- Apr 4, 2022
- 15 (0.02/day)
System Name | DOFAscension2020 |
Processor | Ryzen 2600 |
Motherboard | Asrock Steel Legend b450m |
Cooling | Roseweill pb120 liquid cooler |
Memory | 16 gb (2x8) Corsair Vengeance 2133 (Xmp to 3000) |
Video Card(s) | MSI ventus 1660 ti |
Storage | 1 tb samsung 980 nvme/ 500 gb samsung 850 evo/ 2 TB wd Blue HDD |
Display(s) | I use my TV |
Case | Thermaltake v200 RGB Glass Edition |
Audio Device(s) | Audio from video card |
Power Supply | Corsair CV550 |
Mouse | Decus Speedlink Respec |
Keyboard | Corsair k70 Lux |
Software | Yuzu |
Hello. I hope i've posted this correctly as it's my first post. This pertains to the system power LED light on the CASE. I have a steel legend b450m Motherboard and a Thermaltake v200 case. Everything on my PC is working and my PSU is delivering proper power to all components. My problem is, when the computer is off but the PSU is on, My system power LED is on. BUT, when i turn the computer on, the system power LED turns off. It's basically reversed. I can't find another person with this problem anywhere, and I've tried about 20 solutions. I have the PLED in the correct lead, but the light is on when the system is powered off. So there can be no soldering problems at the case, no power problems at the psu, something else is wrong here. Please let me know if you need any additional information. Thanks very much in advance. Furthermore, I'll add that this systems power LED light worked perfectly before, with the same motherboard. I replaced the PSU and when plugging things back in this problem started. The PSU is Corsair CV550. The PSU reaches gaming loads and modulates varying amounts of power to the computer so i doubt it's the new PSU. Finally, I'm using a simple PLED+ and one PLED-. Does this case come with three PLED connections? My mobo manual shows two connections for PLED on the system control header, and 3 connections for something also called "PLED" right next to it. Is it possible there is a third power LED connector I can't find? I have restored original UEFI settings in bios and that didn't help either. Something really messed up is going on here. -I do not have the technology to show you how my leads are wired. However, they are done correctly according to the manual. I was hoping for out of the box solutions. NOTE: There are 5 "pled" connectors across two headers. three positive and two negative. The ones i need are the two on the system header panel and i know this. I'm just stating that the manual strangely has another set of pins (three pins to accomodate the old style) on the speaker header, whereas most mobo's just have the four pins for the speaker. All five pins work for the system power LED, however it's the same on when off problem. Let's be kind and polite, please.
CPU: Ryzen 2600
Motherboard: Asrock Steel Legend b450m
RAM: 16 GB (2x8) Corsair Vengeance 2133 mhz (xmp to 3000 mhz)
SSD/HDD: Boot Drive Samsung 980 1 tb + Samsung 850 Evo 500 gb + WD Blue 2 TB
GPU: MSI Ventus 1660 TI
PSU: Corsair CV550
Chassis: Thermaltake v200 RGB glass Edition
OS: Windows 10 version 20H2 (OS build 19042.1526)
CPU: Ryzen 2600
PSU: Corsair CV550
