question about super resolution
49 (0.16/day)
Almelo, Netherlands
System Name my system
Processor AMD Ryzen 7 5800X3D
Motherboard Asus Rog strix b550 gaming wifi II
Cooling noctua nh-u12s se-am4
Memory corsair vengeance 32gb (2x16) 3600mhz
Video Card(s) Asus tuf Nvidia RTX 4070 TI Super
Storage 1x 240gb kingston ssd (win) 1x500gb kingston m2 1x1tb 870 evo ssd (for games both)2x1tbhdd (storage)
Display(s) gigabyte aorus cv27f
Case Sharkoon Rebel c50 RGB
Audio Device(s) Creative soundblaster x-ae5 plus
Power Supply Seasonic Focus GX-850 ATX 3.0
Mouse Logitech g502x
Keyboard Perixx Periboard 835
VR HMD none
Software win 11 64 bit home
Benchmark Scores To be tested, so none yet
Hey all.
I still have a 1080p monitor, but am going to make the jump to a 1440p oled in a couple of months.
But I want to test my pc already for it, and now I've heard of super resolution that you can enable in nvidia control panel.
But when enabling the 1440p there, it it the same level of resource intensity as that normal 1440p gaming is? So for example i can expect the same fps ingame then both on 1080p with 1440p super resolution enabled compared to normal 1440p with the new monitor?
Thanks in advance.
ps, i know my pc can handle 1440p quite well, cause i have an 5800x3d and a 4070 ti super, but I'm still curious to see my fps on 1440p beforehand.
162 (2.22/day)
System Name le fish au chocolat
Processor AMD Ryzen 7 5950X
Motherboard ASRock B550 Phantom Gaming 4
Cooling Peerless Assassin 120 SE
Memory 2x 16GB (32 GB) G.Skill RipJaws V DDR4-3600 DIMM CL16-19-19-39
Video Card(s) NVIDIA GeForce RTX 3080, 10 GB GDDR6X (ASUS TUF)
Storage 2 x 1 TB NVME & 2 x 4 TB SATA SSD in Raid 0
Display(s) MSI Optix MAG274QRF-QD
Power Supply 750 Watt EVGA SuperNOVA G5
I would just set the resolution of your game to 1440p (in the game settings)
not sure if super resolution 1440p is the same as native 1440p
49 (0.16/day)
Almelo, Netherlands
VR HMD none
That's what i wanted to do yes. But then still, can i expect the same fps, cause without super resolution obviously i cannot set 1440p ingame with my 1080p monitor
162 (2.22/day)
I think you can, I have several games which give me the option for 4k & even 8k if I am not completely wrong (and i own a 1440p monitor), maybe some games don't offer the option?
Either way your 4070ti/s should smoke 1440p, especially with dlss
49 (0.16/day)
Almelo, Netherlands
VR HMD none
For me it doesnt matter which game i play. Without enabling super resolution, 1080p is the highest i can select.
But ye, i know it should be a blast on 1440p especially with dlss. Still curious though what the fps difference will be.
162 (2.22/day)
Interesting...
Did you look at the reviews of the 4070ti/s? 4070ti/s
Just compare 178 frames average vs 138 frames average, it loses on average 28.9 % frames.
It's not perfect. But should suffice for now.
You could also enable super resolution and look if the difference is around 29 - 30%
49 (0.16/day)
Almelo, Netherlands
VR HMD none
Interesting...
Will do indeed! Thanks nevertheless!
3,527 (1.18/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
1440p DLSS.Quality should perform around 1080p Native minus 10%.
For example, if you get 100FPS @ 1080p Native, you will get 90FPS @ 1440p DLSS.Quality
7,388 (4.95/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Hey all.
Yes. However, keep DLSS and the sort OFF. Setting DSR to 1.78x will result in native 1440p output.
1,946 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Note : There are two versions of upscaling you can set on NV RTX cards :
1) Usual DSR - higher res. gets downsampled to whatever native resolution your screen has.
2) "DL" version, ie. DLSS "enhanced".
If you want to see native performance at higher resolution, you have to choose first option.
This should be within 5% of true native experience.
I wonder how much visual difference is there, between DL "enhanced" DSR and "native" DSR solution...
Of course, on base resolution screen (example : 1440p DSR vs. 1440p DLDSR/DLSS[?] on 1080p screen).
3,435 (4.91/day)
Russian Wild West
System Name DLSS / YOLO-PC / FULLRETARD
Processor i5-12400F / 10600KF / C2D E6750
Motherboard Gigabyte B760M DS3H / Z490 Vision D / P5GC-MX/1333
Cooling Laminar RM1 / Gammaxx 400 / 775 Box cooler
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333 / 3 GB DDR2-700
Video Card(s) RX 6700 XT / R9 380 2 GB / 9600 GT
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 / 500 GB HDD
Display(s) Compit HA2704 / MSi G2712 / non-existent
Case Matrexx 55 / Junkyard special / non-existent
Power Supply Thermaltake 1000 W / Corsair CX650M / non-existent
Software Windows 11 / 10 / 8
There's absolutely zero difference. Running 1440p on a 1080p display and running 1440p on a 1440p display provide the same FPS. DSR will be exhausting for this matter.
I would say DLSS/FSR on Performance = 1080p.
Balanced rather. Performance gets better framerates and, usually, noticeably worse visuals.
1,946 (0.61/day)
System Name BOX
Keyboard HP KB-9970
Source : videocardz.com
