Power Supply temperature rating
4,858 (3.87/day)
Colorado, U.S.A.
Software Windows 11 Home
I found it interesting that the rated temperature varies with power (within the same series)
  • The 430W model is rated for 50°C
  • The 500W model is rated for 40°C
  • The 600W model is not rated for temperature
4,280 (0.88/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
different OEMs? Also the 430w has 430w in the copy but is labeled as 400w in the headline.
4,858 (3.87/day)
Colorado, U.S.A.
Yes, it is confusing, I went with 430W as that is what is on the case.
The identical case made me think it was the same platform (HEC for the 500W)
4,280 (0.88/day)
the 430w was made by HEC and no way it was 50c rated. I highly doubt that 400w is 50c rated, in fact that spec chart is from the HEC made 430w unit which wasn't all that great. It's lazy marketing on EVGA part and too many OEMs for unit procurement that probably overwhelmed them.
*edit, @Shrek if you go to the EVGA web site so you can see the word better it says "all load and regulation testing done at 50c" not that it is "rated for 50c".
4,858 (3.87/day)
Colorado, U.S.A.
The 500W unit (the one I have) blows up on full load; there is an ebay auction for 7 such units (all bust)
as you already know from the thread I made on doubling the number of bridge rectifiers.
Disclaimer: do not mess with power supplies as the main capacitors can carry a lethal charge even when the supply is not plugged in.
4,280 (0.88/day)
4,858 (3.87/day)
Colorado, U.S.A.
I got the supply cheap and added a second bridge rectifier (as a match pair), so will throw caution to the wind.
12,711 (1.92/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
The 400 model is not 80 PLUS certified so it make me wonder if they really are in the same series.
915 (3.20/day)
Nowhere
Processor 14700K
Motherboard Asus Strix B660-G (clock gen)
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Almost all Power supplies are rated 40c to 50c max operating temperature.
If it's not listed, probably best to assume 40c max.
12,711 (1.92/day)
Nebraska, USA
Mouse Logitech M190
"Almost" being the key word there. I note these are budget/entry level models. There are some PSUs rated less than 40°C so I would not assume anything if not published. It is my experienced if an important spec it not published, that means the actual value achieved by that device is nothing the makers are proud of - or else they (their marketing weenies) would hype it up.
That said, it should be noted this spec if for the ambient (room or inside the CPU case) temperature. In other words, the temperature of the air at the intake of the supply. 30°C (86°C) is not what I would consider a comfortable room temp. That said, 30°C rating should not be considered as "bad" (with all else equal), with a properly cooled case in a "normal" ambient temperature room. We must also consider that spec also implies the supply is operating at maximum load 24/7 in those thermal conditions - and that is not a normal scenario for the vast majority of home, office, or TPU users.
Still, if rated at 40°C, that would certainly suggest the PSU is more capable and if rated at 50°C, more capable still.
