Problem with samsung odyssey g7
48 (0.07/day)
Processor Amd Ryzen 7 5800x3d
Motherboard ASUS ROG Crosshair VIII HERO WiFi
Cooling Noctua NH-D15 chromax.black
Memory Crucial Ballistix 3600 MHz 32 gb
Video Card(s) ASUS ROG Strix NVIDIA GeForce RTX 3080 Ti OC Edition
Storage SAMSUNG 980 PRO PCIe 4.0 NVMe SSD 1TB + 2X WD Black 4T
Display(s) SAMSUNG Odyssey G7 Series 27-Inch
Case Cooler Master H500p mesh
Power Supply Seasonic FOCUS GX-850, 850W 80+ Gold
hi guys
a friend of mine has a problem with his monitor which is odyssey g7 27 inch curved monitor, the panel is starting to come off which is a common problem with this screen and with any curved panel, now this isn't the first time his screen done this it happened before and we sent it to samsung to be fixed but now he's out of warranty so samsung told him to go f*** himself ,the problem is that his pc is in a very hot room which facing the sun all day and he doesn't have AC so it's like hell in there and no he can't move it anywhere else, this massive heat is what i think caused the screen to come off second time please note that i have the same screen which had the same issue and since samsung fixed it it didn't come off again ,i live in the same city near him but my room isn't that hot and i have AC.
i couldn't find any specialist that can help us fix it so we decided to do it our self and we were debating about the type of adhesive to use, we don't have much options here -we live in Cairo, Egypt- i have searched a lot and did find only two types of adhesives to use
1- B-7000
2- Victor Reinz 70-31414-10
i think that Victor Reinz is good for the job since it's heat resistant -50°C to +250°C and my friend think that the b-7000 is the one since he saw someone on youtube using it for the same purpose, from my knowledge i know that the b-7000 is not very good, under a lot of heat it melts and the main problem here is heat .
so which one is better ?
will Victor Reinz damage the monitor in anyway ?
you could suggest another option and i will look for it
thanks in advance
Solaris17
Super Dainty Moderator
26,435 (3.80/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Display(s) Odyssey OLED G9 (G95SC)
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
Neither, use E-6000.
The monitor will need to be laid down. Don’t try to let it cure standing up.
48 (0.07/day)
seen it searched for it and it's not available here :(
7,346 (1.46/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
As a RMA tech I would say firmly... B7000 wont help here. To be honest it often fails to stick slightly curved battery covers for phones... yet a monitor... the problems with glue is, you have to prepare the surfaces for proper diffusion, it ain't that simple, it never is, but here is a different scenario.
Basically the force that thermal expansion does is so radical, no glue can mitigate it, otherwise it would crack, it just doesn't have the gaps... just like even SR71 Blackbird had.
3D print a clip maybe? I really believe if you will do glue it like it should... it would crack... so don't overdo it...
48 (0.07/day)
what about Victor Reinz 70-31414-10 ? is it safe to use or not?
i don't have or know anyone have a 3d printer
