Powering a low power GPU with a molex daptor to 8 pin or simular?
3,034 (0.83/day)
So here is a question about alternative powering a lower powered gpu with a 8 pin connector needed.
Problem short: I all ready have a RTX 4090 that takes up all the GPU dedicated 6/8 pins connectors my PSU have aviable, so for my seceondary system i use a pcie slot powered only card in form of a RTX A2000. 1 PSU powers two systems, just to avoid confusion.
However i just stumpeled over this little new soon upcomming RTX 4060 with SFF cooler from Gigabyte. Problem is, it needs a 8 pin gpu connector to power it and i do not have more aviable.
So simply put, does any one here on TPU know a good and reliable way of powering a GPU with alternative connectors. Like Molex to 8 pin adaptor or sata to 8 and so on, that is also safe.
I don´t want melting connectors or fire hazards in my pc. So does any one know a good and safe solution?
3,034 (0.83/day)
Very nice PSU! I think you can try a 6-pin to 8-pin connector / adapter. Don't think there's going to be fire hazard: worst case, system will reboot / shutdown because of power not being delivered.
The 4060 does draw a bit more power than the A2000.
Also, check this thread out (if you haven't, already):
Are 6-pin to 8-pin adapters safe for GPUs? | TechPowerUp Forums
I think you mis understand. All aviable 6 and 8 pins are all in use. Thats why i need another option like molex to 8 pin or simular.
1,033 (0.70/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
Dark Hero is 4+8pins and you have 1 split cables on the CPU side 3 cables, 4 connectors for CPU1 and CPU2. Use the split cable on CPU1 the 5950X is 200W must suffice.
CPU2 will be freed for the 4060 but you need to buy new cable as the ones that 4090 is using 4 cables, 8 connectors just for itself.
3,034 (0.83/day)
Hmm yeah that could might work. I all ready use a cablemod connector for my RTX 4090. So i can might reuse the original 8 pins cable. If not, i must go buy a sutable cable.
Good unput so far.
But still open for other solutions
1,697 (1.08/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
In TPU's testing the RTX4060 spikes to 160 W, so in theory you should be able to power it with a 2x molex to 8-pin adapter. 1 molex provides 54 W, so the card would be getting up to 108 W through the PCIe connector, and should be able to pull the remaining power from the 75 W PCIe slot.
These are only calculations, and I have no way to verify it in practice.
3,034 (0.83/day)
hmm yeah. That sounds about right.
I am considering contacting the PSU provider directly and ask if they know molex or sata can handle a small GPU.
1,033 (0.70/day)
Memory 32 GB
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
Aren't those included anymore. there is always this dual molex connector to 6 or 8 pin in the box. providing only 1 12V per molex cable, so if there is a melting point that is probably it.
ir_cow
4,629 (0.77/day)
USA
Get a second PSU. You don't want to do molex to 6pin because that will be a lot of amps for a single 12v pin.
1,033 (0.70/day)
Memory 32 GB
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
PSU supports 2 systems.
Ketchup and mustard cable goes into separate Molex on the PSU, not on the same and then you have 2 separate 12V pins, and you can even roll your own adapter with 3 separate pins out of two adapters.
2,428 (1.16/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
Absolute safest way:
adapt an unused EPS (8-pin CPU).
What @N/A said would work as well.
I don't shy from molex-6pin as long as the molex plugs are from 2 separate leads.
PCIe 6 pin only has 2 hot conductors, and 2 grounds, the other 2 hot/gnd are not specced for current, and cards aren't allowed to use them.
So, 2 grounds, 2 hots, and you're using the same as a real 6-pin. (A 4-pin +12v CPU plug can be adapted to a 6-pin, also)
2 molex to an 8-pin is 'pushing it'. Even A properly wired adapter will have 4 grounds and only 2 hots.
3,325 (4.80/day)
Russian Wild West
System Name DLSS / YOLO-PC / FULLRETARD
Processor i5-12400F / 10600KF / C2D E6750
Motherboard Gigabyte B760M DS3H / Z490 Vision D / P5GC-MX/1333
Cooling Laminar RM1 / Gammaxx 400 / 775 Box cooler
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333 / 3 GB DDR2-700
Video Card(s) RX 6700 XT / R9 380 2 GB / 9600 GT
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 / 500 GB HDD
Display(s) Compit HA2704 / MSi G2712 / non-existent
Case Matrexx 55 / Junkyard special / non-existent
Power Supply Thermaltake 1000 W / Corsair CX650M / non-existent
Software Windows 11 / 10 / 8
Going for a molex adaptor is a little bit kamikaze. Not recommended, yet you can still do it and above 98% chance not face any trouble whatsoever if it's two molexes and they're connected as tightly as it gets.
Decapitating the unused 8-pin CPU power connector and giving it a new life with an 8-pin PCI-E header is the most reasonable way to do it. Just don't mess polarities up. Do not use adapters, resolder it. The less chain is daisy the less is chance of KCASsing everything out.
454 (0.51/day)
Some Where On Earth
System Name Spam
Processor i9-12900K PL1=125 TA=56 PL2=288
Motherboard MSI MAG B660M Mortar WiFi DDR4
Cooling Scythe Kaze Flex 120mm ARGB Fans x1 / Alphacool Eisbaer 360
Memory Mushkin Red Line DDR4 4000 16Gb x2 18-22-22-42 1T
Video Card(s) Sapphire Pulse RX 7900 XT
Storage Team Group MP33 512Mb / 1Tb
Display(s) SAMSUNG Odyssey G50A (LS27AG500PNXZA) (2560x1440)
Case Lan-Li A3
Audio Device(s) Real Tek on Board Audio
Power Supply EVGA SuperNOVA 850 GM
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
I have used the ones from Amazon without issue, but these were used with low wattage cards (100W to 150W). The dual SATA or Molex cables will only supply 125 watts max before they melt, this why I like the CPU to GPU PCIE cables like this one....
Amazon.com: COMeap (CPU to GPU) CPU 8 Pin Female to Dual PCIe 2X 8 Pin (6+2) Male Splitter Cable for Graphics Card BTC Miner 9-inch (23cm) (Pack of 2) : Electronics
If you do not have a spire CPU connection, they do make Y cables....
Amazon.com: ATX 8 pin Female to Dual 8 (4+4) pin Male EPS 12V Motherboard Power Adapter Cable Extension, CPU EPS Y Splitter for Motherboard 9" (1 Piece) : Electronics
If you do go with the SATA or Molex type, make sure they have two SATA or Molex connectors to power the one PCIE connector.
1,033 (0.70/day)
Memory 32 GB
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
AS you can see the PSU has 4 PCI-e cables and thats plenty can't believe 4090 must be taking all of them. perhaps you can go down to using just 2 as most cables are in fact dual 6 pin to 12VHPWR.
i just don't want to set in motion the events of something bad so be careful.
3,034 (0.83/day)
I am not sure if it is included with this particular card. It's so new it's not even up gigabytes homepage yet.
That is not an option. No place for it.
Using 2 separate ports on psu sounds like good idea.
4090 do need all 4 connectors to safely run at full throttle. 1 8 pin is rated for 150 watts max. Stock it's up to 450 watt and when power target is at max it's up to 600 watt it's alowed to pull. So 4 x 8 pins at 150 watt = 600 watt + 75 watt from pcie. But that with only 3 8 pins that still only 525 watt while the card can pull up 600 watt. So with only 3 8 pins in use, that would take up 75 watt over it's rated max capacity. So in short, yes 4090 need all 4 8 pin when Goin all out.
Also a side note. I can people talk about 6 pin. That would not work as the 4060 I'm looking at use 1 8 pin. 4060 is a 115 watt rated card, but a bit higher when overclock and power target raised to it's max.
ir_cow
4,629 (0.77/day)
USA
Either get a second PSU or buy a 1600 PSU.
Outback Bronze
Super Moderator
2,086 (0.42/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 48GB G.Skill 7200
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Samsung 34" G8
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
Does your 4090 have a 12vhpwr port? Your Gigabyte Gaming 4090 should have one.
If so, you could just buy one on those PCI-e 5.0 power supplies (which may be good for future proofing) and you'll have plenty of 8 pins for 4060 as well.
1,033 (0.70/day)
Memory 32 GB
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
I only see 6 pins. probably a cgi render, not real.
