giorgio ch
- Jun 10, 2022
- 9 (0.01/day)
Hello, im having problems with my laptop, i7 8750h and a gtx1060, my GPU stays in the normal/good temps, but my CPU is going as high as 98c causing me insane FPS drops and inconsistent gameplay, i already took everything apart and repaste it with a good thermal paste, but it didnt fixed the problem i am running the FANS at max speed, also i am using throttlestop in FIVR Options i set the Offset Voltage of CORE and CACHE at -135.7 mV i can tell my cpu is throttling because i am using MSI afterburner and my core clock speed from 3.9GHz drops to 0.8GHz and i get FPS drop then comes back and stays around 3.5/3.8GHz then again and drops, i have my laptop in a cooling pad... what i did was LIMITED the TURBO RATIO LIMITS to 3.1GHz that way i got CONSISTENT 40FPS but thats not what i want, i want to be able to use the 100% of my CPU with minimum throttles, i attach screenshots, my score in CINEBENCH R20 is 2250pts also, when running cinebench i hit 90c but when im gaming i hit 98c and have horrible drops of everything, FPS and GHz running my game with its full capacity of CPU makes it unplayable, i get to play 5 minutes of 70fps at 3.9hGHz then insane drops, but when i choose to limit the turbo at 3.1GHz or 3.2GHz i get STABLE 40fps with occasionally drops. what can i do to fix or improve this, thank you for your time.
