- Aug 16, 2024
- 7 (0.04/day)
- Japan
Processor | AMD Ryzen 7 5700X |
Motherboard | AsRock B550M Steel Legend |
Cooling | SCYTHE Big Shuriken 3 SCBSK-3000R |
Memory | DDR4-3200 32GB |
Video Card(s) | ZOTAC GeForce GTX 1080 TI Blower ZT-P10810B-10B |
Storage | KIOXIA EXCERIA PRO 1TB SSD-CK1.0N4P/N |
Case | SilverStone SST-SG12B |
Audio Device(s) | TASCAM US-366-SN |
Power Supply | Silver Stone DECATHLON 850W SST-DA850-G |
Mouse | Logitech G502 HERO |
I installed GeForce Game Ready driver 572.16.
After that, the DisplayPort video output became unstable, causing symptoms such as the monitor image becoming distorted or not showing at all.
I tried reinstalling driver 572.16, but it had no effect.
The symptoms disappeared after installing the previous driver 566.36.
While using version 572.16, the monitor display problem occurred on both of the two monitors.
When I touched the DisplayPort connector on the monitor side while the image was being displayed normally, the image became distorted.
Also, when I connected and disconnected the DisplayPort connector, the image no longer appeared.
After reverting to version 566.36, the video is normal when I touch the DisplayPort connector.
Even if you connect and disconnect the DisplayPort connector, the monitor image will display normally.
Based on the above symptoms, there may be a problem with the DisplayPort output settings with driver 572.16.
Is there anyone else experiencing similar symptoms?
Also, are there any other possible causes of the problem besides the driver?
I'm using a GTX 1080 Ti.
ZOTAC GeForce GTX 1080 TI Blower [ZT-P10810B-10B]
I have dual 1080p monitors, and the two monitors were purchased on different dates and are different products.
This setup has been working fine for almost 4 years.
