[Case Gallery] Project Flow
582 (0.10/day)
System Name Flow
Processor AMD Phenom II 955 BE
Motherboard MSI 790fx GD70
Cooling Water
Memory 8gb Crucial Ballistix Tracer Blue ddr3 1600 c8
Video Card(s) 2 x XFX 6850 - Yet to go under water.
Storage Corsair s128
Display(s) HP 24" 1920x1200
Case Custom Lian-Li V2110b
Audio Device(s) Auzentech X-Fi Forte 7.1
Power Supply Corsair 850HX
Specs:
AMD Phenom II 955 BE @ 3.8ghz
MSI 790fx GD70 AM3
4gb OCZ platinum DDR3 1600 c7
2 x XFX 4890 XXX edition @ 1ghz/1ghz
EK Waterblocks
Corsair HX850
Corsair S128 SSD
Mods:
Granite floor, all black powder coated, custom waterfall reservoir, Custom bare wire power to motherboard and gpu's, CF stealthing plate, Custom designed Lamptron FC3 fan controller, Front door plating and Side panels cut on CNC router from my drawings, All nickel plated copper waterblocks and ramsink, Laser Cut FLOW logo designed by me, dual DDC 3.2 pumps with EK DDC x-top v2
5,787 (0.98/day)
Switzerland, Heart of Europe
System Name Fractality 1.0
Processor Intel Core i7-860 @ 3.6GHz
Motherboard EVGA P55 SLI
Cooling Prolimatech Megahalems and four Fractal Design 120mm fans, sleeved
Memory 16GB Kingston Hyper RAM
Video Card(s) PNY GeForce 580 XLR8
Storage 64GB and 180GB SSDs / 1TB and 2TB HDDs
Display(s) 24" Acer V243W
Case Fractal Design Define R2, sleeved all I/O cables
Power Supply Corsair HX750W modular, sadly only stock sleeving
Software Win 7 64bit
Sniipe, I give you a 1/10. Why? Because I'm jealous. J/k, 10/10 mate, you know it :p
Howard
152 (0.03/day)
Hong Kong
System Name Simplicity II Extreme Rev.2
Processor Corei7 920 D0 @4.2Ghz 1.375V Turbo
Motherboard eVGA X58 Classified E759
Cooling Watercooled CPU (EnzoTech Luna Rev.A) NB+SB (Bitspower) Mosfet (Bitspower) Feser 360 + MCP655B
Memory Corsair Dominator GT CL7 1866Mhz 6GB (7-6-7-20 @1600Mhz)
Video Card(s) XFX GTX285 XXX
Storage WD Caviar Green 1Tb (OS) - WD Caviar 500Gb - Seagate Barracuda 500Gb
Display(s) Samsung SycnMaster 931bw
Case ATCS840 Black (Acrylic Side Panel)
Audio Device(s) X-Fi Titanium Fatality
Power Supply Corsair HX1000
Software Win7 Ultimate x64
Benchmark Scores will do this asap..
excellent!!! 10/10 !!!
another MDPC just born!!! my eyes r rollin' here seeing the reservoir, it's masterpiece!!!
i want that reservoir, where did u get that from???
salute from me!!! toast~
582 (0.10/day)
System Name Flow
Cooling Water
Cheers guys :D off to clean but I will come back and update the fields after :)
4,251 (0.74/day)
California
Processor Intel i7 10700k
Cooling Corsair H100i
Audio Device(s) Onborad dts
Power Supply Corsair RX 650 W
Mouse Roccat Kiro
Keyboard Razer Tarantula
Software Windows 10 Home x64
This is the cleanest case I have ever seen and the photography is amazing! 10/10
YinYang.ERROR
463 (0.08/day)
System Name Echelon
Processor Phenom II x3 720 - 4th Core Unlocked
Motherboard Asus M4A785TD-V EVO
Cooling Stock
Memory Adata 4gb ddr3 1600
Video Card(s) Ati HD 5770
Storage 640gb & 250gb SATA
Display(s) MAG CRT 17"
Case CM 690
Power Supply 600w Cooler Master Silent Pro
Simply amazing. A perfect 10/10.
3,296 (0.54/day)
System Name Thakk
Processor i7 6700k @ 4.5Ghz
Motherboard Gigabyte G1 Z170N ITX
Cooling H55 AIO
Memory 32GB DDR4 3100 c16
Video Card(s) Zotac RTX3080 Trinity
Storage Corsair Force GT 120GB SSD / Intel 250GB SSD / Samsung Pro 512 SSD / 3TB Seagate SV32
Display(s) Acer Predator X34 100hz IPS Gsync / HTC Vive
Case QBX
Audio Device(s) Realtek ALC1150 > Creative Gigaworks T40 > AKG Q701
Power Supply Corsair SF600
Mouse Logitech G900
Keyboard Ducky Shine TKL MX Blue + Vortex PBT Doubleshots
Software Windows 10 64bit
Benchmark Scores http://www.3dmark.com/fs/12108888
ima pooped my pants.
582 (0.10/day)
System Name Flow
Cooling Water
I made the reservoir myself. I designed the pieces in CAD, sent a drawing to cutsomlasercutting.com and had the pieces cut. I then sanded the edges square (laser cutting bevels edges @ 1-2 degrees) and used tap plastic acrylic bonding cement to join the pieces.
Also a note in case some haven't noticed, there is a full 1080p video of the system and the build at the URL of the build (www.dennishelmar.com/flow) I recommend you download the video to watch but you can stream it by double clicking the frames :D
Howard
152 (0.03/day)
Hong Kong
kool, thx for sharing bru..
anyways, how much is the max volume of this reservoir? it looks so massive haha, approx 2-3liter???
one more question, if you don't mind, how did u fit your reservoir in the case? did u pre-drilled for screw or just sit the res there using adhesive material?
peace out~
Duke_GuRu
70 (0.01/day)
Originally Egyptian now I work in Riyadh, Kingdom
System Name Duke the F1rst
Processor AMD PhenomII X4 940BE @ 3.5GHZ
Motherboard ASUS M3A78-T Mobo
Cooling Modded ThermalTake Bigwater 770 + 745 kits
Memory 2x2GB OCZ Fatal1ty DDR2 Dual-Channel Kit
Video Card(s) Sapphire HD4890 1GB
Storage 1x160GB + 1x500GB + 1xTB + 1x500GB External
Display(s) 22" Widescreen BenQ Full-HD + 32" SAMSUNG LCD
Case Self-Modded GIGABYTE Aurora Full-ATX Case
Power Supply ThermalTake Toughpower 700W
Software Vista Ultimate 64-bit
you are the man; this is one of the best Mods i've ssen in my life.
as for Voting you are off the scale... but here 10/10
You should start your own business and if you do I'll be your Loyal customer LOL
ex-dohctor
112 (0.02/day)
South Africa
System Name Caspar.
Processor AMD Athlon 64Bit 4000+ (939).
Motherboard Saphire Pure Innovation PI-A9RX480.
Cooling Coolermaster Hyper 212 Cooler + 6 x 120mm CM Case fans.
Memory 2GB Kingmax - DDR 400.
Video Card(s) XFX ATI Radeon HD4650 512MB.
Storage 2X Seagate Baracuda 500GB SATA - II (32MB Cache).
Display(s) Samsung 19" LCD + Samsung 17" LCD.
Case Coolermaster Centurion 590 (Stock for now).
Audio Device(s) Onboard Audio.
Power Supply Gigabyte Superb 500W.
Software Windows XP Pro. SP3.
This is an amazing rig man!
2,270 (0.41/day)
the uk that's all you need to know ;)
System Name not very good (wants throwing out window most of time)
Processor xp3000@ 2.17ghz pile of sh** /i7 920 DO on air for now
Motherboard msi kt6 delta oap /gigabyte x58 ud7 (rev1.0)
Cooling 1 green akasa 8cm(rear) 1 multicoloured akasa(hd) 1 12 cm (intake) 1 9cm with circuit from old psu
Memory 1.25 gb kingston hyperx @333mhz/ 3gb corsair dominator xmp 1600mhz
Video Card(s) (agp) hd3850 not bad not really suitable for mobo n processor/ gb hd5870
Storage wd 320gb + samsung 320 gig + wd 1tb 6gb/s
Display(s) compaq mv720
Case thermaltake XaserIII skull / coolermaster cm 690II
Power Supply corsair hx 650 w which solved many problems (blew up) /850w corsair
Software xp pro sp3/ ? win 7 ultimate (32 bit)
Benchmark Scores 6543 3d mark05 ye ye not good but look at the processor /uknown as still not benched
nice set of wheels i mean case 9.9/10
very nice i want one
993 (0.15/day)
Los Angeles...U.S.A
Processor i7 920
Motherboard EVGA X58
Cooling eight 120mm fans, Swiftech GTZ cpu block, 3 120mm radiator, MCP655 pump, primochill tubing
Memory 6 gig G-Skill DDR3 1600
Video Card(s) GTX 285's (SLI)
Storage 500GB Western Digital
Display(s) 3 Asus 23 in inchers
Case Lian Li A77B
Audio Device(s) on board 7.1
Power Supply Corsair 1000
Software win 7 64
Wow. That is one very nice piece of hardware.....10/10
CyberDruid
2,887 (0.47/day)
On top of a mountain
System Name Shop Dog
Processor E8400
Motherboard Asus Blitz Formula SE
Cooling d-Tek FuZion
Memory 2 x 2GB DDR2 800 G Skill
Video Card(s) EVGA 7900 GTX
Storage 150GB VelociRaptor
Display(s) Acer 21.5 1080p LED Back Lit Monitor
Case Working on it
Audio Device(s) PCI SoundMax
Power Supply Silverstone 750 Modular
Software XP Pro SP2
Benchmark Scores Super Pi 11.56s 1M at 4050mhz
Excellent work all around man. Res looks super clean. And of course your photo skills sell the mod.
094145
71 (0.01/day)
voted 10/10 ............................................im speechless .............................................................................................................................................................................................................................................................................................................................................................................................
78 (0.01/day)
Dubai, UAE
System Name Haf nuebe tres dos
Processor AMD FX-8320 @ 4.62ghz
Motherboard Asus Sabertooth 990FX R2.0
Cooling Ek custom water-cooling
Memory Corsair Vengeance 4x4gb DDR3 @ 1600Mhz
Video Card(s) EVGA GTX 780 SC with ACX cooler
Storage Sandisk Extreme 120gb SSD, Toshiba 128gb SSD
Display(s) Samsung 22" LED 1080p
Case Cooler Master HAF 932
Audio Device(s) on board realtek hd audio
Power Supply Cosair TX850w
Software Windows 7 Ultimate 64bit, Windows 8.1
Benchmark Scores 3Dmark Vantage 42000+
i don't like it...i love it!!!!!!!!!!!!the rig that i'm waiting for to get finish..now it's completely done..stunning looks,great architecture..what more can i say,it looks amazing..great work ian..10/10(for sure)..
347 (0.06/day)
Jitra, Kedah, Malaysia
System Name KXa DrakeN
Processor Intel Core i7 3770k
Motherboard Asus Maximus IV Extreme-Z Z68 1155
Cooling NZXT Kraken X60
Memory 8GB Ripjaw-X Red 1866mhz
Video Card(s) 2X ASUS GTX780 DCUII OC
Storage Crucial M4 128gb+Intel 320 160gb Gen3+2TB BLack WD+1TB Black WD
Display(s) DELL S2740L 27'' LED LCD
Case NZXT Phantom 410
Audio Device(s) ASUS XONAR D2X
Power Supply Corsair HX1050wt
Software Windows 7 Ultimate SP1 64bit
that is too awesome bro.. i love it.... nice mod.. very sexy..10/10
101 (0.02/day)
Hungary Budapest
System Name Intensa 2008
Processor Intel Q6600 @ 2,4 Ghz
Motherboard Intel DX48BT2
Cooling Air Intel
Memory Apacer DDR3 10600 2*1Gb
Video Card(s) Asus 8800 GT 512 Top Edition
Storage WD Passport 160
Display(s) Samsung 203b
Case Toora Alu wheels 12*18" Glass Edition
Power Supply LC Power LC8750 V2.2 Prophecy
Software Win Vista
Benchmark Scores 3dMark 2006 11600
Very nice job, nice and clean !
10/10
bye
2,228 (0.36/day)
Larisa, Greece
System Name StarCruiser Dark Knight v.2
Processor Intel® Core™ i5-3570K
Motherboard P8Z77-V LX
Cooling 1x custom W/C loop/ inflow:6x120 /outflow:4x120, 2x200
Memory Viper 3 Black Mamba (4x4GB)
Video Card(s) Powercolor LCS 5870
Storage 1X 128GB OCZ, 2 x 1.500 Gb Seagate
Display(s) Samsung 24" LC24F396
Case custom MDF case (I BUILT IT) check sig.....NOW
Power Supply Tagan 900 watt
Software Win 7 RC / Open office / Games
perfect 10~ *speachless !!!!!*
582 (0.10/day)
System Name Flow
Cooling Water
Thank you all for your kind words!
922 (0.16/day)
London, UK
Processor AMD FX 8350 Black Edition @ 4.2Ghz
Motherboard Gigabyte 990FXA-UD3 Rev 4.0
Memory Samsung Green 16GB 30nm 1600Mhz DDR3
Video Card(s) XFX HD 7950 DD 3GB @ 850/5000Mhz
Storage 240GB Intel 520 SSD + 2TB Seagate Barracuda
Display(s) ASUS PB278Q 27" QHD
Case Fractal Design R5 Black
Power Supply Seasonic Platinum 760W
Mouse Corsair Raptor M40
Keyboard Corsair Raptor K50
just the best ive seen in this gallery so far :) awesome work
The_Real_DeaL31
692 (0.11/day)
canada
System Name Smooth as silk
Processor Phenom II x4 940 BE oced, 3.6ghz 1.5250v
Motherboard Asus M4A79 Deluxe 790FX
Cooling Cooler master v8
Memory OCZ 1066 MHz Platinum Series 4GB kit 5.5.5.15 2T 1141mhz
Video Card(s) Evga ssc 8800gt at stock p.o.s to hot to o.c
Storage Wd 76gb Raptor/Wd 500gb blue sata II, Wd 160gb sata II
Display(s) 20" Acer 2016wBdb widescreen 1600x1050
Case 120mm back/3x 80mm neon front/250mm side fan
Audio Device(s) realtek/logitech x540
Power Supply Corsair vx550 41amps 12v single rail
Software Winxp pro sp3/vista who lol?
Benchmark Scores 3dmark06 15216k
just beautiful lol, its probably the best i ever seen voted 10 !!!
