Question about different DVI port colors
88 (0.03/day)
Houston
System Name Able to Run Star Citizen ON MAX GRAPHICS
Processor AMD FX-9590 4.70 GHz (5.0GHz Turbo) Eight-Core AM3+ CPU 8MB L2 Cache & Turbo Core Technology
Motherboard ASRock 990FX Extreme3 AMD 990FX ATX w/ UEFI Bios, XFast Technologies, GbLAN, 3x PCIe x16, 1 PCIe x1
Cooling Asetek 550LC Liquid Cooling and a square Room Fan by Lasko to cool internals
Memory G.Skill Ripjaws X 16GB (8GBx2) DDR3/2133MHz Dual Channel Memory
Video Card(s) XFX Double D AMD Radeon R9 280 3GB GDDR5 PCIe 3.0 x16 Video Card (Single Card)
Storage 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD
Display(s) Benq FP990 (REALLY OLD AND SQUARE SHAPED)
Case CyberPower Standard Case
Audio Device(s) Don't Remember Brand
Power Supply EVGA Supernova 1300 Watt 80+ Gold
Mouse Azza Standard Optical Mouse
Keyboard Azza Standard Gaming Keyboard
Software Windows 7 64 Bit
Benchmark Scores Never did it for fear of frying my GPU/CPU
So my XFX DD R9 280 has 2 DVI ports, the top one has a blue color and the bottom one has a red color. I didnt think there was a difference until I noticed in the top one I have no problems and the bottom one I have had several complete compuier crashes while playing games, Is there an actaul difference between Blue and Red DVI Ports on this card or is the bottom port just faulty?
rtwjunkie
PC Gaming Enthusiast
14,034 (2.29/day)
Louisiana
Processor Core i9-9900k
Does one have a part of the plug that looks like this: - and another that looks like this: + ?
The - are DVI-D or Digital, the + are DVI-I or Integrated, which will transmit analog and digital signals.
Of the DVI-D there are single link and dual link, with the single link having a gap in the main body pin array. Single link are normally limited to 1900x1200, and Dual link capable of higher resolutions.
The colors don't usually matter, and no standard exists that I am aware of.
EDIT: Here's a little more explanation: https://en.wikipedia.org/wiki/Digital_Visual_Interface
According to your card here: http://xfxforce.com/en-us/products/...black-double-dissipation-edition-r9-280a-tdbd they are the same color. However, the specs say you have a Dual link DVI-I and a Single link DVI-D.
According to this review, the Black/Blue one is DVI-D. http://www.technologyx.com/featured/xfx-r9-280-double-dissipation-review/2/
88 (0.03/day)
Houston
The - are DVI-D or Digital, the + are DVI-I or Integrated, which will transmit analog anf digital signals.
Yeah I checked the bttom one has a plus. but is there any correlation between crashes on the botom one and never crashes on the to[p one?
rtwjunkie
14,034 (2.29/day)
Louisiana
Honestly I don't know. What connection does the male connector for your monitor cable have?
EDIT: I'm guessing your monitor connector is single link DVI capable, and would account for the no problems using the DVI-D connector on your card which is single link.
88 (0.03/day)
Houston
yeo thats probably the case since my monitor is ancient... but which one should I use if I get a new monitor that is modern?
rtwjunkie
14,034 (2.29/day)
Louisiana
I would use the DVI-I since it's dual link, if you get a new monitor, or use the Display Port.
@XFXSupport, your thoughts?
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
There is different cable also
rtwjunkie
14,034 (2.29/day)
Louisiana
D'oh, I didn't even think about trying a DVI-D DL cable! With a dual link, he should be able to use the DVI-I connector without any issues like now.
hat
Enthusiast
21,754 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Hold up... I find it very odd that something as silly as which DVI port you're using causes your computer to crash. The only possible explanation that comes to my mind is if you had a monitor (which you don't) capable of really high resolutions, or a high refresh rate (120/144hz), and these features were only possible using the dual link port, and your computer only crashed while using the dual link port, suggesting possibly instability with your video card as it stresses harder to produce the higher resolution/refresh rate.
You said you don't crash while using the top port, which would mean in the DVI-D port you're fine, and in the DVI-I port you have problems. However, if you look at the image of the back of the card, you'll see that next to the black/blue port there is a VGA icon next to it, and the red port has what appears to be an icon for digital. This seems to suggest that the black/blue port is, in fact, the DVI-I port, and the red port is the DVI-D port, contrary to what the reviewer writes. If I'm right this turns everything upside down and you're okay with the DVI-I port, and not the DVI-D port, which still does not make sense.
rtwjunkie
14,034 (2.29/day)
Louisiana
@hat the only quirk in what you stated is the XFX specs page I linked states the DVI-D is actually single link.
hat
Enthusiast
21,754 (3.23/day)
Ohio
That doesn't really change anything... it just means he's having no issues with a DVI-D single link monitor via a DVI-D single link connection. There's no reason, that I know of, for any problems to occur when using a monitor with a single link connection with a connector that is dual link. If anything, at the most, I would expect the monitor to say "out of range" or somesuch, or possibly have some weird display issues, but crashing the entire computer? That's a bit of a stretch.
88 (0.03/day)
Houston
So can you link me to a DVI cable that is dual
12,340 (2.21/day)
Oregon
http://www.newegg.com/Product/Produ...re=dual_link_dvi_cable-_-12-816-013-_-Product
88 (0.03/day)
Houston
88 (0.03/day)
Houston
Heres Pictures, I use the blue one and I have the cable that was linked to me
http://prntscr.com/9krdl0
http://prntscr.com/9kre3z
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
One is dual-link DVI-I (with digital and analog), the other is single link DVI-D (digital only). I have to admit though, I'm not sure which color is supposed to represent which port.
1 x DL-DVI-I
1 x SL-DVI-D
88 (0.03/day)
Houston
So when I get a super quality awesome Monitor which port do I stick it in, the red one or Blue one?
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
A "super awesome quality monitor" shouldn't be using DVI but rather DisplayPort IMHO. I also already said before:
88 (0.03/day)
Houston
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
rtwjunkie
14,034 (2.29/day)
Louisiana
I said above, "or use the Display port"."
88 (0.03/day)
Houston
44 (0.01/day)
Turkey/Istanbul
Processor AMD Ryzen 5 2600
Motherboard MSI MPG X570 Gaming Edge
Cooling Cooler Master ML240L
Memory Ballistix Sport LT White 16GB DDR4-3000 * 2
Video Card(s) ASUS ROG Strix RTX 2070 Advanced
Storage Sabrent Rocket
Display(s) ASUS MG278Q
Case Phanteks P350X
Power Supply Aerocool P7-750W
Keyboard Logitech G105
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Aren't they same? (Both seems DVI-I for me; 24+5pin)
Here is an example for DVI-I & DVI-D on same card:
The OP has a XFX card, that's an ASUS card... For the OP, one port is dual link, the other is single link in addition to one being DVI-I and the other being DVI-D respectively.
44 (0.01/day)
Turkey/Istanbul
Case Phanteks P350X
I was just showing as example... There is OP's card's pictures in the quote above, anyway here is OP's card from XFX website;
