Question about setting AIO pump correctly
Sharkley22
7 (0.01/day)
Hello everyone,
first of all I would like to apologize for any writing mistakes, because English is my second language. But back to the topic...
Yesterday I have mounted AIO for the first time to my PC (bequet! silent loop 2 280mm). Generally, everything works fine, CPU temperatures do not exceed 65 degrees, but I am concerned about my AIO pump speeds. Right know the motherboard set it up to 1800 RPM and that value is changing up to 2800 rpm depending on the CPU temperature. Im afraid that at idle 1800 RPM is to low. I have done some reserch and according to the producer website the voltage at which the pump should operate ranges from 9-12 volts. I have tried to set it up like that, but it looks like that, my motherboard (gigabyte b550 gaming x v2) does not allow setting fan or pump via voltage, I can only manipulate rpm values. Producent website states that pump RPM is 2800, so im assuming that this value is maximum voltage with which the pump can work, that is 12 volts. So in order to set it up to 9 volts (9-10V in order to keep the pump silent) I should set it up to 2100 RPM or it doesn't work in that way? I am kindly asking for help, because I do not want to break the newly purchased AIO.
2,789 (2.16/day)
Germany
System Name Sunk Cost Fallacy
Cooling Thermalright Phantom Spirit 120
Storage WD Black SN850X 1TB + 2x 2TB, 2x 4TB Crucial MX500, 4TB Samsung 870 Evo.
Display(s) Alienware AW2723DF, LG 27GR93U, LG 27GN950-B
Case Streacom BC1 V2
VR HMD Oculus Rift S
just set it to static 100%.
Sharkley22
7 (0.01/day)
Well... I tried that but at 100% pump is "buzzing" quite loudly, and the whole point of upgrading to AIO was to finally keep my proccesor cool and silent (meaby it was a mistake, at least it's cool right know). I have red-necked thought that If 100% is 2800 RPM and thats 12V, so 9V should be 2100 RPM am I right or that logic is completely wrong?
Toothless
Tech, Games, and TPU!
9,472 (2.49/day)
Washington, USA
System Name Veral
Processor 5950x
Motherboard Asus Crosshair VIII Hero Wi-Fi
Memory 2x16GB G.Skill TridentZ
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
You should be able to have fans run off the board, AIO to be on the AIO header.
Sharkley22
7 (0.01/day)
I have plugged aio pump according to Gigabyte manual that is to the CPU OPT, by the looks of it this motherboard doesn't have a described and dedicated AIO header like for example some ASUS one's.
2,789 (2.16/day)
Germany
then set it gradually lower until it's not annoyingly loud. but have a static RPM it's a lot better for bearings/motors in general.
Sharkley22
7 (0.01/day)
So i should set it up with the "RPM Fixed Mode" in my BIOS? But at which value, i don't want to over do this and go below 9V and break the pump :(.
1,855 (2.67/day)
Brazil
System Name G-Station 1.17 FINAL
Processor AMD Ryzen 7 5700X3D
Cooling DeepCool AK620 Digital
Case Thermaltake Level 20 MT
Mouse Razer Viper Ultimate
What Gigabyte board do you have? On mine there's two dedicated AIO/PUMP headers
Sharkley22
7 (0.01/day)
2,789 (2.16/day)
Germany
how are you supposed to break a product that is literally running in spec? 9V is probably the minimum to make it even start working.
Sharkley22
7 (0.01/day)
So guys any do have any idea on how much rpm should I set it in order to run the AIO pump on 9V?
9,271 (3.33/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
I think you are confusing things, it sounds like the pump is DC controlled, so the header has 3 pins, which means it's controlled by varying the voltage. The way that works is at some point the voltage becomes high enough that the pump starts spinning (this varies from pump to pump. or fan to fan) and then at 12V it reaches it's maximum speed, you don't have to worry about breaking anything, that's just how that works. There is no predetermined RPM at which it spins if the voltage is 9V, this varies from product to product and it's of no relevance to you.
I suggest just leaving it as is, it's actually better that it's not spinning at it maximum speed all the time for longevity.
143 (0.08/day)
System Name Locutus TT P90 open air case
Processor Intel I7 12700K
Motherboard Asus Z690 WIFI D4
Cooling NZXT 280 mm AIO
Memory 32 Gig Corsair Vengeance 3600 DDR4
Video Card(s) Zotac 3080 Holo LHR
Storage 3 various branded SSDs and 6 TB Seagate HD
Display(s) LG 32'' g-sync 144 Hz VA IPS
Case P90 open air case
Power Supply EVGA G2 1 KW
Mouse Logitech G900
Keyboard Corsair Strafe
Software Win 11 Pro
1. All moving parts generate noise.
2. As long as temp stay below 90 C it will be hard to get a warranty replacement and you are only as good as your ambient temp.
3. Try setting BIOS header speed to 100%.
4. Do not overtighten the AIO mounts or use excessive paste.
