Justavideoguy
- Dec 12, 2024
- 1 (1.00/day)
Looking for advice, recommendations, and insights on a video editing PC build
Questions:
Am I missing anything?
How is the stability for the parts selected together?
Would the parts selected be considered easy ones to install together?
Will the high amount of RAM be read/problematic with these parts selected?
Should ECC ram be used instead?
Could use a suggested good, valued GPU that is in stock?
Should I be considering something else especially considering its specific use case (video editing)?
Any recommendations?
Build:
Use:
The computer is intended to primarily be used for video editing only (no gaming or anything else).
Footage edited is (4K, 120p (FPS), 4:2:2, 10-bit, 600Mbps/75MB/s,)
Effects applied: Greenscreen, Adobe AI voice enhance, some light Color Grading.
Listed in order of priorities.
1. Stability - A stable system is more valued than a faster performing computer.
2. Ease of building - Not a pro builder and hoping not to turn this from a short term to a long-term project build due to complications.
3. Longevity - The system will likely end up having a longer timeline than average before the next upgrade.
Recommended information to provide to forum.
Budget: 5-$6K United States
PURPOSE OF THE BUILD: Primarily for Video Editing using Adobe Premiere Pro.
Do use the Adobe Creative Cloud including some After Effects, Photoshop, Photoshop's AI, Illustrator, Cinema Grade, and various plug ins, and MS Office (Word, Excel).
ITEMS YOU NEED/ALREADY HAVE: Fractal Design Define XL R2 ATX Full Tower Case (unsure if front case USB will allow higher transfer speeds since the connection point on the case is older?)
Corsair HX1000i 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply. (Estimated 760-watt system load but don't want to ever skimp on the power supply)
Noctua NH-D15S 82.52 CFM CPU Cooler (Is it worth trying to reuse?)
Leaning towards getting all new parts rather than trying to reuse the 3 items above since despite being in excellent shape they are getting close to 10 years old.
OVERCLOCK OR NOT? Rather have stability than a little extra performance so currently doesn't anticipate overclocking unless recommended.
CPU
Usage? Current: Video editing Adobe Premiere Pro (90%) including Adobe After Effects/Photoshop (5%) and some light color grading (5%).
Future: Expecting Video Editing (65%), Photoshop AI (25%), and Color Grading (10%), After Effects (for special projects only)
Motherboard:
Do you need an overclockable model? Unlikely
What connectivity and ports do you need? Faster transfer speeds for direct connected backup drives (not using a NAS yet) would be a nice feature since currently local backups can take time.
Is it compatible? Is it the right size for the case? I am guessing Yes.
Are you using it's onboard sound? Yes, but expected in the future to go with a DAC (not during this update but in the future)
Graphics Card: No, gaming would be done on this system. Just video editing and video editing supported tasks.
Suggestions are welcome since I am having a difficult time selecting a graphics card appropriate for video editing that is actually in stock. Leaning towards one that has more VRAM than rated speed since some have suggested that it's the better way to go for value. Having both is ideal but keeping it close to budget likely VRAM will have to be prioritized.
RAM: Any suggestions for ECC RAM would be welcome if recommended to use.
SSD's/HDD's (Size?. Prioritizing on reliability over performance. Moved down from 8 TB to 4 TB M.2 drives due to costs. Leaning towards the following set up for M.2 drives.
1 boot,
1 scratch,
3 raided for all active working projects.
1 HDD for archiving projects.
Case: Not interested in any RGB but interested in having the system run quiet for critical audio listening/sound design.
PSU: Recommendations are welcome, but I just selected one with a good amount of power for the build. Probably overkill but it was recommended and listed on the mobo capability list.
Monitor: Currently run 3 smaller standard 22-inch screens. They are nothing special but get the job done. Next upgrade may include upgraded monitors but likely more than a year out due to budget.
Operating System: Windows 11 Pro
Peripherals: Wireless keyboard, mouse, basic editing control surfaces, and small mixer for voice recording.
Cooling (Noctua NH-D15S for CPU and several Noctua case fans listed.
Thank you for taking a look and to anyone that has any suggestions.
Questions:
Build:
Use:
CPU
Motherboard:
1 boot,
1 scratch,
