Problem with monitor
9 (0.38/day)
System Name Old asf
Processor Ryzen 3 1200 3,10ghz
Motherboard Gigabyte 450M DS3H-CF
Cooling Stock
Memory 16 GB DDR4 G-skill Ripjaws V 3200MHZ
Video Card(s) Sapphire Nitro+ RX 580 8GB
Storage Lexar 500gb SSD
Display(s) SAMSUNG Odyssey G3 LS24AG300NRXEN
Case Some amiga case from the 1900s (It's REALLY old)
Power Supply SPC (Endorfy) Viro 700W 80+ Bronze
Mouse SPC (Endorfy) LIX PLUS
Keyboard EPOMAKER TH80 PRO (with the knob)
Hello ladies and gentlemanes, i have a little problem with my monitor.
It all started when i tried to install old drivers for my rx 580, because of some problems with dwm.exe high GPU usage, when i did install like the wrong drivers, i tried to come back to them using windows, you know, the roll back setting, and everything lagged, then i turned off my pc, and i cant boot it up since then.
It shows that monitor doesnt have display port connection, but it never did, it always was running on hdmi, and i didnt change anything in that direction.
It works fine with other pcs (i tested it with my brother pc)
But when i tried to plug in another monitor that i think was a dvi monitor, it was laggy as hell, after 10minutes of pain, it turns out that the this monitor doesnt detect my gpu.
Idk what's happening, i'll add some photos to maybe help.
The crosshair thing is wrote in Polish and it means literally
check the cable connection and output device settings
Displayport
Also when my computer boots up, always in the top left corner there is hdmi and displayport windows
