- Jul 15, 2020
- 996 (0.65/day)
System Name | Dirt Sheep | Silent Sheep |
Processor | i5-2400 | 13900K (-0.02mV offset) |
Motherboard | Asus P8H67-M LE | Gigabyte AERO Z690-G, bios F29e Intel baseline |
Cooling | Scythe Katana Type 1 | Noctua NH-U12A chromax.black |
Memory | G-skill 2*8GB DDR3 | Corsair Vengeance 4*32GB DDR5 5200Mhz C40 @4000MHz |
Video Card(s) | Gigabyte 970GTX Mini | NV 1080TI FE (cap at 50%, 800mV) |
Storage | 2*SN850 1TB, 230S 4TB, 840EVO 128GB, WD green 2TB HDD, IronWolf 6TB, 2*HC550 18TB in RAID1 |
Display(s) | LG 21` FHD W2261VP | Lenovo 27` 4K Qreator 27 |
Case | Thermaltake V3 Black|Define 7 Solid, stock 3*14 fans+ 2*12 front&buttom+ out 1*8 (on expansion slot) |
Audio Device(s) | Beyerdynamic DT 990 (or the screen speakers when I'm too lazy) |
Power Supply | Enermax Pro82+ 525W | Corsair RM650x (2021) |
Mouse | Logitech Master 3 |
Keyboard | Roccat Isku FX |
VR HMD | Nop. |
Software | WIN 10 | WIN 11 |
Benchmark Scores | CB23 SC: i5-2400=641 | i9-13900k=2325-2281 MC: i5-2400=i9 13900k SC | i9-13900k=37240-35500 |
Yep, that's the whole idea. Less pins, less space.The 12vhpwr has less voltage pins man, the 8pins cable standard was overbuilt. You could literally power a 350w card with one single connector that splits off to 2x6+2pins.
12vhpwr will not pull more than 600w unless molded, but it sure can.
If you bend the wire near the connector you can result in over pressure that can cues such burn phenomena.
Interesting to know what was the reason in this case.
Right.I am reading on the internet people saying that this is a user error, but I believe it is not. There was never a case in the past where you have to be careful with a power cable, so how is this a user error? People never had to even consider something like this and even if the cables come with a warning on the installation manual, do even people know when the cable is bent more than it should? People are not engineers.
I agree that it is more a location problem on the GPU (and the size of it causing you to be space-limited) and the use of the adaptor that make space for maneuver even smaller than problem with the 12VHPWR spec.Is anyone surprised?
Going from 24-Pin (3x 8-Pin) to 12-Pin with 50% smaller terminals delivering the same 450 Watt.
Now in a perfect world that may be fine, but the bending of the pins can't be avoided with the current design.
There is no problem to engineer such pins that can stand the current\voltage. Also, only 3 of the 8pin are for voltage. So it`s 3*3=9 total. Not 24...
FYI, 12VHPWR have 6 voltage pins. see pic.
We need to ask about this incidence circumstance and not only bash the 12VHPWR brain out.
