Project: XBOX Supreme
208 (0.04/day)
Hi members,
My name is Richard aka Kier. I've did some nice things in the past with cases
And I wanna share my ideas and skils with you guys. Some previous builds can be seen
on my site madebykier
My first build overhere is not gonna be an pc but an watercooled xbox
Hope you like it!!!
Sponsored by:
Presenting:
Hi fellow modders.
I was looking a long time for this Lian Li case, the PC-XB01
I knew he was EOL, but there is always someone who has this one.
So the search continued.
Did this case is really a beauty and offers quite a few opportunities because
Xbox is not really big and little more content, while the Lian Li is quite large.
It therefore offers opportunities for an expanded water cooling setup to installon the CPU and the GPU Proccesor.
After some research, I accidentally found a lovely Lili with a good friend:
Gnoom172.
Gnoom I owe you one
Also He had a nice Watercooling set for the Xbox. Which is very sweet, but too little for me.
I was then also noted by wwwicked a nice set from the famous Highflow shop ;)
It was the XBOX PRO Dual 40 Watercooling Kit
Also very nice. But for a large case like i have now it’s actually too small
So after some fitting and measuring, I found out that it is quite possible for the following parts:
EK-Multioption RES X2 - 250 Advanced
Laing DDC-1 MCP350 12V
Black Ice GT Stealth 120 Black
Nanoxia DX Series 120MM DX12
Hmm, I think the color combo is gonna be again black / green uv......I like it ;)
And 2 x a EK-Supreme HF Nickel CPU Block
The Supreme's will fit nicely. I just need to mod the brackets, but this will definitely be nice
With this beautiful List I went to Freddy, and Highflow is again prepared sponsor this build
Freddy / Highflow thnx again very much
To start with I have some photo’s taken from the beautiful Lili
These are the victims that I had left from a distant past. ;)
And I could not resist to test the little sweet set
With the set is nothing wrong, but would like some more extreme than this, what will succeed. I know it for sure.
So this is the start of a my new build.
Grtzzz. And to be continued
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Definitely subscribed, looks awesome!
7,180 (1.12/day)
Is that the innards of a xbox 360 S?
Looks cool btw.
EDIT: Okay its just premium 360s the old models.
2,954 (0.58/day)
One simple question; why?
The project looks cool and all, but the xbox finally has a decent cooling setup with the Jasper and later revision processors. Decreasing the temps even further will very likely extend the useful life of your xbox, but you'll probably spend twice the price of an xbox modding them into this case.
If you're running the hardware as a cheap server box I'll give you some credit. At the same time, an atom board can probably hang with the 360 in that type of processing (for a much cheaper price tag. If you're looking at a cheap desktop you can get more power from a sub $300 price point than you will if you sink $300 into the project (very likely considering case, cooling, and two donor boxes).
Why???
I look forward to whatever reason you come up with to justify this project. On the same token, I hope M$ doesn't flag your console as a cheater if you do attempt soomething as insane as overclocking. Best of luck.
208 (0.04/day)
Why???
I think one simple answer is in place.
The why question: why do guys like me mod? To make things nicer then they allready are
And to show off there skills. Also hopefully give people ideas for there projects.
I've done a lot of builds with pc's but I just wanted something differend and I always loved
the LiLi PC-XB01. These 2 xboxes i have are the older versions with the bad X-clamp thing.
Allready have the new one, so these where lying around.
It's not about overclocking or the costs, just to have fun to mod something in a way that not much people has done.
Thnx.
2,954 (0.58/day)
Thnx.
That's as good a justification as any that I can come up with for half the crap I do.
I obviously worded my thoughts poorly, and for that I apologize. What I had meant to ask was if there was a reason beyond "because I have the parts and can." Using an older xbox and aftermarket cooling just seemed like a substantial undertaking without an underlying plan for using it differently. Of course, I'm guilty of doing this kind of thing, just to see if I can, on several occasions.
As before, best of luck with the project. I hope if works out for you.
208 (0.04/day)
lol, not a problem
Don,t have to apologize, most of my mods keeps giving questions like "are you crazy?" ;)
Like you said "just to see if I can"
208 (0.04/day)
Update!!!
Today and yesterday got some very nice stuff in of my belgium neighbors and High Flow
Yes, I had some luck ............ Ac Ryan acryl still in there shop;)
Uv green rules ;)
The size of the side panel taken
And put some nice UV strips in the back
Both sides and just the right size
Placed the acryl and lights out
Also placed the sidepanel
And the effect is quiet nice
The other side is coming the same with some adjustments, transparent window and hole in the side panel.
And today got some nice stuff from Highflow
The Black Ice GT Stealth 120 Black radiator
A nice EK acryl top for the Laing DDC-1 MCP350
And the MCP350 pump
And my favorite fan, the Nanoxia DX 120MM DX12
Also not to forget, the 2 EK-Supreme HF Nickel CPU Blocks
Placed the EK acryl top
And this is what's coming in xbox
After all this picture taking, it's time to Dremel the bracket
marked the pieces
After some filing and grinding
And put it together again
Number 1
Both Supreme's side by side
That's it for now. Weekend is coming more ;)
Grtzzz.
2,704 (0.45/day)
System Name Dire Wolf IV
Processor Intel Core i9 14900K
Motherboard Asus ROG STRIX Z790-I GAMING WIFI
Cooling Arctic Liquid Freezer II 280 w/Thermalright Contact Frame
Memory 2x24GB Corsair DDR5-6600
Video Card(s) NVIDIA RTX4080 FE
Storage AORUS Gen4 7300 1TB + Western Digital SN750 500GB
Display(s) Alienware AW3423DWF (QD-OLED, 3440x1440, 165hz)
Case Corsair Airflow 2000D
Power Supply Corsair SF1000L
Keyboard Chuangquan CQ84
This is pretty awesome. I need to steal that acrylic idea for some of my plans...
MxPhenom 216
ASIC Engineer
13,116 (2.47/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
OMG this is awesome. I want to see the finished part. Awesome how you modded the HF block to work on the xbox.
6,560 (1.02/day)
System Name Vintage
Processor i7 - 3770K @ Stock
Cooling Scythe Zipang II
Memory 2x4GB Crucial DDR3
Video Card(s) MSI GTX970
Storage M4 124GB SSD// WD Black 640GB// WD Black 1TB//Samsung F3 1.5TB
Display(s) Samsung SM223BW 21.6"
Case Generic
Power Supply Corsair HX 520W
Software Windows 7
Now the acrylic really is something nice. I really like that a lot!
208 (0.04/day)
Update!!!
I found out that the radiator does not quite fit nicely. When i put him on the inside and place the fan on top it came too much into the case. So I moved him to the outside. First marked the holes for the fittings.
After drilling the holes placed the radiator
Placed BP Fittings
And placed the fan
Power on
I love the looks of the Nanoxia uv green
The total is still quite nice, the radiator is pretty slim. But not finished, something beautiful is coming my way from Mnpc , but that’s classified
I also have painted the mounting hardware for the dvd and hdd black
And I’ve started to work an the other side. In this I want the uv green edge back again. So again sawn another piece of green
And then mod the original panel
The intention is that there is a window in the same shape as the original
Tape on both sides .....
Draw some lines
And after some cutting and filing:
Tape off and he's done.
Now it is obviously not good to have a green window. Windows should be transparent, no color allowed. Therefore I used the green plate and did some more cutting
First, mark and drill holes in the corners for the jigsaw
And again some sawing
First I placed and fixed with bolts to put everything in place
After that I had a mold for the transparent acryl.
And the result
And put everything in place. All that work for a green edge, lol
But I like it
And the window just transparent
Total shot...........you like?
Next update, I’m gonna let you see the loop of the water cooling ;)
See you then, I hope
Grtzzz.
208 (0.04/day)
Update 30-05
Here we go again....update time
Had the tray of the Xbox board disassembled and painted it black
This is better than the aluminum look.
Exchanged the original rivets for black ones
scotch tape on it from damage the paint
Nice flat and black
Also did some brainstorming for the window and got some nice ideas presented. I am going to try engraving this time.
So after some practice and see some movies
http://www.youtube.com/watch?v=wSguz5c56Zc
For the lines I use a diamond point bit
And for coloring / Shadow effect I used a diamond tip
First some practice on a scrap piece and then ............. the real work
with a steady hand you'll do quite well. The first angle
In the dark, and an LED strip behind
And yesterday, the second part done. Pretty funny this engraving ;)
And that was the update for now......you like it? I know I did
Grtzzz.
AsRock
TPU addict
19,200 (2.97/day)
UK\USA
Cooling D15
Cool, although i cannot see the point with water cooling. I would like it more if it was just air cooled as what was wrong really with consoles is the boxes that they are in.
Would like to see a PS3 version done just for the fact they get stinking hot..
Bo$$
Lab Extraordinaire
5,656 (0.98/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
that is frickin' epic modding!
1,109 (0.18/day)
Greenville, NC
System Name Champ's 1440P Rig
Processor Intel i7-4770K @ 4.6 GHz
Motherboard AsRock Z97 Extreme6
Cooling Corsair H60
Memory Corsair Vengeance 16GB 1600 Mhz 4x4 Blue Ram
Video Card(s) Nvidia 1080 FE
Storage Samsung 840 Evo 256 GB/RAID 0 Western Digital Blue 1 TB HDDs
Display(s) Acer XG270HU
Case Antec P100
Power Supply Corsair CX850M
Keyboard TT eSports Poseidon
that damn thing is bad. Some people don't see the point, but it like me with my car modding hobby with rims, paint and ground pounding stereos. Its what ever makes you happy and it gives you a way to express yourself.
2,863 (0.47/day)
Brasil
System Name Sovereign // HTPC
Processor i7 3770k 4.2 // i7 3770k 4.2
Motherboard Maximus V Gene // Sabertooth Z77
Cooling Noctua D14 // Intel HSF
Memory 16GB Samsung // 16GB VengeanceLP
Video Card(s) Deciding // 660 DC2
Storage OS (X25-M), Data (Seagate 1TB) // Samsung 840 120GB & bunch of drives
Display(s) Samsung T240HD // LG TV
Case TJ08e // Grandia GD08
Audio Device(s) DT880 Pro 250 ohm // TV speakers
Power Supply Seasonic Plat 1000 // Seasonic Gold 760
Software Windows 8 Pro x64 // Windows 7 Pro x64
Put the rad and fan inside man!
208 (0.04/day)
It's not the why? It's the how ;)
Thnx!!!
Your absolutely right
It was the first plan, but do not have enough space next to the board
208 (0.04/day)
Update 02-06
Today did the final touches to the engraving. Like this engraving thing
we gonna do this often ;)
The black painted parts are also placed back
And I was brainstorming for the watercooled components. Pump and the 250mm Reservoir
The EK Supreme's with BP fittings
Reservoir next to it
We fill under the xbox drive. This gonna make a plate with a hole for reinforcement
He goes from the pump in to the first block
And from the second block he goes into the radiator, and from the radiator back to the reservoir.
And two last pictures of the hardware with window
This is it!!!
Grtzzz.
2,704 (0.45/day)
Amazing work. Next update plz!!
Wile E
Power User
24,318 (3.61/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
208 (0.04/day)
Update 04-06
Just a hardware update. Yesterday I received from a friend (thanks Marco) a second-generation Xbox, with a Falcon Xenon GPU on board.
The layout of the PCB is also some different and better looking, it is much cooler and therefore less likely to give the RROD.
Old PCB:
further in the update photo's of the new print
On the this new board are placed some capacitors, where some data is printed on
To have a nice clean print I get the caps cleaned with acetone and after some brushing the become quite clean
I've also been busy with the tubes. From pump to the first EK Supreme
And from the first to the second block by BP rotery and multi-link adapter + Custom acryl tube
And from the second block to the black ice 120mm radiator with Tygon R3603 tubing
First part is finished.
From the output of the radiator to the reservoir
And the loop is ready for use
As you can see the new print varies somewhat with the old, and is much cleaner.
Have a nice weekend!!!
Grtzzz.
2,047 (0.36/day)
Republic of Texas
Processor R9 5950x
Motherboard Asus x570 Crosshair VIII Formula
Cooling EK 360mm AIO D-RGB
Memory G.Skill Trident Z Neo 2x16gb (CL16@3800MHz)
Video Card(s) PNY GeForce RTX 3090 24GB
Storage Samsung 970 EVO Plus 1TB NVMe | Intel 660p 2TB NVMe
Display(s) Acer Predator XB323QK 4K 144Hz
Case Corsair 5000D Airflow
Audio Device(s) Objective2 Amp/DAC | GoXLR | AKG K612PRO | Beyerdynamic DT880| Rode Pod Mic
Power Supply Corsair AX 850w
Mouse Razer DeathAdder Elite V2
Keyboard Corsair K95 Platinum RGB "Cherry MX Brown"
VR HMD Oculus Rift
Software Window 11 Pro
2,704 (0.45/day)
Very clean looking loop. Nice!
