OCMaster95
- Nov 10, 2017
- 1 (0.00/day)
MSI Afterburner software is one of the best tools for overclocking… and I think this info got pretty obvious recently due to the hot mining topic.
I am using my GTX 960 to play the Destiny 2 but the fps is so low and the performance is so LAG….so just decide to buy the latest 1070 Ti and try to overclock it. Just finished the profiles and want to share it to anyone who is interested on this topic! It’s pretty easy though, steps sharing as below.
Profiles Download LINK: https://goo.gl/852NT3
1. Of course you need to have Afterburner first…
Download link: https://www.msi.com/page/afterburner
2. Make sure to check your card is working properly
- Go to your pc -> “Properties” -> “Device Manager” -> “Display adapters” -> “Properties”
- You are good if it shows “This device is working properly”
3. Check click the “Unlock voltage control” and “Unlock voltage monitoring”
4. Click on the “Afterburner” folder in C Drive and Select the “Profiles” folder
- usually the default path is C:\Program Files (x86)\MSI Afterburner\Profiles
5. You only need the file with your system name on it
6. Attached my profiles to you
7. Open my file and you will find below info
8. Step as following
9. Reboot your Afterburner
Profiles information:
1. Profile 1: increased 78 MHz core clock
2. Profile 2: enhanced power limit from 100% to 120%
3. Profile 3: raised voltage to 100%
4. Profile 4: increased 100 MHz memory clock
5. Profile 5: revised the fan control properties
