- Jan 28, 2006
- 710 (0.10/day)
- Cali
Hey everyone long time no posts,
I just have encountered an issue with my power supply/computer today and cant really put my finger on the problem and fix it without some clarification. First off I was cleaning the whole system out today, getting rid of dust and taking fans out etc. I was using a shop vac to suck the dust off the motherboard and fans and the power supply. I guess I must have held the vacuum to long over the fans on the power supply and induced some voltage from spinning the fans or from static electricity. Because when I reassembled the computer and flipped the PSU Switch nothing happened, then it made a high frequency noise and then a fan light flashed. After that I figured all systems go, so i pressed the power button and nothing happened at all.
So after that I figure that its toast and ill try a reserve 300w psu (a 120w downgrade from my thermaltake 420w psu). I didnt connect hardly any fans but did connect my 3 hard drives and motherboard along with vid card and dvd drive, lol. It booted up just fine and went into windows 7 and it started to recognize all my accessories and hdd's. Then I go to plug my joy stick it in about 1 minute after that and boom, it shut off to a high frequency noise and no power to the computer at all. Probably from lack of power i assume.
So my question is, Did I fry just my power supply or did I fry something major? Thanks for reading my post
