Ps3 Controller having random DPAD inputs
1,491 (0.93/day)
System Name Chip
Processor Amd 5600X
Motherboard MSI B450M Mortar Max
Cooling Hyper 212
Memory 2x 16g ddr4 3200mz
Video Card(s) RX 6700
Storage 5.5 tb hd 220 g ssd
Display(s) Normal moniter
Case something cheap
VR HMD Vive
My ps3 controller is having random DPAD inputs
Most noticable in forza 7 and 4
Using SCPS driver to use on a pc
*PS3 is currently not working so cant test it*
364 (0.29/day)
Maybe your joystick switches are worn out , they have a limited lifet
isit more noticeable in one direction compared to others?
734 (0.16/day)
Malaysia
System Name Cypher-C4
Processor Ryzen 9 5900X
Motherboard MSI B450 Tomahawk Max
Cooling Deepcool AK620
Memory 32GB Crucial Ballistix Elite 3200MHz
Video Card(s) Palit RTX 3060 Ti Dual
Storage 250GB Crucial MX500 + 2TB Crucial MX500 + 2TB WD Black + 4TB Toshiba + 1TB Samsung F3
Display(s) Acer XV272UP
Case Corsair Obsidian 750D
Audio Device(s) Behringher UMC202HD Audio Interface + Mackie HM-4 + Sennheiser HD 280 Pro + Shure SM58
Power Supply Corsair HX750i
Mouse Steelseries Rival 310
Keyboard Keychron K8 + Kailh BOX Crystal Jade switches + Ducky Good in Blue keycaps
He said it's the D-Pad.
474 (0.31/day)
System Name Dusty
Processor 5900x
Motherboard MSI B550 Tomahawk
Memory Corsair Vengence LPX 32GB
Video Card(s) MSI RTX 3070 Gaming X
Storage yes
Case Fractal Design Define R6
Power Supply EVGA SuperNOVA 750w
VR HMD Oculus CV1
if i recall, this is not a uncommon problem with the DS3 controllers. They have a ribbon cable thats held/pressed in to place with a small piece of foam, which degrades over the years.
So open it up and give it a good service and possibly replace said foam with something else.
364 (0.29/day)
I didn’t pay attention, well for Dpad same story, switches have a limited amount of clicks , ps3 is quite old I guess time to change the switches
43,276 (6.74/day)
The switches are like what is seen on a membrane keyboard, the pcb would need repair or replacement. Just buy a new controller
1,491 (0.93/day)
System Name Chip
Processor Amd 5600X
Cooling Hyper 212
VR HMD Vive
i followed this advice and cleaned all the pins and stuff
and it seems to have fixed the problem
in the event i need a new controller what ones do you recommend for a pc?
80 (0.06/day)
United States
Processor Intel i7 2600k @ Stock
Motherboard Asrock Z68 Pro 3
Cooling Corsair A70
Memory 16GB DDR3
Video Card(s) Nvidia Geforce GTX 970
Storage 1x Samsung 860 Evo 250GB, 2x WD 1TB HDD
Display(s) Samsung 2253BW
Case Silverstone RL06
Xbox 360 or Xbox one controllers work really well for PC. No need for external tools. Just plug and play.
