Power supply or motherboard
ArekkusuJG
5 (5.00/day)
Good morning guys i have a question. So today i turn on pc and played game for like 10min after that my pc shutdown i tried to turn it back on but nothing happend. Also i do have a RGB keyboard, mouse,headset and when it shut down i could see that nothing is glowing so my question is, does anyone know where is problem i heard that it can be motherborad but also can be a power supply, anyway i tried everything that i could think of,trying YouTube, Google etc... but nothing helps,so if someone know whats problem please tell me. Thanks in advance
Sorry if it isn't motherboard but i posted here, i dont know whats causing that problem
Specs:
Asus prime 320m-k
Amd Ryzen 5 2600 3.4 - 3.9ghz
Amd rx 590 8gb ddr5 256bit
Kingston fury beast ddr4 16gb
Fsp hyperK 500w
405 (2.81/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
It could be all kinds of things. Start by filling out your system specs so we know what you are working with.
Motherboard and PSU are certainly possibilities. First thing I would do is give a good visual inspection. Make sure everything is properly seated/plugged in, and check for visible signs of damage.
Next, remove all non-essential peripherals.
ArekkusuJG
5 (5.00/day)
Thanks for answering i havent touched anything for almost a 2months so i dont think that something wasn't plugged right atleast, i was trying to smell something when that happend but nothing,no smells,no warning nor even a sound. I am trying to figure out if it is motherboard or power supply so i can change it but i dont want to risk and change something that didn't cause the problem.
Specs are
Asus prime 320m-k
Fsp hyperK 500w
405 (2.81/day)
Texas, USA
Still, a good idea to disconnect from power and re-seat everything. No smells or warning doesn't mean something didn't go kaput.
You may want to disassemble and place everything on a non-conductive surface and try it out of case, without storage or anything except MB/cpu/ram/psu/and gpu....just to see if it will fire up.
After that, i'd try another power supply. 500w is adequate, but still working that psu a bit harder than I like, and that is one of FSP lower-grade power supplies.
605 (0.12/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
First step in troubleshooting is K.I.S.S
Has the system been moved or otherwise disturbed? Something could have become unseated ever so slightly if so.
Does your motherboard have any sort of speaker attached to listen for beep codes? If so, pull all of the RAM out and it should start beeping like crazy.
I would certainly do what @DirtyDingusMcgee recommended. I have used the motherboard box to setup on and used a small flat head screwdriver to jump the Power SW pins.
42,993 (6.72/day)
21,594 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
Go get a power supply
Depending on what brand the previous PSU was (we have no idea of that or anything really) I am inclined to lean that way too.
42,993 (6.72/day)
Easier to get that for troubleshooting than just guessing at that rate, otherwise a shop can tell person, now other thing could ge bad is the electricity source from the power strip to the substation and power plant
21,594 (3.40/day)
System Name Pioneer
Yeah, or there's a short somewhere etc. I agree its way better to get info before guessing.
ArekkusuJG
5 (5.00/day)
I did disconnect everything and connected it back, expect gpu cuz its little bit complicated for me and same pressing power button nothing happens.
I was trying to do paper clip test and fan doesnt spin so ill try with new power supply and will se whats gonna happen cuz i heard they last from 2 to 5years
Hi, no it doesnt not have any sort of speaker, is it safe to power jump it with screwdriver tho? Im gonna try it
Its pc like 8years old and still have,has the same psu
Ill probably take it to shop so they can test psu and else and then ill know which should i change
So first I'll get it to some shop so they can test psu cuz i think its up to it but not quiet sure i dont want to change psu and at end gonna be motherborad,so yea anyway ill keep you updated what happened
Check power cord first and circuit breaker. Check surge protector or UPS if you have one. Check if anything is glowing inside the computer case - many modern components have leds.
21,594 (3.40/day)
System Name Pioneer
Then I certainly lean towards it being the psu but the shop should be able to tell you for sure.
2,064 (0.64/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
Unlikely, but power button on case is a possibility. Tests already suggested would isolate failure there.
freeagent
9,210 (3.99/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Just touch the 2 pins with the screwdriver, don't drag the driver all over the board hoping to find an arc, just those two pins.
1,689 (1.08/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
I am kinda scared to jump start motherboard with screwdriver, is it safe i wont ruin it?
You could use a spare jumper instead, but don't leave it on. When you've just removed the power connector, it'll be clear which two exact pins you need to short.
2,064 (0.64/day)
Storage 1TB 980 Pro
Software W11 Pro
So let me update ya all since you helped me, power supply is dead thats why it doesnt turn on
Buy a good quality psu with a good warranty. Look at the power needs of a potential newer system you would consider owning to determine wattage. 750w-850w is probably realistic and would have a wide range of options.
Buy a new psu from somewhere with a good return policy. If mobo or gpu no longer turn on you might wish to reassess your options without spending any money at this point.
