Puget Systems Releases CPU Failure Report: AMD CPUs Achieve Higher Failure Rate Than Intel 13th and 14th Generation
AleksandarK
2,476 (0.95/day)
A fleet of recent reports have highlighted stability issues affecting Intel's 13th and 14th-generation desktop processors, raising concerns among consumers and industry professionals. The problem, which has gained significant attention over the past few months, is related to the processors' physical degradation over time. Custom PC builder Puget Systems has shared insights from its experience with these processors, revealing a nuanced perspective on the issue. While it has observed an increase in CPU failures, particularly with the 14th-generation chips, its failure rates remain notably lower than those reported by some game development studios and cloud gaming providers, who have cited failure rates as high as 50%. An interesting observation is that Puget Systems recorded a higher failure rate with AMD Ryzen 5000 and Ryzen 7000 series than Intel's 13/14th generation, with most failures happening at Puget's shop rather than the "field" in customers' hands.
Puget Systems attributes their more modest failure rates of Intel processors to their conservative approach to power management settings. By adhering strictly to Intel's specifications and developing their own power settings that don't hurt performance, they've managed to mitigate some of the stability issues plaguing other users. Intel has acknowledged the problem and announced plans to release a microcode patch by mid-August, with extended warranty program. This update is expected to prevent further degradation but may not reverse existing damage. Despite the elevated failure rates, Puget Systems' data shows that the issue, while concerning, still needs to be at critical levels for their operations. The company reports that failure rates for 13th and 14th gen Intel processors, while higher than ideal, are still lower than those they experienced with Intel's 11th gen chips and some AMD Ryzen processors. In response to the situation, Puget Systems is taking several steps, including maintaining its current power management practices, promptly validating Intel's upcoming microcode update, and extending warranties for affected customers. Below, you can see failure rates by month, by Intel's Core generation, as well as by "shop" vs "field" testing.
Low quality post by Sabotaged_Enigma
459 (0.32/day)
Earth, Solar System, Milky Way Galaxy, Local Group
Processor AMD Ryzen 7 5700X
Motherboard Asus TUF Gaming B550M-Plus (Wi-Fi)
Cooling Thermalright PA120 SE; Arctic P12, F12
Memory Crucial BL8G32C16U4W.M8FE1 ×2
Video Card(s) Sapphire Nitro+ RX 6600 XT
Storage Kingston SKC3000D/2048G; Samsung MZVLB1T0HBLR-000L2; Seagate ST1000DM010-2EP102
Display(s) AOC 24G2W1G4
Case Sama MiCube
Audio Device(s) Somic G923
Power Supply EVGA 650 GD
Mouse Logitech G102
Keyboard Logitech K845 TTC Brown
Software Windows 10 Pro 1903, Dism++, CCleaner
Benchmark Scores CPU-Z 17.01.64: 3700X @ 4.6 GHz 1.3375 V scoring 557/6206; 760K @ 5 GHz 1.5 V scoring 292/964
Suspicious Intel-sponsored content...
152 (2.05/day)
May I ask someone who can dig this information up please?
I just wondered how long the warranty period or bring in time is for that hardware?
I doubt someone bring in a device which costs your own money to fix. I assume that 10th/11th Generation Intel is long out of warranty. That's why it does not show up anymore in 2023 / 2024 basically.
If it were my own 9th or 10th generation Intel platform, I would maybe sell the mainboard and the RAM and move on.
I think those graphs miss some important information. How long is the maintenance / service / warranty period for the hardware in question. (applies to all of those graphs)
the54thvoid
Super Intoxicated Moderator
12,908 (2.38/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
For those who seem more interested in graphs than reading the content, here's the reason for their low Intel failure rates. Puget, after the 11th gen issues, started:
In other words, they don't follow default motherboard settings and instead apply ones which avoid the voltage problems caused by the microcode.
11,868 (5.65/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
So basically, all of the systems had Puget's own conservative power settings applied instead of the BIOS default. That's how you fabricate statistics, congratulations! :shadedshu:
4,930 (0.75/day)
Hong Kong
Processor Core i7-12700k
Motherboard Z690 Aero G D4
Storage Plextor M10P 2TB
Display(s) InnoCN 27M2V
Case Thermaltake Level 20 XT
I guess this means they running settings that are even more conservative than SuperMicro, who does pretty much everything by the book?
Because there are Raptor Lake CPUs that have degraded even when ran well within Intel's spec.
148 (0.22/day)
The results Puget systems has aren't in line with most other sources because they aren't using the Intel baseline specs that Intel insisted was fine while the blame was thrown at motherboard makers, even though Intel knew what was happening since 2022.
I don't get why this post was made, the issue at hand is even with Puget using their own settings there is still an increase of failures in their graphs. And the whole point of GN bringing up the graph was to show higher than normal failure rates.
200 (0.14/day)
Yes lacks context, for example might be using 10 times more AMD CPU's than Intels.
The graph uses percentages...
They follow Intel's guidelines as best as they can. That's what Intel should mandate from the start instead of auto-OCing all their CPUs from the start.
3,296 (0.81/day)
Athens, Greece
Memory 32GB - 16GB G.Skill RIPJAWS 3600+16GB G.Skill Aegis 3200 / 16GB JUHOR / 16GB Kingston 2400MHz (DDR3)
Storage NVMes, ONLY NVMes/ NVMes, SATA Storage / NVMe boot(Clover), SATA storage
This seems like damage control from Puget, no sample size listed or what SKU's of Ryzen processors are failing.
The timing, the fact that they had never bothered publishing failure rates before(have they?), especially when 11th gen was failing at such higher rates, does point in that direction.
11,868 (5.65/day)
Midlands, UK
Yes, should... but they don't.
3,296 (0.81/day)
Athens, Greece
So basically, all of the systems had Puget's own conservative power settings applied instead of the BIOS default. That's how you help Intel's argument that the problem is with voltages only, so a firmware can fix it, congratulations! :shadedshu:
Just another theory.
152 (1.90/day)
No mention of them doing the same for amd, so the comparison isn't completely fair. A portion of those failing amd cpu's could have been prevented from developing issues were they equally conservative with power settings for amd too.
side note: 11th gen seems like an absolute dumpster fire.
Don't know what the situation is on the amd side, but I can attest to intel board manufacturers pushing way more volts than needed. My 490 board applies 1.37v to stock 10700 in normal/auto modes, but the cpu only needs 1.25v manual voltage to pass stress tests.
59 (0.04/day)
So with 'conservative approach to power management settings', 'their own power settings' and presumably much better cooling than average (custom made workstations) - so far from default compared to most users, both prebuilt and DIY - they report comparable total failure rates to other CPUs that were on the market three or four times longer (while 14th gen degrades over time)?
Surprise, surprise. Nothing wrong with 14th gen, definitely nothing to see here, move along... /s
I'm suprised the OP does not mention Puget's other statements, like:
'The concern for the future reliability of those CPUs is much more the issue at hand, rather than the failure rates we are seeing today.'
'We're seeing ALL of these failures happen after 6 months, which means we do expect elevated failure rates to continue for the foreseeable future and possibly even after Intel issues the microcode patch.'
3,433 (1.65/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
I dont see the issue here, the article clearly states the bios configuration was done in a safe way to keep CPU's within safe tolerances.
I do the same on my own systems. I check if board vendor has voltages out of spec (usually is the case with ASRock), I check power levels, I check if safety features are enabled and so on.
They havent claimed this is out of the box experience, it is data "after" they have applied their own adjustments.
478 (0.59/day)
Note the "shop" vs "field" difference. AMD CPUs fail more often in their shop when they are trying to apply their own overclocking or whatever, Intel CPUs fail more in the field ie. when used by users. AMD has a lot lower failure rates in the field, where they fail more is when Puget Systems are setting them up.
So yeah, damage control.
1,648 (0.80/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
Intel data has timeline, but AMD data doesn't.
Wonder why.
335 (0.49/day)
NYC
System Name GameStation
Processor AMD R5 5600X
Motherboard Gigabyte B550
Cooling Artic Freezer II 120
Memory 16 GB
Video Card(s) Sapphire Pulse 7900 XTX
Storage 2 TB SSD
Case Cooler Master Elite 120
Ahh, Puget, the vendor that refused to use Ryzen cpus and when they finally started selling them, their “Configuration assistant “ always ended suggesting an Intel cpu.
Better yet, if their claims are true, how come nobody else experienced such a huge number of issues with their AMD cpus outside Puget?
I will admit, this intel collapse (thank you karma!) is really showing the rabid fanbois, bribed influencers and especially, the white knights which are out in full force doing damage control.
Adding the DOJ investigation on Ngreedia plus the conveniently and sudden delay on their new AI chips, the other side will also be super busy.
Meanwhile … :)
148 (0.22/day)
Exactly, something doesn't seem right unless Puget does publish failures rates, I don't really care what their rates are as they are using different settings than what most other companies are. The timing of Puget publishing results seems like they're looking to defend Intel and trying to keep customer confidence in buying Intel systems, though them going "but AMD!!!!" seems like a deflection tactic, given how desperate Intel has gotten with changing statements after the tech press has already reported on the issues I wouldn't be surprised if there is paid damage control.
I came across some stats from Puget systems on r/hardware, Puget sold about 70-80% Intel systems in 2023.
Yes they should have, but didn't and chose to push their cpu's past the limit to beat AMD, according to Buildzoid talking to someone hosting Minecraft severs with 14900K cpu's, the failure rates drop from around 30% to 5% by disabling TVB, though by disabling TVB the CPU is no longer running at the specs Intel claims its capable of but that is a whole other issue.
1,648 (0.80/day)
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
We 've discussed this for numerous times already.
From Intel's own public materials
Intel only enforce minimum and max values,
The 'Recommended value' is always 'N/A'
Some even had their minimum values 'N/A'
So there is basically no 'guideline' from Intel regarding CPU voltage, anything below maximum are 'in-spec'
3,433 (1.65/day)
UK, Midlands
System Name Main PC
Processor 13700k
The default settings are decided by the board vendors.
Intel's mistake was giving them the freedom to do that.
3,296 (0.81/day)
Athens, Greece
CPUs and GPUs needing less voltage to pass stress tests is not unusual. The oldest example I have is in my sig where I mention that I have a mobile "Core2Duo undervolted at 1.0125V down from 1.188V". Another example was my 6 core Phenom II that had a typical voltage of 1.32V for 2.8GHz and it was doing 3.5GHz with 1.28V. Going Ryzen I stopped messing with voltages, but i guess the situation is the same.
Companies push more voltage to be sure that the CPUs that will get on consumers hands will be stable. I think almost everything can be undervolted and still work just fine, except in case it is a mediocre sample.
3,350 (2.43/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
