 100% and Computer Utilization Time to 16 hours per day. These settings will help compensate for component aging, and add a little extra padding to the results. This typically results in a little cooler and quieter operation. I hate fan noise :mad: so quieter is always better in my book, as long as adequate cooling is not compromised.
Note that no calculator wants to recommend a PSU that is underpowered so they all pad the results, some more than others. Graphics card recommendations and the calculators provided by the PSU makers tend to pad the results more than non-affiliated calculators. PSU makers have the added incentive to recommend larger supplies for bigger profit margins.
The eXtreme OuterVision calculator is independent of those manufacturers and the most conservative. And that's a good thing! This occurs because it is the most flexible and has the most extensive databases of available options you can enter. This allows it to factor in all possible components to much more accurately (and realistically) calculate our needs, rather than guess and assume and add even more padding to ensure they never underestimate.
I note the 8900 XTX is not yet in their databases but you can be sure it will be soon.
It won't hurt anything if you go "over the top" except your budget. But when budgets are limited, it makes sense to spend it wisely and buy what you "need" and not more than you need.
436 (0.11/day)
Midlands, UK
It absolutely is. It is only slightly inferior than the PLUS version. Still a brilliant unit.
dgianstefani
TPU Proofreader
4,915 (1.99/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus Block, HWLABS Copper 240/40 + 240/30, D5/Res, 4x Noctua A12x25, 2x A4x10, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+, TOFU-R CNC Alu/Brass, SS Prismcaps W, Jellykey, Lube/Mod, TLabs Leath/Suede Wristrest
Software Windows 10 IoT Enterprise LTSC 19044.4046
Benchmark Scores Legendary
Get a ATX 3/3.1 variant.
Don't skimp on PSU it's a 10 year part and directly affects lifespan and performance of everything connected to it, plus mediates amount of heat in case. If difference between mediocre and good is $160 to $200, get the $200 model.
6,232 (4.53/day)
São Paulo, Brazil
The XT is just the scaled down model for people who want a flagship but can't pay for one. This generation, the XTX and XT were 10% in price and 15% apart in performance. A really, really bad deal, unless purchased on a sale with an appropriate discount.
Also at this point in time, everything and anything about RDNA 4 is to be considered purely speculative. I don't think anything is final, we just have MLID "leaks" to go by and the fact that AMD seems to have admitted early on that it will not be competitive with Nvidia's Blackwell microarchitecture in performance and that this is not their aim with this particular generation. It'll be Intel's Battlemage vs. RDNA 4, with the GeForce cards being positioned as a premium alternative.
Yeah, I agree with this. That MWE V2 is a decent power supply on a budget, though, and it looks like OP wants an all-AMD system with RDNA 4 in mind. Unless that thing is an indescribable flop, I think it'll be on the power efficient side, given it's not really going to be developed for all-out performance.
18,585 (2.71/day)
dgianstefani
TPU Proofreader
4,915 (1.99/day)
Swansea, Wales
System Name Silent
It's irrelevant if OP wants AMD or NVIDIA, both are going to be using the 12V-2x6 connector.
4,989 (3.86/day)
Colorado, U.S.A.
There seem to be some 'renewed' power supplies on amazon
12,891 (1.94/day)
Nebraska, USA
Mouse Logitech M190
Yeah, I understand their normal naming conventions. I am just saying as of right now, these cards do not appear to be on the market - yet.
Yeah. But there is no way of knowing what that really means. It could have been returned because it was the wrong color. They just cannot resell it has new.
22,035 (6.01/day)
Mouse XTRFY M42
Get 850W to be safe but pre buying is also locking yourself into a purchase. Nobody knows what these gpus will require.
5 (0.13/day)
System Name MyPC
^^^THIS^^^
About the ,,do I need new one" Well, my current PSU is about 10 years old and it is not any good brand, it's 700W Plus Bronze. So I kinda feel like I am sitting on a time bomb, even with my R5 7600 for now.
Also I just added my PC build do the TPU as I am a newbie and didn't know there was this section, so thank youa and did the thing with the PSU calculator and with 7900XT as for now it shows 555W and I thing I added everything I would need. So with this, should I maybe move to better tier of 750W PSU's?
12,891 (1.94/day)
Nebraska, USA
Mouse Logitech M190
Sure.
That said, while 10 years old is pretty old, that does not mean it is about to fail. If your computer is not having unexplained problems now, like sudden reboots, freezes, or shutdowns, and if you are planning on upgrading your graphics card in the future, if me, I would buy both a new PSU and card at the same time. That way I can be sure I am getting the supply my card (and the rest of my hardware) needs.
436 (0.11/day)
Midlands, UK
The 750 W version of the FOCUS GX is 448 zl.
131 (0.10/day)
System Name Upgraded CyberpowerPC Ultra 5 Elite Gaming PC
Processor AMD Ryzen 7 5800X3D
Motherboard MSI B450M Pro-VDH Plus
Memory CM4X8GD3000C16K4D (OC to CL14)
Video Card(s) XFX Speedster MERC RX 7800 XT
Storage TCSunbow X3 1TB, ADATA SU630 240GB, Seagate BarraCuda ST2000DM008 2TB
Display(s) AOC Agon AG241QX 1440p 144Hz
Case Cooler Master MasterBox MB520 (CyberpowerPC variant)
Power Supply 600W Cooler Master
Most leaks indicate that there won't be any high-end RX 8000-series GPUs at all.
The fastest is likely to be something called either RX 8800 XT or RX 8800 XTX, and is expected to be slower than the RX 7900 XTX.
31 (0.10/day)
VR HMD none
Software W11 pro
Yes, Focus GX is an option (check my rig). On the brand generalization - I meant quality power supplies, not those in the 30-40$.
Cale
2 (0.05/day)
Corsair RMx on Amazon, 850W is $115.
In-cable capacitors tho if you care about that.
146 (2.12/day)
