problem with vga port
1,118 (0.63/day)
System Name just ordinary potato system, but dont understimate potato..
Processor ryzen raven ridge 2200g, ryzen 2600 upgrade:)
Motherboard msi b350 pc mate, biostars a320, asrock ab350m micro
Cooling x2 cheap china handmade, i got plenty aigo/fantech rgb fans now heh
Memory klevv dual channel 8gb 3000mhz, trident 16gb 3600mhz, random ddr2 stick
Video Card(s) back to square, using vega 56 now:D
Storage wd green ssd 240gb, 3tb seagate expnasion, random laptop hdd x4, 1tb 3.5
Display(s) acer vgo 22inch fullhd 75hz
Case cheap segotep/dazumba mid atx, alcatroz mini atx
Audio Device(s) genius retro wood style, harman kardon stick iii
Power Supply be quite system power9, powerlogic standar, voltron 300fx, thermaltake smart 1200w
Mouse rexus, genius ps/2, powerlogic ps/2 ball tracking
Keyboard rexus, random china product x3
Software talking abt best software, autodesk/unity3d/notepad yes notepad!!
Benchmark Scores theres nothing to brag abt potato, but it can run decent 30fps fullhd with good setting:)
hello i get problem with old monitor, the monitor itself can be turn on just fine, the problem is whenever i pkug vga cable, my screen turn black no display, do thia consider i have broken vga port?
132227
the pic above is on standby mode, no cable plug
132228
its sudently blank after plug vga cable, not to mentioned connect to pc, both have same problem blank screen
132229
i testing on 2 old monitor, both have same brand samsung sync master, the 15inch one have problem, while the 17inch run just fine
132230
12,521 (1.91/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
If you are saying you used the same cable with the same computer and the 17 inch monitor worked fine but the 15 inch monitor did not, then you just proved the 15 inch monitor is faulty.
Sadly, according to these specs, it only supports 1 VGA D-sub input. So it looks like that 17 year old monitor needs to go to the electronics graveyard.
875 (0.46/day)
The New England region of the United States
System Name Daily Driver(gaming, browsing)
Processor Ryzen 7 3800X
Motherboard Gigabyte X570 Aurus Pro Wifi
Cooling Noctua NH-D15 chromax.black
Memory 32GB(2x16GB) Patriot Viper DDR4-3200C16
Storage Samsung 970 EVO Plus 1TB (Boot/OS)|Hynix Platinum P41 2TB (Games)|Kingston KC3000 2TB (Misc)
Display(s) Gigabyte G27F
Case Corsair Graphite 600T w/mesh side
Audio Device(s) Logitech Z625 2.1 | cheapo gaming headset when mic is needed
Power Supply Corsair HX850i
Mouse Redragon M808-KS Storm Pro (Great Value)
Keyboard Redragon K512 Shiva replaced a Corsair K70 Lux - Blue on Black
VR HMD Nope
Benchmark Scores Nope
Those display controller boards don't last forever. Interestingly enough, the old inverters and CCFL backlights usually fail way before the controller boards do. Try another VGA cable maybe another PC if possible. Make sure the settings are 1024x768 and 60Hz refresh. Specs say it will do 75Hz but test with 60Hz to be sure. Unless you absolutely need the 15" it's not worth the time and effort to repair it.
187 (0.11/day)
Processor Raptor Lake 13700K
Motherboard Asus Z690
Memory 32GB DDR4 3600Mhz CAS16
Video Card(s) Gigabyte 4070 Ti
Display(s) Samsung C32HG70 - 32" 1440p
Case Silverstone GD-07B
Audio Device(s) Focusrite Scarlett 8i6 3rd Gen - Sennheiser HD595
Probably the monitor, but it could also be any component here. I see PATA ports and an AGP slot. Judging by the HSF, probably a Socket A along with some sort of X800/X1800 card. Could also just be refusing to output a certain resolution because reasons.
I'd personally pull the CPU as a souvenir and then send the whole lot to the electronics graveyard, including the keyboard.
12,521 (1.91/day)
Nebraska, USA
Mouse Logitech M190
Right and that was my first thought as those are fairly easy and inexpensive to fix. But if the backlight and/or inverter had failed, he would not have gotten the "No connection, Check Signal Cable" error.
PATA? That's for EIDE hard drives and has nothing to do with the video display. And if the AGP slot (or card), the 17 inch monitor would not show a display.
Huh? Why? The computer works. The 17 inch monitor works. Only the 15 inch monitor is having problems.
187 (0.11/day)
Thanks Captain Obvious. I mentioned those things because they help put a date on the system.
Because they're either pre-2004, or just generally crap components. He's free to mess around or do whatever he wants; that's just what I would do personally. Computers of that era aren't old enough to be interesting to me.
1,118 (0.63/day)
thax for the sugestion guys, i will try it again tomorrow, ive spare old pc amd sempron am2, maybe it can be display correctly, if the problem still presist, i will threw this 15inch monotor hehe :D
12,521 (1.91/day)
Nebraska, USA
Mouse Logitech M190
Worth a try. If you can repurpose old hardware and keep it out of land fills, that's great. BTW, many communities have electronics recycling centers just to keep such hazardous waste products out of landfills.
:( So did the link to the monitor I included above (which is what this thread is about) and where I pointed out the monitor was 17 years old.
To you? Perhaps not obvious, but this thread is not about you. And obviously, the OP is interested in keeping it productive.
785 (0.24/day)
System Name Fat NCASE
Processor Ryzen R9 3900X
Motherboard ASUS TUF GAMING B550M ZAKU (WIFI) Edition
Cooling Scythe Fuma with 3 SCYTHE Wondersnail 2400RPM + Arctic MX2
Memory Corsair Vengeance 128GB @3200Mhz Cl16 (32GB X 4)
Video Card(s) Palit RTX 3060 StormX ITX 12GB
Storage MX500 4TB SATA + Toshiba MG08 16TB HDD
Display(s) LG 27UL500 4K monitor
Case Jonsbo W2 black
Audio Device(s) Onboard realtek 1200 & Soundblaster G3 usb
Power Supply ASUS ROG STRIX 850W Gundam Edition
Mouse Elecom wireless mouse :)
Keyboard RK100 Royal Kludge
Software Windows 10 HOME
Benchmark Scores Don't know any benchmark. It runs good enough for me.
Great to see someone still repurposing old hardware, I don't have much knowhow and especially space to this things. I have my long serving Philips monitor from 2008 the one defunct in my signature. Unfortunately for mine, it cannot turn on at all. For things this old, the fix might be pretty simple, most likely the capacitors in monitor display board have already bloated or dead. Changing them might bring the screen the life, I wanna do that but I am not sure of prying my screen and sadly it was disposed. Majority of dead old boards are capacitors issues
You can try it, the worse is a dead screen which is already dead. I'll definitely keep those AM2 boards and fix them old boards are getting rare and many are dump as people don't see the value in them. I still find them good for legacy windows xp system or even before.
1,118 (0.63/day)
i managed to make it work, theres 2 pin cable corrosion, but i encounter new trouble, look at this, the screen only 1/3 i guess
132758
whats this problem, anyone knowhow to fixed?
7,762 (2.95/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
Is the corrosion on the cable or monitor? If the former I would try another VGA cable. Cleaning corrosion out of a VGA port would be tricky, though. I would try soaking in vinegar, but that doesn't exactly sound easy for a monitor. A quick spray of WD-40 and inserting and removing the cable a bunch of times might clear things up, but comes with the added risk of gunking up the port over time due to sticky residue.
Question: is this for a retro gaming PC or some such?
1,118 (0.63/day)
iv alr clean the cable inside motherboard, and manage to make it display propely, but theres new problem, only half of screen displayed, before that its actually blank screen:D,
132776
acuattly i keep this monitor for current gaming too, when my gpu cant handle such decent 60fps, i might switch to used 720p or even below res to get smooth gameplay, if i used 2k monitor, the scaling just bad and cause real fuzzy/blurry, so old monitor it help me sometimes:)
btw this 15inch monitor native is 1024x768, is good for playing highend game such re2 or assasins odyssey with igpu vega 8, i could get lot fps using this monitor probably:D
dorsetknob
9,106 (1.29/day)
You can buy that age or newer monitors (often bigger ) from Goodwill/charity shops for $5 to $10 fully working
There is your solution
7,762 (2.95/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
Well, as Digital Foundry recently showed, a CRT is a far better solution for low-res gaming. It's just too bad they are so damn huge.
1,118 (0.63/day)
yes indeex
yes indeed, it wont worth a repairing cost tho i can buy another 15inch for $10, am just curious whats the problem on this monitor:D
plus they were not efficent on electricy :p
2,800 (0.66/day)
System Name BoX-Server | 775PC
Processor I3 3.5GHZ (3150) | Modded Xeon E5450 (OC @3.60)
Motherboard ASRock B85M-ITX | ASUS P5Q-EM
Cooling OEZM HSK | 92MM Heatsink RGB
Memory 8GB DDR3 | 8GB DDR2
Video Card(s) AMD 6450 | AMD RX 550 4GB
Storage 120GB SSD 1TB WD | 120GB SSD 1TB Seagate 500GB HDD <<
Display(s) DELL 17" LCD 1280x1024 | ASUS 24" LCD IPS
Case CoolerMaster 110 | RoseWill ZIRCON
Power Supply Rosewill 610WATT | Rosewill 550WATT
Mouse Input-Director| RoseWill FUSION C40
Keyboard Input-Director | RoseWill FUSION
Usually this tends to be a Cable issue, pins bent, or internally the cable PCB connector is twisted beyond repair hence "No connection"
