PowerColor Next-Gen LCS Liquid Cooling Solutions Pictured
47,294 (7.53/day)
PowerColor is ready with its next-generation LCS (liquid cooling system) VGA cooling solutions. The first one in the series is a close-loop all-in-one solution for single-GPU cards, which consists of a pump+block, plumbed to a 360 mm x 120 mm radiator (at least for this prototype). Much of the liquid cooling parts have "GamerStorm" design language, hinting at DeepCool being the OEM. This single-GPU cooler could be launched with upcoming "Polaris" graphics cards. Don't let the radiator size be any indication of the upcoming chip's thermal characteristics.
Also unveiled is a new full-coverage water block for dual-GPU graphics cards hinting at the possibility of a custom-design Radeon Pro Duo by PowerColor being under development. The block appears to be more than 1-slot thick, and uses the additional volume for two independent coolant channels, so one GPU doesn't get second-hand coolant from another GPU.
101 (0.03/day)
Processor i5-4670k
Motherboard MSI Z87-GD65
Cooling Magicool G2 Slim 240+360, Watercool Heatkiller 3.0, Alphacool GPX 290 M05
Memory G.Skill RipjawsX DDR3 2x4GB 2133MHz CL9
Video Card(s) Gigabyte Radeon R9 290
Storage Samsung 850 EVO 250GB, 320GB+1TB HDDs
Case SilentiumPC Aquarius X90 Pure Black
Power Supply Chieftec Navitas GPM-1000C
These look amazing. I hope you can get your hands on them for some tests!
