Pump leaking
533 (0.12/day)
Processor i7 6900k @ 4.3GHZ
Motherboard MSI X99A Godlike Gaming Carbon
Cooling CPU/GPU loop with 480mm and 360mm radiators
Memory 32GB Corsair Dominator 3000MHz C15
Video Card(s) 2x EVGA 1080 SC ACX @ 1830/1330
Storage Samsung 950 Pro M.2 512GB, WD 2TB Black HDD
Case Corsair 900D
Power Supply EVGA 850W Gold 80 plus PSU
Hey guys, So i've now got my watercooling loop fully set up. However, when I went to do a leak test all was good for about 4 to 5 minutes until the pump started leaking from the back. I tried turning the pump speed up and this only increased the leaking. Do you think the pump if just defective?
12,062 (2.68/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
Is the leak coming from the pump, or from the fitting you have screwed into the pump?
Futher if it's from the fitting, is it leaking from weak pressure from the tubing, or not screwed in tight/dodgy thread?
533 (0.12/day)
Case Corsair 900D
It is coming from the back of the pump, definitely not the tubing screwed on to the pump; the tubing is all very tight and I used multiple cable ties to ensure it was tight.
EDIT: I should also note that I literally just took the pump out of the box and put it in my system (Didn't do anything else to it or with it.)
9,871 (1.88/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
its from the pump, rma it
12,062 (2.68/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
If the pump casing is compromised and is leaking then it's time to do an RMA.
533 (0.12/day)
Case Corsair 900D
Alright, thanks guys, will do that.
533 (0.12/day)
Case Corsair 900D
Just have a quick question; Is this too much/not enough thermal paste for my 4930k (I just have to check with my OCD :p) - http://imgur.com/c17FW2v
12,062 (2.68/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
533 (0.12/day)
Case Corsair 900D
533 (0.12/day)
Case Corsair 900D
What would you also say is the best method? Just a line down the centre or a circle in the middle?
12,062 (2.68/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
Imagine the shape of a pea that's been squished together slightly on it's sides, AKA grain of rice.
533 (0.12/day)
Case Corsair 900D
Yeah thats good.. did ya have the shakes applying the paste lol
Hahah I was a little nervous, but I had to do it an awkward angle, around the tubing :p So you think that amount is fine?
12,062 (2.68/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
The original picture? probably a bit too much of a long line and won't spread properly.
