Power usage iGPU AMD7800x3D
35 (0.01/day)
System Name CyberDyne Systems
Processor AMD 7800X3D
Motherboard Asus ROG STRIX B650E-E Wifi
Cooling Alphacool Eisbaer Aurora HPE 360 mm
Memory 32 GB G Skill Flare X5 F5-6000J3038F16GX2-FX5
Video Card(s) Nvidia 4090FE
Storage WD Black SN850X 1 TB, WD Black SN850X HS 2 TB, WD Black SN770 2 TB
Display(s) Alienware AW3821DW 3840x1600 144 Hz
Case ThermalTake Core P3 TG Pro
Audio Device(s) Onboard Realtek ALC4080 Corsair SP2500
Power Supply Asus Thor II 1000W
Mouse Razer Viper Ultimate CyberPunk 2077
Keyboard Corsair K65 LUX RGB
Software Win11 Pro
For my setup see my system specs.
As you can see the PSU of my system is an Asus Thor II. This PSU has a screen which shows the current powerdraw of the system.
My system also has 2 GPU's, a 4090FE and the internal GPU of the 7800X3D. The (single) monitor is connected to the 4090.
When both are "active" (iGPU not disabled in bios) the power draw of the system is about 110-115 W in idle.
GPU-Z shows that the AMD iGPU draws about 37 W. This seems high for a GPU that does nothing and is a significant portion of the 110-115 W.
I would expect that when the iGPU is disabled in bios the total power draw of the system would decrease. Maybe not the full 37 W or so but still a good portion of that.
Unfortunately it doesn't. After disabling the iGPU in bios the total power draw stays the same at about 110-115 W.
Can anybody explain this? Is GPU-Z wrong or is something else going on.
22,622 (6.04/day)
It is lying to you. There is just 37W going through the CPU. The load is 0%. After all, the GPU IS the CPU.
3,799 (1.32/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
GPU-Z is showing the CPU Package Power there.
1,149 (0.71/day)
System Name Gamey #1 / #3
Processor Ryzen 7 5800X3D / Ryzen 7 5700X3D
Motherboard Asrock B450M P4 / MSi B450 ProVDH M
Cooling IDCool SE-226-XT / IDCool SE-224-XTS
Memory 32GB 3200 CL16 / 16GB 3200 CL16
Video Card(s) PColor 6800 XT / GByte RTX 3070
Storage 4TB Team MP34 / 2TB WD SN570
Case Corsair 4000Air / TT Versa H18
Power Supply EVGA 650 G3 / EVGA BQ 500
100% on both previous responses. I use an AMD MiniPC and total CPU+iGPU power is listed in the GPU Power Draw section in GPU-Z. The CPU and iGPU power metrics are not separable.
35 (0.01/day)
Software Win11 Pro
If GPU power draw is not what is shown maybe it should be labeled different to clarify.
Like CPU+GPU power draw or Package power draw.
Toothless
Tech, Games, and TPU!
9,647 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Look at Adrenaline for power usage for the iGPU.
1,149 (0.71/day)
Adrenalin's Performance tab Metrics gives the same power value in Zen 4 APUs (R7 7840HX) as GPU-Z, it sums the power of the entire thing. Looks like desktop iGPUs aren't treated any differently?
