PSU's For Crunchers ??
2,312 (0.35/day)
Norn Iron
Processor Q9550 @3.8
Motherboard Asus Maximus Extreme
Cooling Custom water cooling
Memory 4GB Patriot Viper DDR3 1600MHz
Video Card(s) 2x HD4870 512MB
Storage 2x 500GB
Display(s) 3x LG L226WTQ 22" Widescreen LCD
Case Modded TJ07
Audio Device(s) On board
Power Supply PC P&C Silencer 750
Software Windows 7 Ultimate
I am looking for some input on a good PSU to run my crunching rigs with.
The rig's will mainly be-
Q6600
maybe a low end GPU (9600GSO or something)
and the usual HDD,fans etc
So I would like to get a couple of PSU's for my rigs and would like some idea's.
Would like 80%+ efficiency if possible and probably ~400W
So any thoughts, throw them out here :)
EDIT: And another thought, reliability would be good as well :)
2,312 (0.35/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
I just setup a "scrap yard" cruncher with similar specs and used this PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817171031
Works great and at a decent price.
Here's how it worked out for me - http://www.realredraider.com/vbulletin/showpost.php?p=34011&postcount=64
Like the cheap case ;)
Do you know if that PSU is 80+% efficient ??
I want to keep the power bills down as much as possible.
Anyone heard of Powercool PSU's before ??
EDIT:I see it is 70%+ efficiency...but will keep in mind.
Baleful
112 (0.02/day)
The 80% efficiency rating on PSU's won't make a difference in the amount of electricty consumed. I could be wrong on this, but if you take and compare two PSU's, one being 70% efficient, the other being 80% efficient, your rig will consume the same amount of electricity on both PSU's. The 80% efficient PSU just handles it's power better.
2,312 (0.35/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
Ahh I thought with it handling it's power better that you then used less draw at the wall.
I am clueless on this :), so cant hurt to try and learn more on this subject.
Baleful
112 (0.02/day)
I could be totally wrong here, I don't think I am but the possibility is there :p
From the way I understand it is, your machine consumes XX amount of electricity. Whether you have a PSU that is 90% efficient, or 60% efficient, you still consume XX amount of electricity. However, the 90%/80% just handles it's rails/load much better than the others.
2,259 (0.38/day)
System Name Budget AMD System
Processor Threadripper 1900X @ 4.1Ghz (100x41 @ 1.3250V)
Motherboard Gigabyte X399 Aorus Gaming 7
Cooling EKWB X399 Monoblock
Memory 4x8GB GSkill TridentZ RGB 14-14-14-32 CR1 @ 3266
Video Card(s) XFX Radeon RX Vega₆⁴ Liquid @ 1,800Mhz Core, 1025Mhz HBM2
Storage 1x ADATA SX8200 NVMe, 1x Segate 2.5" FireCuda 2TB SATA, 1x 500GB HGST SATA
Display(s) Vizio 22" 1080p 60hz TV (Samsung Panel)
Case Corsair 570X
Power Supply Seasonic X Series 850W KM3
If its just a Q6600...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151057
Cause i like quality stuffz.
Efficiency... lol.
You machine uses 300W.
Your PSU is rated at 85% efficiency.
Add 15% of 300W to the total to get the draw from the wall.
Your machine uses 300W.
Your PSU is rated at 70% Efficiency.
Add 30% of 300W to get the total draw from the wall.
Thats efficiency.
2,312 (0.35/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
So really the 80+ would only help if your system was nearing the limit of the PSU, it would be able to handle the load better than one with less efficiency.
2,312 (0.35/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
4x4n
Xtreme Refugee
558 (0.10/day)
Seattle
Processor 3950x
Memory 4x8gb Corsair Dominator
Video Card(s) Sapphire Nitro RX580
Storage Adata XPG SX8200 Pro
Display(s) Asus 24"
Case Phanteks Evolve X
Power Supply Seasonic 650
One of the best psu's for the price is the Antec EW 500. They can be had for around $50 bucks. I am using 2 of them with Q6600's and 8800GT's running 24/7.
2,312 (0.35/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
Thanks 4x4n, will take a look at those as well.
All seem to be around the £50/$75 mark for these PSU's :(
4,213 (0.72/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
You kindof correct. The "system"will consume more electricity due to 10% of the energy being wasted. But the components will consume the same amount of electricity.
I don;t know if you'd be able to find them where you are, but i'd recommend AcBel PSU's. They have 80% efficiency models and are generally cheaper than most big name brands
Usually the "Efficency" of electrical components is talking about Electricity in vs. out. ex: 1000w in 800w out would be 80% efficient.
2,312 (0.35/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
Never heard of AcBel before.
And they dont seem very popular here, as there are very few for sale that I see.
4,213 (0.72/day)
Vietnam
They are an oem manufacturer. They only make PSU and they make them for the big-brands who label them. Usually cost about 70% of the price for the same product.
http://www.compucon.com.au/acbel/acbel.htm - Here's a linky
2,312 (0.35/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
Any I can find are IBM/AcBel models but only very few and 100-200W models.
But thanks anyway.
4,213 (0.72/day)
Vietnam
But thanks anyway.
No worries, they aren;t that widespread. I'm guessing they're easier to find in asia as this is where they are based.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.46/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
If I were you, I'd pick up an Enermax MODU82+ 525w ($90 after mail-in-rebate). Once you go modular, you don't go back. ;)
2,312 (0.35/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
I have two Enermax PSU's, just not the new ones, and love them.
Only thing that PSU is £80/$120 here in the UK...damn ...wish we could order from the egg
EDIT: For any UK readers, Enermax's RMA is amazing..they had my new PSU out to me within 5 days of me sending mine off :)
3,505 (0.61/day)
Another vote for Antec. With Q6600, 350w one should be fine with just a 9600GSO. We aren't talking about main rigs or anything big, so better get the cheapest while maintaining efficiency.
2,312 (0.35/day)
Norn Iron
Storage 2x 500GB
Case Modded TJ07
Well I just snagged a Coolermaster 460W for £25, will do for just a cruncher rig :rockout:
+1 on the Antec's, running a 850W Signature range on one of my main rigs and really like it.
Now to see if I can get any other good deals out there :)
Thanks for all the help guy's, keeping an eye out for all the ones mentioned.
