QNAP Unveils the QWA-AC2600 Wireless Adapter
889 (0.36/day)
QNAP Systems, Inc. today released the new QWA-AC2600 wireless adapter that can provide increased flexibility in NAS deployment and potential NAS applications. The QWA-AC2600 is a 2.4/5 GHz dual band dual concurrent (DBDC), 4 x 4 multi-user MIMO (MU-MIMO) PCI Express (PCIe) wireless adapter, equipped with two Qualcomm QCA9984 NICs, that supports speeds up to 2533 Mbps.
Joan Hsieh, Product Manager of QNAP, said, "The QWA-AC2600 wireless adapter can turn Ubuntu/Linux PCs or compatible QNAP NAS into wireless access points or base stations, providing more flexibility in usage and more potential applications. Multiple QWA-AC2600 adapters can be installed into a single Ubuntu/Linux PC or QNAP NAS for flexible deployments and performance expansions without the clutter of network cables."
The QWA-AC2600 can be used with Ubuntu/Linux PCs or QNAP NAS to set up wireless access points or base stations for other wireless devices to directly access data inside it, while offloading traffic from the primary wireless base station. Ideal scenarios include IoT (Internet of Things) developments, video surveillance and more. The QWA-AC2600 can be used on QNAP NAS with the WirelessAP Station app and the Network and Virtual Switch app can be used to enable advanced features such as DHCP and NAT.
Key specifications
QWA-AC2600: PCIe 2.0 x1 interface, IEEE 802.11a/b/g/n/ac, 2.4/5 GHz DBDC, 4 x 4 MU-MIMO, max. 2533 Mbps, antennas detachable, with magnetic stand base and full-height & specialized (for selected QNAP NAS) brackets included
Availability
The new QWA-AC2600 is now available for purchase. For more information and to view the full QNAP NAS and peripheral lineup, please visit www.qnap.com.
993 (0.19/day)
Processor Intel Core i5 8400
Cooling Silverstone AR05
Display(s) Dell U2415
Case Silverstone RVZ02B
Keyboard Ducky One Red Switch
Software Windows 10 Pro 1909
Holy smokes, I didn't know network components need this type of cooling.
6,658 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW | Sapphire PULSE RX 590
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
But can it stream Crysis...
307 (0.06/day)
Processor Ryzen 2700X
Motherboard Asrock X470 Master sli/ac
Cooling Raijintek Themis Evo
Memory Team Dark Pro 3200 cl14
Video Card(s) GTX 1080
Power Supply Seasonic Focus Gold Plus 850W
I had a router CPU cooled with a modded real CPU cooler, in hot summer days it could get rather uncomfortably warm, much less disconnections due to overheating too.
16,717 (2.33/day)
This is technically a router on an add-in card. Considering the tight space in some of the NASes, the active cooling might actually be needed.
It's actually not the CPU that's the hottest part in high-end routers, but the power amplifiers. They're tiny and hard to cool.
480 (0.13/day)
System Name Diablo | Baal | Mephisto | Andariel
Processor i5-3570K@4.4GHz | 2x Xeon X5675 | i7-4710MQ | i7-2640M
Motherboard Asus Sabertooth Z77 | HP DL380 G6 | Dell Precision M4800 | Lenovo Thinkpad X220 Tablet
Cooling Swiftech H220-X | Chassis cooled (6 fans + HS) | dual-fanned heatpipes | small-fanned heatpipe
Memory 32GiB DDR3-1600 CL9 | 96GiB DDR3-1333 ECC RDIMM | 32GiB DDR3L-1866 CL11 | 8GiB DDR3L-1600 CL11
Video Card(s) Dual GTX 670 in SLI | Embedded ATi ES1000 | Quadro K2100M | Intel HD 3000
Storage many, many SSDs and HDDs....
Display(s) 1 Dell U3011 + 2x Dell U2410 | HP iLO2 KVMoIP | 3200x1800 Sharp IGZO | 1366x768 IPS with Wacom pen
Case Corsair Obsidian 550D | HP DL380 G6 Chassis | Dell Precision M4800 | Lenovo Thinkpad X220 Tablet
Audio Device(s) Auzentech X-Fi HomeTheater HD | None | On-board | On-board
Power Supply Corsair AX850 | Dual 750W Redundant PSU (Delta) | Dell 330W+240W (Flextronics) | Lenovo 65W (Delta)
Mouse Logitech G502, Logitech G700s, Logitech G500, Dell optical mouse (emergency backup)
Keyboard 1985 IBM Model F 122-key, Ducky YOTT MX Black, Dell AT101W, 1994 IBM Model M, various integrated
Software FAAAR too much to list
Hmm.. That antenna array. I like it. Where can I buy it?
FreedomEclipse
~Technological Technocrat~
23,583 (3.74/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
I think Asus used to have something similar bundled with their high end AC network cards. Not sure if this is still the case though
38 (0.01/day)
Houston, TX
Processor AMD Ryzen 1700X
Motherboard ASRock X370 Taichi
Cooling EKWB Custom Loop
Memory 16GB (2x8GB) G.Skill Trident Z RGB 3000Mhz
Video Card(s) MSI Gaming X GTX 1080 EKWB Nickel WB
Storage 256GB WD Black M.2 O/S & 1TB WD Black Storage
Case Anidees Crystal Cube RGB
Power Supply Corsair RM 850 W/ Cable Mod Carbon Pro Cables
Mouse Razer Deathadder
Keyboard Razer Black Widow
Software Win 10
I want the water block version lmk when that's out thnx lol
480 (0.13/day)
Not in the full 4x4 setup afaik :/
5,449 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
Um not it's not it's a dual chip wireless nic and that's it
16,717 (2.33/day)
Huh? The QCA9984 is router grade hardware combined with four PA's per chip. You do not get this in a wireless NIC.
Maybe read up on your tech before making uneducated comments.
Yes, there's no router SoC on this board, but that doesn't mean this isn't half a router on an add-in card.
This won't work with Windows, as QCA only provides Linux drivers for these chips, so saying it's just a "dual chip wireless nic and that's it" is obviously not correct.
Or maybe you think it's normal to pay $160 for a WiFi card that's limited to what platforms it can run on?
5,449 (1.03/day)
Gougeland (NZ)
did you read the specs for it differently than I did, it maybe router grade but it's not a router it's dual chip dual channel quad connection NIC just because it wont run in a PC under windows doesn't change the fact it's just a NIC
16,717 (2.33/day)
Clearly you don't understand what this is, but that's ok...
5,449 (1.03/day)
Gougeland (NZ)
Sorry I understand completely what it is it's you who are trying to make it sound more complicated than it really is IT'S A FLAMING 4 WAY WIFI NIC so it's still a bloody NIC isn't it
16,717 (2.33/day)
Whatever dude.
Deathlokke
11 (0.00/day)
"The QWA-AC2600 wireless adapter can turn Ubuntu/Linux PCs or compatible QNAP NAS into wireless access points "
This is far more than just a NIC. A standard desktop NIC cannot function effectively as a WAP.
6,563 (1.40/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
Prepare to get your brain friend from all that EM power!
