Question About I5 8600k OC for personal use
ZeusCoral
3 (1.50/day)
Hi I have an I5 8600k + Asrock Z370 Taichi + Seasonic 750w Gold + NZXT x62 AIO. I dont use the PC for gaming this last time, and I Recently overclock the 8600k from 3600mhz stock to 4600mhz ( I use a guide from a video so I put all cores at 46, voltage at offset 50) and the temps and VCORE at Windows was good at stress test. My question is : Is worth to have the CPU all time at 4600mhz to web browse, see videos, open programs, etc or I dont see a diferrent in speed up my PC? I want to be sure that the oc is worth it and is done good. Thanks
666 (2.71/day)
Woodstock IL
Processor 13700K
Motherboard MSI Z690 D4
Cooling Air/water/DryIce
Memory Corsair 3600mhz something die cl18 at 4000mhz
Video Card(s) RX 6700 XT
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Power Supply Antec 850w Continous Power Series (since 2009)
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Benchmark Scores Max Freq 13700K 6.7ghz DryIce. Max all time Freq FX-8300 7685mhz LN2
Sounds good to me. If it's stable, use it.
959 (0.29/day)
System Name The Banshee
Cooling CM Hyper 212 Plus
Memory 16GB 2x8 G.Skill Trident Z 3600 CL16 1.35V
Video Card(s) RTX 3060M 6GB @ 1750-2100MHz Core / 1875MHz Mem
Storage 1TB Kingston NV2 & 1TB Mass Storage HDD
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 10 Pro 64-Bit
Stock turbo on the 8600K is between 4.1GHz-4.3GHz, running it @ 4.6GHz isn't going to make a difference in normal use. Of course it's technically faster but you won't be able to tell.
ZeusCoral
3 (1.50/day)
So is best to undo all the overclock and set the BIOS to stock u say? The turbo speed activate automátically, right? Thanks
1,000 (2.03/day)
System Name Stugots V
Cooling Thermalright PA-120 Black
Memory 2 x 16GB G.Skill 3600Mhz CL16
Video Card(s) ASUS Dual RTX 4070
Storage 500GB WD SN750 | 2TB WD SN750 | 6TB WD Red +
Display(s) Dell S2716DG (1440p / 144Hz)
Case Fractal Meshify 2 Compact
Audio Device(s) JDS Labs Element | Audioengine HD3 + A8 | Beyerdynamic DT-990 Pro (250)
Power Supply Seasonic Focus Plus 850W
Keyboard Leopold FC750RBT
Software Win 10 Pro x64
Since you're just doing basic computing put it back to stock, heck you can even try and undervolt it.
Also yes Turbo should be enabled by default, you can check all of that in BIOS settings too.
ZeusCoral
3 (1.50/day)
Ty I leave it stock and with the high performance plan at Windows 10 so the CPU is at 4000/4100mhz all the time
1,000 (2.03/day)
You can put it to balanced or custom, your chip doesn't need to be running at 4GHz just to watch a video or browse the web.
Since Turbo is enabled by default the it will clock itself up when needed, and down when it isn't (best of both worlds).
