Power supply radio noise
5,161 (3.75/day)
Colorado, U.S.A.
Software Windows 11 Home
Do they cover radio noise for computer power supplies? is it part of the ATX spec?
13,356 (1.99/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
42,679 (6.68/day)
FCC part 15, spreadspectrum was created for that reason, not sure if it can be disabled as i dont see motherboards with a setting to switch it off now
They put metal beads on some cords to prevent emi
13,356 (1.99/day)
Nebraska, USA
Mouse Logitech M190
There are also 1000 finger tines surrounding every port on the rear I/O shield for the motherboard where it mates with the case, plus about a dozen grounding points where motherboards mount to the case, plus at least one, typically several grounds in every power and data cable, plus every expansion card, the PSU and most other add-ons have multiple grounding points to, among other reasons, either block incoming EMI/RFI from other nearby electronics or to suppress outgoing EMI/RFI from interfering with other nearby electronics.
Then as eidairaman1 notes beads, chokes and other solutions are added to help too.
5,161 (3.75/day)
Colorado, U.S.A.
I'm concerned with radio being sent back out of the mains cable where ferrite chokes are not common.
13,356 (1.99/day)
Nebraska, USA
Mouse Logitech M190
Sent back out and do what? First off, it would just be switching "chatter", if anything. It would not contain any "intelligence" (data).
Second, let's point out that EMI/RFI suppression is NOT, by any means, just an ATX requirement. There are all sorts of even stricter UL, FCC, DIN and a whole host of other international regulatory agencies that govern the amount of EMI/RFI leakage allowed - and for sure, it is miniscule so it does not interfere with your own TV in the same room, let alone your neighbors electronics interfering with yours.
If your PSU has not been dropped kicked down the stairs - twice - you should not need to be fussing over EMI/RFI emissions getting out, or in.
134 (0.15/day)
What are we talking here?
Are you afraid to ruin grandpas radio signal?
Are you afraid that your pc can be tracked at the front line?
42,679 (6.68/day)
Yeah i know about the tangs on the io shield, all for bonding
5,161 (3.75/day)
Colorado, U.S.A.
I have a cheap PC power supply that seems to lack X/Y capacitors at the input.
42,679 (6.68/day)
Ok any provisions to add them?
5,161 (3.75/day)
Colorado, U.S.A.
Looks like that is possible.
13,356 (1.99/day)
Nebraska, USA
Mouse Logitech M190
Not sure what you mean by "bonding". Definitely they are for grounding and shielding. That's why that little rectangular piece of metal that inserts into the case is called a shield.
Got a model number? I note even the cheapest of the cheap MUST comply with the various regulations dictated by the FCC, UL and other agencies if the product is to be sold (even imported) into the US. I assume the EU and other jurisdictions that care about interference into their local emergency services, military and commercial services have similar laws and regulations.
5,161 (3.75/day)
Colorado, U.S.A.
Apevia ATX-PR600W Prestige 600W
3,615 (2.49/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
If that's true then it lacks filter coils too.
5,161 (3.75/day)
Colorado, U.S.A.
HAM radio interference
13,356 (1.99/day)
Nebraska, USA
Mouse Logitech M190
It has the FCC and CE logos. That's good enough for me. Now again, that assumes the PSU has not been physically damaged, has a factory defect, or is counterfeit.
As far as HAM radio, as a radio technician for the USAF, I used to be in charge of the maintenance at 2 different MARS stations. So I know a little about RFI and HF radio. This is pretty easy to check out here. If you hear a buzz in your headsets, unplug the computer PSU from the wall. If the buzz goes away, the PSU is a problem. If the buzz remains, something else is.
42,679 (6.68/day)
A definition of bonding
The io shield makes contact with the chassis, like the mobo does with the standoffs and the pci cards do with the mounting bracket, the psu makes contact with the chassis and that is the only component directly attached to ground.
13,356 (1.99/day)
Nebraska, USA
Mouse Logitech M190
That is what I thought you meant by bonding - but not sure. Some refer to bonding as a chemical or thermal "bond" of two or more materials - similar to welding two metals.
42,679 (6.68/day)
Landing gear is bonded on an aircraft so that way it doesn't become an antenna itself or build up static charge which can be lethal to a person if they are hit with it right, in a way think of electrical engineers requiring an arc flash suit. Avionics computers are bonded as well.
Heck my truck has 4 bonds for the engine itself due to the efi and ignition system, that doesn't include the sensors using the block as a bond. 1 for the hood, and not sure how many for the cab or fuel pump or transmission. Spark plug wires are spiraled internally so they don't become antennas like a solid core wire does.
5,161 (3.75/day)
Colorado, U.S.A.
42,679 (6.68/day)
Didn't know that.
This lesson was learned in aviation during the use of the otto cycle engine, before the advent of the brayton cycle engine, you don't want stuff interfering with radios and other navaids for use in ifr.
In Bayton Cycle engines you have a he igniter which can kill you like a microwave or a crt, or a pc psu, or radar equipment/high energy radio transmitters.
Ottocycle engines are primarily in the General Aviation category.
5,161 (3.75/day)
Colorado, U.S.A.
500 Ω per foot, no wonder this is only used for spark plug wires.
How recent is this innovation? I don't recall it in cars 40 years ago.
