pretty raptor pattern but slow as a dog.. he he
8,253 (1.17/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
mine is the red one.. the blue line is an earlier 36 gig one..
trog
KennyT772
3,572 (0.51/day)
System Name Raptor
Processor Intel E8400 Wolfdale @3600
Motherboard Asus P5Q-Pro LGA775
Cooling Zalman CNPS9700
Memory 1024mbx2 Crucial Ballistix DDR800
Video Card(s) XFX 9600GT
Storage Seagate 7200.11 500GB
Display(s) Acer AL2216Wbd and Acer AL1717
Case Gigabyte 3DAurora Black
Audio Device(s) Creative X-Fi Extreme Gamer Faitality
Power Supply OCZ GameXStream 500w
defragg
its loading all the files to cache then bursting threw sata.
Ketxxx
Heedless Psychic
11,521 (1.66/day)
Kingdom of gods
System Name Ravens Talon
Processor AMD R7 3700X @ 4.4GHz 1.3v
Motherboard MSI X570 Tomahawk
Cooling Modded 240mm Coolermaster Liquidmaster
Memory 2x16GB Klevv BoltX 3600MHz & custom timings
Video Card(s) Powercolor 6800XT Red Devil
Storage 250GB Asgard SSD, 1TB Integral SSD, 2TB Seagate Barracuda
Display(s) 27" BenQ Mobiuz
Case NZXT Phantom 530
Audio Device(s) Asus Xonar DX 7.1 PCI-E
Power Supply 1000w Supernova
Benchmark Scores Fast. I don't need epeen.
by the looks of that, trogs never heard of a defrag :p
Alec§taar
4,677 (0.68/day)
Someone who's going to find NewTekie1 and teach hi
Processor DualCore AMD Athlon 64x2 4800+ (o/c 2801mhz STABLE (Ketxxx, POGE, Tatty One, ME))
Motherboard ASUS A8N-SLI Premium (PCIe x16, x4, x1)
Cooling PhaseChange Coolermaster CM754/939 (fan/heatsink), Thermalright heatspreaders + fan built on (RAM)
Memory 512mb PC-3200 DDR400 (set DDR-33 for o/c) by Corsair (matched pair, 2x256mb) 200.1/200mhz
Video Card(s) BFG GeForce 7900 GTX OC 512mb GDDR3 ram (o/c manually to 686 core/865 memory) - PhaseChange cooled
Storage Dual "Raptor X" 16mb 10krpm/RAID 0 Promise EX8350 x4 PCIe 128mb & Intel IO chip/CENATEK RocketDrive
Display(s) SONY 19" Trinitron MultiScan 400ps 1600x1200 75hz refresh 32-bit color
Case Antec Super-LanBoy (aluminum baby-tower w/ lower front & upper rear cooling exhaust fans)
Audio Device(s) RealTek AC97 onboard mobo stereo sound (Altec Lansing ACS-45 speakers - 10 yrs. still running!)
Power Supply Antec 500w ATX 2.0 "SmartPower" powersupply
Software Windows Server 2003 SP #1 fully patched, & massively tuned/tweaked to-the-max (plus latest drivers)
VERY interesting fellas!
* Today's not a 'wasted day' as I apparently have picked up a NEW THING in this analysis of yours...
(I.E.-> I had NO idea that HD Tach could indicate the need for defragmentation of disks via its pattern of data on its graphs...)
APK
8,253 (1.17/day)
neither had i alec but its a brand new just formatted and empty HD.. so i recon we can forget a cure as simple as that.. he he..
something wrong with the bugger thow.. the read seems to be the problem HD Tach apart stuff seems to write to it okay but not from it..
i only used the benchmark in my attempts to find out why its iffy..
soo defrags apart what can make a HD behave like this.. he he
my other three are perfectly okay.. even the ones that might need a little defrag.. he he
i have checked everything out it might just be a duff drive..
trog
Alec§taar
4,677 (0.68/day)
trog
I'm now wondering if TCQ or NCQ (I don't think this model of RAPTOR has that latter one though, but, iirc, it DOES have the former one) is turned on?
APK
P.S.=> It can affect things, but I honestly NEVER knew how to turn those features on OR off on these disks to be blunt about it... jumpering maybe? apk
8,253 (1.17/day)
its has the latter one same as the new 150 drives.. same 16 meg cache as well.. i did look at mine and didnt see any jumpers anywhere.. its the GD on the end that denotes the older ones..
i did read that command line queuing or whatever its called has a negative impact for single user set ups and should be turned off.. ..
but as u say i aint found any way to turn on or off such things..
trog
ps.. the average read time given is way off as well.. its worse in reality then the HD benchmark suggests.. it seems to spend a lot of its time doing nothing with little bursts of activety in between.. lets say its at least 10 x slower then it should be.. he he.. the average read figures are when it is reading not counting the time in between spent doing bugger all.. he he.. in short its painfull to watch..
Alec§taar
4,677 (0.68/day)
Ahhh, I see... you have one of the "latest/greatest" NEW edition 36gb RAPTORS then... I myself still have the "original edition" here (8mb buffer type).
I also looked right after I posted that to you... & STILL cannot find the answer (that, I do NOT like, of course).
You MAY have a "lemon" there, they DO happen. I don't know what to tell you, other than IF you bought it new, this would be grounds for exchange imo @ least... & if used? Well...
APK
8,253 (1.17/day)
"you MAY have a "lemon" there.."
thats at the top of my probability list alec.. but its said that most hardware sent back has nothing wrong with it.. my own experience backs this up..
but i think it was a mistake anyways so if it does go back its a credit note i would be after..
i have dropped the prob on one other storage based forum so an answer might pop up.. he he.. why do i doubt it thow.. he he he
if it has an easy answer alec it aint a problem to me..
trog
