PS2 Memory
Beatie3:16
4 (0.80/day)
1st post!
I love playing wwe smack down Here comes the pain. I’ve created numerous wrestlers on it but had to spread them across a number of memory cards. Is there away I can save/merge multiple cards together?
12,498 (1.91/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
First, welcome to TPU!
Second, not sure what you mean by merging cards. You can get card readers that support more than one card at once. Or you can buy a card with a bigger capacity, then copy the files from the smaller cards to the bigger card.
Beatie3:16
4 (0.80/day)
Cheers, I’ve tried using a card with more capacity but the game still only allows me to us 32 of the created characters.
12,498 (1.91/day)
Nebraska, USA
Mouse Logitech M190
Oh. Ok. Then I don't see that as a hardware "problem" but a limitation (feature?) of the program. And it is not something I can help you with. I think your concerns would get more helpful attention in a different forum. Let me see if I can get the attention of mod who will move it to a better place. It should not take long.
Ruru
S.T.A.R.S.
11,498 (2.72/day)
Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Motherboard Gigabyte B550M Aorus Elite
Cooling Alphacool Eisbaer w/ 2x 240 rads
Memory 32GB Kingston HyperX Fury DDR4-3466
Video Card(s) Asus GeForce RTX 3080 TUF w/ EKWB FC
Storage ~4TB SSDs + 6TB external HDDs
Display(s) Acer 27" 4K120 + Lenovo 32" 4K60
Case Define Mini C
Audio Device(s) Asus TUF H3 Wireless
Mouse MX518 og
VR HMD Oculus Rift CV1
Benchmark Scores It runs Crysis remastered at 4K
-do you have multiple cards
-do you have OEM or some third party "multi-page" cards
I'd do what I always do, I'll have only one save at a time. I still play PS2 as well myself. Just got a lot of games, paid 50EUR and they're worth of 360EUR. :)
Silver soft-modded PS2 with a component cable. Two OEM controllers, two OEM memorycards and a 200GB HDD (2nd memory card has the softmod shit etc).
Beatie3:16
4 (0.80/day)
Cheers pal
6,634 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW | Sapphire PULSE RX 590
Storage Various
Display(s) PIXIO IPS 240Hz 1080P
Software XP/7/8.1/10
You can buy an offbrand card they go up to 128 mb
so buy put in 2nd slot transfer save over and repeat with other saved wrestler caws/cards
Ruru
S.T.A.R.S.
11,498 (2.72/day)
Finland
Case Define Mini C
Mouse MX518 og
Is it just me but I don't trust those cards
6,634 (1.46/day)
Florida
Storage Various
no one does but for experiments its ok he has original copys still
I believe some of the modern cards are made better. You can probably make your own now since everyone makes pcbs now.
$10 on amazon go crazy
Beatie3:16
4 (0.80/day)
Excuse my ignorance but can you please explain the last paragraph in layman’s terms? Cheers
6,634 (1.46/day)
Florida
Storage Various
You can play games off of harddrives/usb sticks basically. I have a 1tb drive with 250 games. its a deep rabbit hole many ways to do this. youtube freemcboot/freehdboot
Ruru
S.T.A.R.S.
11,498 (2.72/day)
Finland
Case Define Mini C
Mouse MX518 og
I mean, I saw already in the 90s that my friend's "multi-page" card corrupted saves from time to time
I prefer only OEM Sony cards. Works hella great as I have even McBoot softmod on a Sony card.
Yep. Though having a fat PS2 is practically a must if you want to play from HDD
I have "only" a 200GB drive.
