[Case Gallery] Predator II
Ranse
52 (0.01/day)
Gastonia NC
Specs:
AMD FX-8150 Zambezi 3.6GHz Socket AM3+ 125W Six-Core Desktop Processor, Rosewill BRONZE Series RBR1000-M 1000W Certified, Modular Cable Design, SAPPHIRE Flex 100328FLEX Radeon 2 HD 6770 1GB GDDR5 in cross fire mode, CORSAIR Vengeance 16 GB DDR3 SDRAM DDR3 1600, GIGABYTE GA-970A-UD3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard, CORSAIR CWCH60 Hydro Series H60 High Performance Liquid CPU Cooler, OCZ Vertex 3 VTX3-25SAT3-60G 2.5" 60GB SATA III MLC Internal Solid State Drive (SSD) 1 SAMSUNG 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive, XION Predator Gaming Series AXP 970-001BK Mid Tower PC Case w/ Hot-Swap Enabled Front Loading Trays for SATA HDD.
Mods:
I cut the side and placed a clear window were the mesh was and sleeved cables, repainted the side from window work and added cooling to the hot-swap drive rack and cool box to bottom of case. This will probably by my last build for a while I hope yall enjoy. I do like working with the Xion Predator cases have had four builds with them. I have the computer over clocked to 4ghz
9,896 (1.86/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
nice and simple
i like the carbon fiber accent
Pasha
12 (0.00/day)
Slovenia
I voted 10/10 because:
Clean
693 (0.11/day)
Processor AMD 8350
Motherboard Asus M5A99FX PRO R2.0
Cooling Xigmatek Dark Night Night Hawk Edition
Memory 4x4GB DDR3 1600 GSkill Ripjaws CL7
Video Card(s) Gigabyte 980 Ti Xtreme Gaming OC Ed
Storage Samsung 850 Evo 500gb + WD Black 5Tb
Display(s) ASUS VG248QE 144Hz
Case White Corsair 500r
Power Supply Corsair AX860i 860W
Software Win 10 Pro 64bit
Very nice. What is underneath the carbon fiber? I've been curious as to what people are using to hide the wires & stuff.
Ranse
52 (0.01/day)
Gastonia NC
Panel materials
I used Lexan for the panels its easy to work with and with a heat gun is moldable but be careful when using heat you have to go slow to it don’t warp or bubble. To cut the holes I used a 4" hole saw.
693 (0.11/day)
Processor AMD 8350
Cool, thanks for the info.
