problem with wuwa and rtx 4090 and wutheringwaves
57 (0.03/day)
System Name Lulze
Processor ryzen 7700X
Motherboard X670E Taichi
Cooling 420 AIO
Memory 32 go ddr ddr5-6000
Video Card(s) RTX 4090 Trinity OC
Storage 980 PRO
Case CORSAIR 7000D
Power Supply CORSAIR HX Series HX1200
i think i have some performance problem with the game wuthering wawes and my 4090
i play at 1440P
i cannot maintain the 120 FPS anymore like before. before 120 FPS was easy. what the hell happened, is the game now hard to run of the 4090 underfperform,(i dont have problem with my other game )
the rest of the system is 64 go of ram corsair 6000mhz and the cpu is 7700X
4,852 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
since your other games are fine it's not a hardware issue
Any new patches to the game, expansions, or driver updates by you?
Are you sure it's a downstream issue and not an upstream issues?
Your best bet would to check in with your fellow players and see if they are experiencing similar issues
7,602 (5.01/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Yes, actually. WuWa just added support for RT and DLSS on yesterday/today's patch and it might have been automatically enabled since OP has a 4090. If they only play casually and don't follow the game's socials, might have missed that entirely.
Meanwhile us Genshin players stuck with 60fps and a third party unlocker tool :(
@cou60 Please check if Ray Tracing is enabled in your settings
1,523 (0.97/day)
Tel Fyr
At least it's an UE4, so it can be tweaked trough a bunch of .cfg files, right? Right?
57 (0.03/day)
System Name Lulze
Cooling 420 AIO
Storage 980 PRO
Case CORSAIR 7000D
thx mr Hu tao
ray tracing was enabled and DLSS was disabled.
with ray tracing disabled i can do 120 FPS again
should i enabled DLSS to help me get 120 FPS,
ray tracing is heavy damm. hope the 4090 will be ok until the rtx 6080.
genshin is easier to run than wuwa, i could run genshin with an old 980 TI
7,717 (3.28/day)
California
System Name His & Hers
Storage lots of SSD.
I can't remember what call of duty it was but an update came out that enabled RT and a person I did a system build for called me telling me his pc must be broke he's only getting 30-40fps vs 100 he was usually getting lol.
This made me think of that.
