question about quality difference between resolutions on same size monitor.
54 (0.16/day)
Almelo, Netherlands
System Name my system
Processor AMD Ryzen 7 5800X3D
Motherboard Asus Rog strix b550 gaming wifi II
Cooling noctua nh-u12s se-am4
Memory corsair vengeance 32gb (2x16) 3600mhz
Video Card(s) Asus tuf Nvidia RTX 4070 TI Super
Storage 1x 240gb kingston ssd (win) 1x500gb kingston m2 1x1tb 870 evo ssd (for games both)2x1tbhdd (storage)
Display(s) gigabyte aorus cv27f
Case Sharkoon Rebel c50 RGB
Audio Device(s) Creative soundblaster x-ae5 plus
Power Supply Seasonic Focus GX-850 ATX 3.0
Mouse Logitech g502x
Keyboard Perixx Periboard 835
VR HMD none
Software win 11 64 bit home
Benchmark Scores To be tested, so none yet
Heya.
Since im buying a new monitor in a month from now i was wondering about something.
I currently do have an 27" 1080p va monitor with hdr400 and unofficial g-sync.
Im switching to a 27" 1440p QD-Oled monitor with hdr400 true black and unofficial g-sync.
I know the 1440p has more PPI, but i was wondering: If i set the resolution of my games back from 1440p to 1080p on the new monitor, do they look as good then as that they are looking now on my 1080p screen?
I mean, my logic would say cause theyre both 27" screens, that the difference should be minimal if gaming on 1080p on that new screen, just because of the same sizes of both monitors.
Am i correct in this regard?
Thanks in advance!
3x0
977 (1.13/day)
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
No, 1440p isn't an integer multiple of 1080p, it will look terrible (1440p = 1080p x 1.33). It would look better if it was a 2160p screen showing a 1080p picture as there are 4 native pixels to show a single 1080p pixel.
98 (0.07/day)
System Name desktop
Processor Ryzen 9800X3d
Motherboard Asrock Pro Rs
Memory G.Skill Flare X5 6000mhz cl30 1.35v
Video Card(s) Asus GeForce RTX 4080 TUF Gaming - OC Edition
Storage 2TB WD_BLACK SN850X NVMe
Display(s) Acer Predator 1440p
Case Fractal R6
Yeah i think it would look more blurry and just seem off mostly since the pixels dont kinda line up properly.
54 (0.16/day)
Almelo, Netherlands
VR HMD none
So in this case, since 27" monitors that are 4k are rare and expensive, my best bet to get decent fps is to crank up the frame gen and dlss a bit more then?
I mean, maybe im a bit too much "used" now to having high fps with my 4070 ti super, but i still remembering the days where my 2070 was really outdated netting me fps of around 40-45 ingame.
But hey, i do have a 4070ti super with a ryzen 7 5800x3d, so i still, especially with dlss and frame gen, should get decent fps in most, if not all games for a couple of years to come isnt it?
188 (0.11/day)
System Name The New, Improved, Vicious, Stable, Silent Gaming Space Heater
Motherboard MSI B450 Tomahawk Max
Cooling be quiet! DRP4 (w/ added SilentWings3 120mm), 4x Noctua A14x25G2 (3 @ front, 1 @ back)
Memory Teamgroup DDR4 3600 16GBx2 @18-22-22-22-42 -> 18-20-20-20-40
Video Card(s) PowerColor RX7900XTX HellHound
Storage ADATA SX8200Pro 1TB, Crucial P3+ 4TB (w/riser, @Gen2x4), Seagate 3+1TB HDD, Micron 5300 7.68TB SATA
Display(s) Gigabyte M27U @4K150Hz, AOC 24G2 @1080p144Hz vertical, ASUS VP228H@1080p60Hz vertical/ double4Kwhen?
Case Phanteks P600S
Audio Device(s) Creative Katana V2X gaming soundbar
Power Supply Seasonic Vertex GX-1200 (ATX3.0 compliant)
Mouse Razer Deathadder V3 wired
Keyboard Keychron Q6Max w/ Gateron G Pro 3.0 Black linear switches
27" 4K IPS is not very rare here. 27" 4K OLED though...
You have a 4070TiSuper, if you're fine with turning up DLSS it's pretty okay for 4K IMO.
But if you are very minded in FPS I'm not going to push for a 4K monitor.
2,154 (0.66/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
For the sake of open minded discussion I'd place resolution lower than overall focus on what the best 27" monitor ish screen currently available is. Might be instructive.
54 (0.16/day)
Almelo, Netherlands
VR HMD none
Aye, i was looking for it, and found out that 27" 4k oleds almost don't exist at all.
But indeed, i most likely will be fine with my gpu for a couple of years to come.
As for @nomdeplume
I have looked for it for a couple of months already, and it seems to me that the Gigabyte aorus fo27q2 is the best bang for the buck here in the netherlands:
I know that one is its bigger brother the q3, but its exactly the same with the only difference is that the q3 has a higher refresh rate, and some rgb at the back.
I mailed gigabyte about it, and they confirm it as well.
And since the q2 only costs 600 euro's here in the netherlands, i think its the best monitor that you can buy with such low amount of money
2,154 (0.66/day)
Storage 1TB 980 Pro
Software W11 Pro
Must've had this search for a 27" 4K in mind. Ended up watching a string of hilarious videos reviewing "best 27" monitor available" the 55" Samsung Odyssey Ark.
