Powercolor Unveils the Radeon HD 7870 Eyefinity 6
4,784 (1.00/day)
Still on the East Side
TUL Corporation, a leading manufacturer of AMD graphics cards, today releases the only HD7870 graphics solution which can support up to 6 displays simultaneously: the PowerColor HD7870 Eyefinity 6. The latest edition optimizes multi-display Eyefinity technology, enabling up to six monitors to be operated from one card through its six mini display port onboard design. This unique feature allows gamers to enhance productivity to get more things done at once, also delivering the most vivid HD gaming experience with wider view.
The HD7870 Eyefinity 6 clocks in at 1000 MHz core speed and 1200 MHz of memory speed; with 2 GB GDDR5 onboard memory, the latest edition allows more bandwidth for demanding DirectX 11.1 gaming title, delivering the intense gaming performance and unrivaled image quality with lifelike 3D visual effects.
The HD7870 Eyefinity 6 takes advantage of AMD PowerTune technology, enabling higher clock speeds while needed through unused TDP headroom; by utilized AMD ZeroCore Power technology, allowing GPU to consume virtually no power in idle mode, delivering the best power efficiency. Also, with the support of AMD APP Acceleration, it creates a "co-processing" environment of GPU and CPU, simply speeds up the everyday applications.
Completely Bonkers
2,576 (0.39/day)
Processor Mysterious Engineering Prototype
Motherboard Intel 865
Cooling Custom block made in workshop
Memory Corsair XMS 2GB
Video Card(s) FireGL X3-256
Display(s) 1600x1200 SyncMaster x 2 = 3200x1200
Software Windows 2003
4,113 (0.68/day)
Iowa, USA
System Name THE CUBE 2.0
Processor Intel i5 13600k
Motherboard MSI MPG Z690 EDGE DDR4
Cooling Phanteks PH-TC14PE BK 2x T30-120 Fan mod mount
Memory G.Skill TridentZ 3200 MT/s C15 32GB 2x16GB
Video Card(s) Gigabyte Aorus 1080 Ti 11GB OC: Core 2GHz, Mem 5.7GHz
Storage WD SN770 250GB / 3x WD SN850X 2TB / Toshiba X300 4TB / 2x RAID1 Toshiba P300 3TB
Display(s) Samsung 49" Odyssey OLED G95SC 240Hz 5120 x 1440
Audio Device(s) Beyerdynamic DT 880
Power Supply Corsair RM1000X
Mouse Logitech G700
Keyboard Logitech G910
Ouch, this is not for gamers more towards stock market and people that needs lots of screen room for like coding/photoshop etc.
unless you want crappy FPS.
102 (0.02/day)
Depends on what you play, the free mmo market is a billion dollar industry and a 7870 can run 95% of those games on max. Vindictus a source powered MMO plays nicely on my 5770 @ 2700x1600 windowed eyefinity.
