Question about HWMonitor PWM fans show 0%
Driver170
10 (0.20/day)
i’m not very tech savy with all this stuff but learning as i go along.
i just got this from chillblast which they built up but i chose the parts
Does anyone know why in HWMonitor PWM fans 0,1,2 show 0% are these related to the fractal fans at the front which you get with the case?
Here are some pictures
Gigabyte X870 GAMING X WIFI7 AMD Motherboard
Fractal North XL Mesh Full Tower Case - Black
Corsair NAUTILUS 360 RS 360mm
ARGB AiO Liquid CPU Cooler in Black
13,739 (2.02/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I cannot tell what's really going on by the pictures EXCEPT that the fans are indeed, clearly spinning - a very good thing.
As for HWMonitor, I can only guess the fans are not being powered via monitored motherboard fan headers.
Did Chillblast suggest using HWMonitor to monitor your fan speeds?
Driver170
10 (0.20/day)
Well they are spinning which is good. They never mentioned what to use. Should i use the Gigabyte control command software?
sneekypeet
not-so supermod
29,696 (4.30/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
As a newer member, might I suggest uploading images through the "attach files" button. No offense, but users will be sus of outside links ;)
Driver170
10 (0.20/day)
Ok uploaded some pictures.
CPU 2320 RPM
CPU OPT 1094 RPM
SYSTEM 4 PUMP 922 RPM
So CPU OPT is my case fans and SYS 4 PUMP is my CPU cooler? So where is the CPU FAN that reads 2320 or does this cooler have two pump fans maybe?
But having a look at my front fan case it looks like they are plugged into SYS FAN 4
3,891 (1.93/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 85C temp limit, CO -8~14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3037), upgraded from Win10 to Win11 on Jan 2024
What does HWiNFO64 tells you about the fans/pump speeds?
Also you should inspect the system thoroughly and find out what is connected where if you want to get to the bottom of this
