GoronsRule
- Aug 3, 2024
- 3 (3.00/day)
Hello everyone, hope you are doing well. I've surfed through this site quite a bit for the past year because of its excellent programs and threads that help thousands of people.
I'm here because I've exhausted all of the possible solutions I could think of to cool my Acer laptop. The problems are as follows:
1. Intensive gaming such as Elden Ring, heavy emulation like the Switch, etc., all lead to temperatures that hover around 90-95 WHILE UNDERVOLTED. I tried a trick I've been using that is limiting the FPS to 30 and "duplicating it" with LSFG from Lossless Scaling and it worked for a while when it comes to performance (even if it's fake FPS), but I still had high temperatures nonetheless.
2. Prochot Offset is locked by Acer from what I've seen (there is a yellow lock above it, although the options aren't grayed out), so I can't manually lock the temperatures so that it doesn't overheat.
3. As I've said, I already undervolted and underclocked both my CPU and GPU following some YouTube guides and the nice preset Red Sand (Hero Preset) from the Acer forums, and from what I've read so far, it works nicely. It's not a miracle thing, since the author of the preset said that the fps would be more or less the same but the temperatures would decrease 5 or 20 degrees depending on the games at that time.
4. I've used this 6 year old laptop for 4 years (got it in 2020) heavily (changed OS from Windows to Linux and back to Windows, I'm on Windows 11 which I kinda regret), so I don't know how much life it has left, and may be why it overheats. I upgraded it with 16 GBs of RAM (24 GBs now in total) and a 1TB SSD if that helps. I've sent it for maintenance and thermal paste change, but nothing worked. I even have a cooling pad that lifts it a little bit so it has a better way to cool itself, but it also doesn't do much.
So yeah, these are the issues with my laptop and I require some help. Uncle Webb, if you are reading this, I require your infinite wisdom when it comes to this stuff, and I thank everyone beforehand for reading this and helping me afterwards if possible.
I don't have any benchmark programs at the moment, only some games and HWInfo if that helps. I'll provide logs if needed but I don't know how to do it efficiently, so I'll wait for instructions as well. Have a good day.
