Power supply for geforce RTX Ampere
475 (0.20/day)
Jakarta, Indonesia
System Name PC-GX1
Processor i9 10900 non K (stock) TDP 65w
Motherboard asrock b560 steel legend | Realtek ALC897
Cooling cooler master hyper 2x12 LED turbo argb | 5x12cm fan rgb intake | 3x12cm fan rgb exhaust
Memory corsair vengeance LPX 2x32gb ddr4 3600mhz
Video Card(s) MSI RTX 3080 10GB Gaming Z Trio LHR TDP 370w| 566.36 WHQL | MSI AB v4.65 | RTSS v7.36
Storage NVME 2+2TB gen3| SSD 4TB sata3 | 1+2TB 7200rpm sata3| 4+4+5TB USB3 (optional)
Display(s) AOC U34P2C (IPS panel, 3440x1440 75hz) + speaker 5W*2 | APC BX1100CI MS (660w)
Case lianli lancool 2 mesh RGB windows - white edition | 1x dvd-RW usb 3.0 (optional)
Audio Device(s) Nakamichi soundstation8w 2.1 100W RMS | Simbadda CST 9000N+ 2.1 352W RMS
Power Supply seasonic focus gx-850w 80+ gold - white edition 2021 | APC BX2200MI MS (1200w)
Mouse steelseries sensei ten | logitech g440
Keyboard steelseries apex 5 | steelseries QCK prism cloth XL | steelseries arctis 5
VR HMD -
Software dvd win 10 home 64bit oem + full update 22H2
Benchmark Scores -
Are my new PSU still good enough for all version of RTX 3070 ti 8gb or RTX 3080 10gb or RTX 3080 ti 12gb.... ??
because in the future, I want to install a 3rd hdd external usb 3.0, 1st or a 2nd SSD sata3, a 5th 1x12cm fan case rgb.....
EDIT: will the second low profile dual channel RAM, which will be attached to my motherboard, clash with my CPU cooler.....??
3,381 (0.48/day)
Canada
System Name PCGR
Processor 12400f
Cooling Stock Intel Cooler
Video Card(s) Dell RTX 3080
Display(s) LG 32" 1440p
Case Phanteks Evolve itx
Seasonic psu? Yeah, should be perfectly fine.
620 (0.39/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
That PSU absolutely. The disks don’t consume the amount of energy shown by the PSU calculators.
43,265 (6.74/day)
You have an excellent PSU,
(SeaSonic or SuperFlower as OEM is great)
Here you go, look for specifications and ram clearances.
475 (0.20/day)
Jakarta, Indonesia
System Name PC-GX1
VR HMD -
Benchmark Scores -
i am asking like this, because i am very very concerned about nvidia rtx ampere 3070 8gb - 3090 24gb has spike power consumption, something like this....
https://www.reddit.com/r/hardware/comments/k5lgm4
so, even if i can using a gpu, such as, galax rtx 3080 ti 12gb SG OC or gainward rtx 3080 ti 12gb phoenix on my PC, is that my PSU is still have plenty room for another fan case 1x12cm rgb, a new 1 or 2 SSD sata3, also an external hdd usb3 ..... ??
about that the thread of cpu cooler master and RAM, i am so so sorry...... but, so my cpu cooler can still not clash with 2nd RAM dual channel low profile ....... ??
9,629 (3.28/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Hard to tell, a 3070 ti will be fine but a 3080 ti will use almost as much power as a 3090.
475 (0.20/day)
Jakarta, Indonesia
System Name PC-GX1
VR HMD -
Benchmark Scores -
but, single gpu, such as, asus rtx 3080 10gb TUF OC or MSI rtx 3080 10gb x trio, is still fine too ?? just like if i am using rtx 3070 ti 8gb series......... ??
4,628 (0.75/day)
where everyone wants to be
System Name Everchanging
Processor AMD Ryzen 9 5900X
Motherboard ASUS ROG Crosshair Dark Hero
Cooling Arctic Cooling Liquid Freezer 2 420mm
Memory 2x16GB Corsair DDR4 3600 CL16
Video Card(s) eVGA RTX 3090 Ti FTW3
Storage Samsung 980 Pro 256GB, Samsung 980 Pro 2TB
Display(s) 2xSamsung 28" 4k HDR 144Hz
Case Fractal Meshify 2 XL
Audio Device(s) fiio K9 to Hifiman Sundara's via 4.4mm balanced cable
Power Supply Seasonic Prime TX 850w
Keyboard Corsair K70 RGB PRO
Software Windows 11 x64
Your best bet, if the funds are available to you, get the card to start, and play games, or do whatever you will being to load up the system like crazy for a week or 2, and see if you have the same issues, then decide if you need to upgrade the PSU. One thing to note about that bit you posted, the person doesn't specifically state what the games they were playing were when they saw the crashes, if they had their CPU OCed, and other system specs. One thing to note if they OCed that 10900k heavily, but you don't OC your 10900, you might not have the same issues as your CPU will likely use less power.
475 (0.20/day)
Jakarta, Indonesia
System Name PC-GX1
VR HMD -
Benchmark Scores -
this review....
eventhough that card is using 2x8pin or 3x8pin, but they are still recommended PSU 750-850w.....
Transients and power supply recommendation
As I have already proved in detail in my basic article “The battle of graphics card against power supply – power consumption and load peaks demystified”, there are also higher loads in the millisecond range, which can lead to unexplainable shutdowns in the case of unfavorably designed or improperly equipped power supplies. The TBP (Typical Board Power) measured by the graphics card manufacturer or the reviewers alone does not really help in this case for a stable system design.
Peaks with intervals between 1 and 10 ms can lead to shutdowns in very fast reacting protective circuits (OPP, OCP), especially in multi-rail power supplies, although the average power consumption is still within the standard. For this card, I would therefore calculate at least 430 to 450 watts as graphics card load for the normal OC, proportionally to the total secondary power consumption of the system, in order to have enough reserves for the worst case scenario. A short excerpt with higher resolution shows us now the 20 ms measurements (10 μS intervals), as I let them run automatically for value determination:
*** its still very very scary......
1,533 (0.39/day)
Grunn
System Name Indis the Fair (cursed edition)
Processor 11900k 5.1/4.9 undervolted.
Motherboard MSI Z590 Unify-X
Cooling Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans
Memory G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v)
Video Card(s) EVGA 2080 Super Hybrid (T30-120 fan)
Storage 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB
Display(s) BenQ XL2546K, Dell P2417H
Case FD Define 7
Audio Device(s) DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5
Power Supply Seasonic 860w Platinum
Mouse Razer Viper Mini, Odin Infinity mousepad
Keyboard GMMK Fullsize v2 (Boba U4Ts)
Software Win10 x64/Win7 x64/Ubuntu
tldr GPUs need better input filtering (x
475 (0.20/day)
Jakarta, Indonesia
System Name PC-GX1
VR HMD -
Benchmark Scores -
well, now, i am confused..... inno rtx 3080 10gb ichill x4 HLR, msi rtx 3080 10gb gaming z trio LHR, gainward/palit rtx 3080 ti 12gb gaming pro...... which is more safe for my psu..... ??
23,011 (6.08/day)
850w for a single GPU should be very much fine. Your CPU is a non-K, as well. I wouldn't worry.
2,975 (2.05/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
since it's not a garbage PSU a mid tier version of a 3090 is totally fine.
a high end one like a strix OC or FTW3 Ultra with the XOC Bios is a big no. (they pull 500W+ non stop with transients higher than the total wattage of your PSU)
475 (0.20/day)
Jakarta, Indonesia
System Name PC-GX1
VR HMD -
Benchmark Scores -
alright, i will avoid all version of msi suprim x, asus strix oc, evga FTW, GBT aourus extreme from rtx 3080 10gb or rtx 3080 ti 12gb......
43,265 (6.74/day)
Just get a Sapphire 6800/6800XT...
7,447 (3.20/day)
California
System Name His & Hers
Storage lots of SSD.
I haven't had any shutdowns with my 3080 ti and a Seasonic Ultra Prime Ti 850w with the power limits maxed and it hitting north of 450w. My 5800X and soon to be 5950X use a lot less power than your 10900 although gaming wattage should be similar..... That being said the gaming X trio might be a good option for you the power limit is set to like 380w or if you just stick to the stock power limits on the ftw 3 or strix.....
Other than if you water cool or buy one with a 240/360 aio there really isn't any reason to raise the power limits even maxed out the difference is 2-3% even with my gpu never going over 70c.
475 (0.20/day)
Jakarta, Indonesia
System Name PC-GX1
VR HMD -
Benchmark Scores -
i am sorry, because i had very bad experience about radeon vga in the past..... so, right now , also in the future, i will skip those vga from radeon......
what, my cpu TDP is only 65 watt when playing borderlands 3........
anyway, my OS is should be upgrade to update 21h1 or not ?? just for playing pc games......
43,265 (6.74/day)
Nv has its fair share of problems , i just told you to get the second best AMD card around.
I had a geforce once, switched to ATi and never looked back.
Its your loss for the billion questions, i gave a simple solution.
My 1250 XM2 Gold is still flawless
Also its unheard of a game killing a gpu, reminds me of detonator drivers and sudden error 43s on gf gpus.
freeagent
9,458 (4.07/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
So Ampere for sure is the new Fermi? Any future outlook on nextgen TDP? 550w on a card stock or overclocked is crazy man wtflol. That is serious business. I am sort of glad I haven't been able to get one.. questioning whether I want one :D
7,447 (3.20/day)
California
It actually reminds me more of Hawaii.... 7000 series from AMD only the cards tend to be much better built. My Sapphire Vapor X 7970s were worse than my ftw blower 680s for example thermally.....
My 3080 ti hits around 68-70c so thermals are fine regardless of the wattage used.
My guess is future high end cards will also be high wattage a side effect of both companies being competitive in rasterization.
Mussels
Freshwater Moderator
58,413 (7.88/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
A 750W has heaps of room for me with a 3090, you'd just need 100W more since you have a hungry hungry hippo... i mean intel.
I dont think my systems gone over 550W, with everything balls to the wall
the only people seeing stupid wattages are the people with crossflashed unlimited powah BIOS
475 (0.20/day)
Jakarta, Indonesia
System Name PC-GX1
VR HMD -
Benchmark Scores -
alright, so my PSU is still very safe to handle single rtx 3080 10gb or rtx 3080 ti 12gb (except if that vga has 3x8pin and has requirement of psu 850w) .... ???
freeagent
9,458 (4.07/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
That was a solid reply!
I am kicking myself for getting a 750.. but at the time it was pretty much all I could get.
Edit:
Ther was a couple of 850s but a hundreds.. not really much of a game changer.
Mussels
58,413 (7.88/day)
Oystralia
I think i agree that if its got the 3x 8 pin, you'd want an 850W
Your CPU is hungrier than mine, but its not a K so it has somewhat reasonable limits
The 3080 is a good bit less than the 3090, cause the 14GB of extra VRAM sure chews through some power on its own
475 (0.20/day)
Jakarta, Indonesia
System Name PC-GX1
VR HMD -
Benchmark Scores -
after sometime, i choose to buy this vga....
eventhough, that vga has 3x8pin, but the recommended requirement of PSU is only 750 watt, also in the review, that vga has average 470 watt when full load......
but, right now..... how iam going to used the cables ??
3 cables 8 pin or 2 cables with 1 pig tail ??
also, my OS is should be upgrade to update 21h1 or not ?? just for playing pc games and watch the movies......
